Soundboard (EZB) icon Soundboard (EZB) — Play WAV/MP3 via EZ-B v4, manage tracks, add timed scripts for synced robot actions, control via ControlCommand(), volume and clipping indicators. Try it →
Vertical Mounting Of Ez-b4, Hero-1 Reboot
Vertical Mounting Of Ez-B4, Hero-1 Reboot
Good Afternoon Community! I'm making slow but steady progress on rebuilding my Hero-1. I have a question:
Has anyone run in to issues mounting a EZ-B4 vertically?
See the attached photo.
I've looked at all the EZ robots...all are horizontally mounted. From what I can see, the power connector and the magnets are the only "things" holding the processor in the base. I'll have to come up with a way to secure the processor in the base so it doesn't vibrate out.
-Greg
Ok...Let's try this again https://www.ez-robot.com/emicons/emo_smile.gif
#17
Ok Figured out how up load video of "Shake Test"
@Justin, Just a quick thought, use the power from one of the servo power pins to power a relay. The relay when engaged passes power to the rest of the robot. If the EZB comes off the base the relay disengages and no power to the bot.
#19
Yep... that's one way of handling it. -Greg
#20
My electronics knowledge is limited, but I think when this has been discussed before the conclusion was that you also need a pull down resister to the relay. That way if the EZ-B loses communication but still has power, and the pins float, the signal will be pulled low and release the relay.
Someone please correct me if I have this mixed up.
Is there a bit from the EZB that will toggle in a "loss of comms" event? That way external hardware could trigger an alarm and do a graceful shutdown -Greg
#23
I have been searching (unsuccessfully because I can't seem to properly narrow down the search terms) for previous discussions about this. I did find a post from DJ that says all ports will go low when the EZ-B loses connection, but I have definitely seen other discussions where ports floated and might not be seen as low by a connected device. Not sure what the actual current status is since most of those conversations predate the V4/2.
Perhaps some experimentation is called for... Empirical data always beats documentation anyway.
I agree with you Alan. If it's true that all ports go low or float with a comm loss...then you could set a bit with a pull-down on it, high while running. Monitor the bit externally and trigger an alarm when low...is it that easy or am I missing something? Greg
