Pandorabot AIML2 icon Pandorabot AIML2 — Connect ARC to Pandorabots AIML2 to run AI-driven virtual personalities for human-like text or voice chat, using API keys and script hooks. Try it →
Netherlands
dome lift mechanism R2D2
Dome Lift Mechanism R2D2
I am trying to convert a system so it can be used in EZ-B/
The Dome Lift MEchanism by Matthew Zwarts https://www.thingiverse.com/thing:3654411
The system works with a hbridge that moves the platform up, hit a switch... Do his thing (depending on which lift, servo movement/leds... than reverse the direction of the platform till it hits the lower switch.
Whil going up ... a panel must be opened first and when going down it should close afterwards...
For now the scipt works by pushing a button as trigger....   Link to script:  https://www.thingiverse.com/download:7006587
Dome lift in action
Example of lift not exact the same used on R2..
The system works with a hbridge that moves the platform up, hit a switch... Do his thing (depending on which lift, servo movement/leds...  than reverse the direction of the platform till it hits the lower switch.   While going up ... a panel must be opened first and when going down the panel should close afterwards...
Dual Hbridge by Synthiam
Two-channel Dual H-Bridge movement panel to control two DC motors (on/off) for forward, reverse, left, right via EZ-B digital ports; no PWM speed.
From hiko translated....
Hello, as I am working on the dome elevation system, I have all the components but I have doubts about the connection of this board. I would appreciate some connection diagram of this component to know how to connect it correctly. Greetings from Chile
@hiko: That board is an affordable PCA9685 16-Channel 12-bit PWM/Servo Driver with I2C interface.
I would first start here:
If you have an EZ-Robot EZB controller, you can PWM/Control 24 servos, so the board is redundant.
Chile
Gracias amigo. Me ha servido mucho tu ayuda. Saludos
Chile
Otra duda, puedo reemplazar la tarjeta Mega 2560 por arduino uno?
#13   — Edited
No you need an Arduino Mega.
The project uses: 6 motors : 2 digital control pins per motor = 2 * 6 = 12 output digital pins. 2 dip switches per motors =  2 * 6 = 12 digital input pins 1 button per motor = 1 x 6  = 6 digital input pins  Total: 18 input ports + 12 output ports
Uno has: 12 digital pins (excluding the serial port)  4 analog input ports (excluding 2 ports for the I2C)
Definitely you need the Arduino Mega
onedayflie2, I'd love to collaborate with you using the ARC system instead of Padawan 360, etc - as I am building an R2D2 from Michael Baddeley's designs.  Are you on any FB forums related to the R2 build?
Netherlands
#15
I had a pause because of the covid period...  But i will resume my project soon (as soon if i can get that subscription)
Colaboration is great... Let me take some pics of the wiring.... And i try to upload my build...  Isn't there a chatfunction?
