Sabertooth Movement Panel icon Sabertooth Movement Panel — Sabertooth movement panel: control two motors via Simplified Serial with variable speed sliders, movement buttons, and serial port options. Try it →
Can't Switch Speech Recognition To French
Is any one have been successful setting up "Speech recognition" from US to french Canadian or other language in ARC.
(French Speech synthesis is working fine)
When I add the "speech recognition" feature in EZ-Buider, I always receive the message in debug:
2015-01-01 10:07 - Speech Recognition Culture: en-US 2015-01-01 10:07 - Loaded speech recognition successfully 2015-01-01 10:07 - Set Dictionary Error loading phrases (Custom): La langue de la grammaire ne correspond pas à celle du module de reconnaissance vocale. 2015-01-01 10:07 - Set Dictionary Error loading phrases (Custom): La langue de la grammaire ne correspond pas à celle du module de reconnaissance vocale.
French Speech rec. and speech synthesis are working fine under windows 8.1
I have remove and re install ARC several time with no success. I also had the same error trying on an other PC.
I know this issue have been address before and ARC is suppose to switch automatically to the right language.
Would it be a good idea to allow the user to change some variable manually?
I could be wrong, but I thought voice rec only worked with English....
Once DJ mention it should switch automatically to any culture installed on PC
