Has anyone tried using a MegoMoto shield yet?
https://www.robotpower.com/products/MegaMoto_info.html
I'm looking for some easy, high powered motor controllers to run some old electric wheelchair motors, and thought these might be compatible.
Cognitive Vision
— Microsoft Cognitive Vision integration for ARC: real-time object, face, emotion detection, OCR, confidence data and script-triggered robot actions.
I'd beware of using a shield, or specifically that one due to heat issues. It is bound to get hot and the EZ-B already has a couple high amp voltage regulators. The combined heat may be too high. The Sabertooth motor driver series by Dimension Engineering is what we recommend for high amp control.
Or, if you want to stick with an 4 wire style HBridge, than I use this for my snow shoveling robot: https://www.ebay.ca/itm/1xArduino-Smart-Car-50A-Dual-Motor-driver-module-high-power-Hbridge-strong-brake-/261004097423?pt=LH_DefaultDomain_0&hash=item3cc50e778f
But sabertooth is pretty awesome
Thanks! I'll go check out sabertooth.
I have a 12 amp RMS Sabertooth , it's a very nice controller.
