ADC Value icon ADC Value — Display ADC port voltage and 0-255 linear values (0-3.3/5V); configurable board/port, units, multiplier and sample interval. Try it →
Wireless Connection To Arduino?
I’m building Spot Micro Next. The base design uses a Arduino Mega.  I’d like to use ARC to program the robot.   Has anyone worked out how to wirelessly interface to an arduino with ARC?
USB
Digital 21
#10   — Edited
DJ, what about using a iotiny plus a IIC connected either to an arduino mega or PCA9685 to control the 5v servos. I can add a single voltage regulator for the 8 servos. This way I could use the servo tools in ARC to automate the legs.  How would I map the servos?
Yet another option.. I found this thread in an arduino Bluetooth communicton scheme to ARC.
#33 Feb 2019 Any for that board will work. They just create a virtual COM port in Windows, which you select in ARC.
could I just use a Bluetooth module on the mega work and connect the it ASAP serial port to the pc? Load the ARC mega firmware to the board and massage in the Bluetooth code?
