Auto Position (Gait) icon Auto Position (Gait) — Create servo frames and actions to animate gaits and gestures with automatic motion planning, software ramping, movement panel, import/export Try it →
Yes, you can use PWM to control the brightness of an LED, so a script that ramps up and down the pwm going to the digital port will do it.
Use the ServoSpeed() command to apply a ramping speed to the PWM. And as alan mentioned, use the PWM command to set the brightness.
Something like this...
# set the servo speed to 2
ServoSpeed(d0, 2)
:loop
# Set LED On
pwm(d0, 100)
# wait some time for the pwm to do its ramping thing
sleep(3000)
#set LED Off
pwm(d0, 0)
sleep(3000)
goto(loop)
I figured it might be through the servo controller. Seeing the code is very helpful. Thanks for the fast response, guys!
Oh, good one DJ. I didn't think about using the PWM ramping built into Servospeed.
I did this script (D11 is my LED)
$brightness = 0
repeatwhile($brightness) <= 100)
  PWM(D11,$brightness)
$brighness = $brightness + 1
Sleep(150)
endrepeatwhile
(this just ramps up, not back down).
@Science Bob.... Next time ask us something really challenging will ya.... LOL
Welcome to ez robot, btw.... :)
