Virtual Reality Robot icon Virtual Reality Robot — Stream robot camera to VR and control servos with headset pitch/yaw; supports SteamVR and Cardboard (iOS/Android) for immersive teleoperation Try it →
Italy
Using Pin 38 On Arduino Mega
Hi, i'm working on a robot called spotmicro (you can find it on thingiverse), i'm using arduino mega2560 and i'm not sure how to use pin 38 of my arduino, using ARC. I have selected virtual pin 38, but it doesn't work. Could you tell me please how to use ALL my arduino pins with ARC? Thanks
That's a good question - the software supports up to 25 digital ports, and the virtual ports are for optional extended hardware. I believe the solution is for us to look into adding a larger range of digital ports for ARC.
In the meantime, unfortunately ARC will only provide access to the first 25 pins of the arduino mega. I do have a few suggestions to help you access those ports in the meantime - are you interested in trying some alternate solutions?
