EZ-B V3 Configuration icon EZ-B V3 Configuration — Manage EZ-B hardware settings: edit Bluetooth name and apply updates to restore altered configurations. Try it →
Vr Options?
Does anyone know if the SDK of the Oculus Rift package would work with EZB if there was a plug in developed for it? It doesn't really need to be something as big and bulky as that. Very unfortunate that Vuzix is no longer offering support with EZB. That would work great.
Like the Vuzix, I'd like to pull from the IMU data to move servos and transfer the camera feed from the EZ camera to the goggles over two complete separate computers in different places.
Any ideas or suggestions on how to POC this, would be grateful.
#129
Sounds good. I’ll up a bvh or fbx of the facial mocap. Yes I guess this would be without Bio Ik! My mistake! A script that could use any value in a scene would be helpful to me. I’m think not only setting up for full body and facial mocap but also control rigs, like for use to puppet control robots, VR etc!
#130
Got a facial mocap scene together in unity, best to observe the motion per the scene mode so you can watch the motion of the points being moved for each part of the face.
Link : Facial mocap Unity
@fxrtst I do not have time on my hands now...but I will check on it asap!:)
#132
Ok No problems! Thanks!
#133
Hey, I put the scripts to the Virtual JD...This is just to show how the whole thing works, so actually at the moment it is just sending the rotational values of JDs first two arm joints to servo D0 and D1 of your EZ-B. It seems to be working great, I experienced no lag, it seems to be realtime control!
As far as the setup goes...I created three different scripts RotX, RotY and RotZ. Drag and drop those scripts to the objects that you created joints for in BioIK. Always check which rotation you want to extract in BioIK first and use the corresponding script! The objects name should be changed to just the number of the servo that you want to drive in ARC.
In ARC just start the Http Server, setup the servos as usual...done!:)
If you are experiencing any difficulties, let me know!
edit...I assumed that the setup in Unity has the BioIK slider values set on -90/+90 if this is any different, you need to change the script!
#134
For the facial mocap, I do not get this to work...I have tried to access the y position of the Eyebrow, and I could retrieve the first position, but it does not update! I tried different approaches but none of them worked for me! Maybe I am doing something wrong, but I could not figure out what it is!
Also, since the face is moving in space, I guess there will be difficulties in getting this scene to work correctly...
edit
I could not resist to try one more option...so now it works! I took another Game Object and linked it to the position of the Eyebrow. I attached a scene where you can see a cube linked to the eyebrows movement and how the y position gets send to the EZ-B...but I guess its a hell of work to find all the upper and lower limits for those facial controls, I doubt they will stay the same in changing scenes? If you find out the value limits it can be easily translated to servo movement, but I dont know if all this is heading the right direction.
I guess the best route would be to create a rig in your favorite 3D application which contains all the servos that will drive the facial animation, and rig the facial animation to move your virtual robot inside of your 3D application, playback can be done in Unity!
Believe me I tried to map mocap to a robot, it does not work this way, the key is to create a mechanical rig which is a representation of the real world robot. That way motion can be created, or mapped for your robot!:)
https://we.tl/uT8tLNO2WN
#135
Ok I will give it a spin tonight. Nice job on the virtual JD. I'll let you know if i have any trouble setting it up. Glad to hear its reatime, I suspected Unity was going to drive everything real time when i saw the ArdUnity plug in working!
Thanks for trying with the face mocap. I figured I would have to create a retarget so all the positional data would be remapped to a robot standin or avatar. Which would then have consistent data. I will create a real world example. and see how we can solve the issues.
#136
Yes I guess if you would remap the data and there would be consistent limits plus only those values you want to use to drive the servos, it should not be a problem to wire it up in Unity!:)
