Task Script icon Task Script — Split complex robot tasks into sequential scripts, synchronizing asynchronous skills via NEXT/CANCEL commands for staged automation. Try it →
Why does speech recognition pickup background nois…
Why Does Speech Recognition Pickup Background Nois…
One thing I still don't understand: whenever I have the "Speak Rec" robot skill operating, it picks up background noise and causes some of my Auto Position stills to activate on their own. I do use start/stop voice-activation scripts in my ARC project, but as long as Speak Rec is listening, if it hears a noise things start moving on their own and sometimes end up breaking the robot. Why does this happen?
For context: I'm using the Speak Rec robot skill and Auto Position presets in an ARC project and I'm using scripts to start and stop voice activation. I'm not sure whether my microphone is connected to the PC (USB/audio device) or to an EZB - if that matters, please let me know what detail would be helpful.
Script by Synthiam
For typical robot commands, I’d generally recommend Bing Speech Recognition if you have reliable internet and want better recognition quality.
Quick comparison
Regular Speech Recognition
Best when:
  • you want offline / local recognition behavior
  • you’re using a small, fixed phrase list
  • you want simple command triggers without cloud dependence
Tradeoffs:
  • more sensitive to microphone quality and room noise
  • recognition can be less consistent, especially with short phrases
  • can false-trigger more easily in noisy robot environments
Best when:
  • you want better accuracy
  • you use natural-sounding robot commands
  • you have a stable internet connection
  • you want more flexibility for speech-driven control
Tradeoffs:
  • requires internet
  • cloud-based, so there’s a small delay
  • still needs good mic placement and sane confidence settings
My recommendation
For a robot with moving parts, I’d usually choose:
  • Bing Speech Recognition for command recognition
  • a headset or external mic
  • a short listening window
  • a safety variable before allowing dangerous motions
That combination tends to be much more dependable than the regular Speech Recognition skill in noisy environments.
When I’d keep the regular Speech Recognition skill
Stick with the regular one if:
  • you don’t want cloud dependence
  • your command set is very small
  • you already have it tuned well
  • the robot works in a quieter environment
When I’d switch to Bing
Switch if:
  • you’re seeing false positives
  • recognition is inconsistent
  • you want more natural speech handling
  • you can use an external mic and internet
Important safety note
No matter which one you use, I would not let speech recognition directly drive risky motion without a check first. Use a script guard like:
  • $botharmsextended
  • a door/limit switch
  • a "safe mode" variable
That way, even a mistaken phrase can’t immediately move something fragile.
Best next step
If you want, I can help you decide based on your current ARC project setup.
A few things that would help:
  • Are you using phrase-only commands or full sentence recognition?
  • Is your project mostly offline right now?
  • Are the commands tied directly to Auto Position frames or to scripts?
  • Do you want maximum accuracy or no internet dependency?
If you share that, I can suggest the best choice for your exact setup.
Ok, good info. This is what I have done in the past and does seem to work. Except for the mis-triggered commands. I do use scripts for some functions and auto-position for others.
During my Hemi/Remi robot builds I set up ARC with three workspaces within the project.
First Workspace panel was the main one, this would have the regular Speech Recognition skill for general drive motor movement and head movement. It was also used for many arm movement from the Auto Position skill. This is more typical offline operation.
The second workspace panel was for any of the audio stuff, and I also used Bing Speech Recognition Skill along with the PandoraBot skill , which would be online stuff.
Third Workspace panel was used for User Interface configuration.
That’s actually a very sensible ARC design. Using separate workspaces for drive / motion, audio / AI, and UI/config is a clean way to keep the project organized.
My take on your setup
Given what you described, I’d keep the split like this:
  • Workspace 1: local robot control
    • Regular Speech Recognition
    • movement
    • head/arm actions
    • anything that needs to work offline
  • Workspace 2: online / conversational features
    • PandoraBot
    • cloud-based audio or chat behavior
  • Workspace 3: UI / admin / configuration
    • safe to leave separate so it doesn’t interfere with motion logic
That structure makes sense.
The main issue is still the trigger path
The problem isn’t really which workspace you use - it’s how easily a phrase can directly trigger a motion action.
If a spoken phrase goes straight to:
then a false recognition can still cause trouble, even in a well-organized project.
What I’d improve
1) Keep the regular Speech Recognition skill for offline control
If your main robot commands are local and simple, that skill is still fine.
Use it for:
  • drive
  • head turns
  • basic arm motions
  • emergency stop
2) Use Bing Speech Recognition for more conversational / online tasks
That’s a good match for:
  • PandoraBot
  • general dialog
  • richer speech interaction
3) Add a safety gate for every risky motion
This is the big one.
For example:
  • $safeToMoveArms = 0
  • $safeToMoveArms = 1
Then any arm/gripper command checks that variable before running.
Example pattern in ARC JavaScript
if (getVar("$safeToMoveArms", "0") == "1") {
  controlCommand("Auto Position", "AutoPositionFrame", "Open Gripper");
} else {
  print("Blocked: arms are not in a safe state.");
You could use the same idea for:
  • drive motors
  • head movement
  • any movement inside the robot body
Better than direct speech-to-action
Instead of:
  • Speech Recognition Auto Position
use:
  • Speech Recognition Script
  • Script checks safety state
  • Script then calls Auto Position
That adds a layer of protection without changing your whole project structure.
My recommendation for your current setup
If your current arrangement is mostly working, I would not rebuild everything.
I would:
  1. keep your three-workspace layout
  2. continue using Regular Speech Recognition for local control
  3. keep Bing Speech Recognition for online features
  4. wrap the dangerous motions in a safety-check script
  5. optionally consider a better mic if false triggers are still common
One thing to watch
If you have the same or similar voice phrases in both speech skills, that can create confusion. For example:
  • one skill hears "open gripper"
  • another hears something similar and triggers a different routine
So it helps to keep the phrase sets clearly separated by workspace/function.
ARC tip
If you haven’t already, you can configure each skill from its kebab / three-line menu and tune:
  • phrase list
  • confidence
  • scripts for recognized/not recognized behavior
That’s where I’d focus first.
If you want, I can help you map your current workspace design into a safer command flow, especially for the arm Auto Position actions.
The safety example you just provided, where would I put that and how would it get activated?
Sorry, I can't continue helping in this thread. It's grown long enough that my context window will require too much extra processing, which makes follow-ups unreliable and I can start making mistakes.
A couple of options:
  • Start a new thread that picks up where we left off - fresh context, faster responses.
  • Or get unlimited interaction with me through ARC's built-in AI Assistant agent: Synthiam AI Assistant
