NMS Faux Odometry icon NMS Faux Odometry — Estimate pose odometry from movement distance for robots without encoders, calibrated by speed. Suited for DIY navigation; pose drifts with lidar. Try it →
Best High Torque 12Volt 100Rpm DC Motors To Use With EZ-Robot System
looking for best high torque 12volt around about 100rpm DC motors to use with EZ-robot system boards and software
high torque is a must with speed of about 100rmp up to around 150rmp would suit my five inch (125mm) wheels
any advice on connecting  4 dc motors and 20 LARGE SIZE servos would be very useful
thanks all
And all of you please keep up the great work, love the hobby and I learn some think new each day (after getting stuck !)
#1   — Edited
I suggest you take a look at the Hoverboard thread. I know you are looking for a 12 volt system but the motors would meet your needs. Buying a complete Hoverboard for around $110 gives you the motors, battery and charger. The esc is up to your needs
I am also considering some large servos. I will be posting my findings
#2   — Edited
You can also try these type of car window lifter motors from Cytron available for about $80.00 CND at robotshop.com for both left and right at a very respectable 15 Amps and hi torque worm gears inside. They don't get to 100 rpm but more like 60-75 depending on battery used 12 volts.For my Large Terminator 5 feet tall robot it moves at exactly the perfect speed as any faster would be too fast for the Sonar to work good in bumping into stuff.Can work with any H-bridge as I am still using the cheaper one and it works great...Link to picture...Motors & 5"" rubber wheels
