Hello everyone,
Im using the HC-SR04 , works well but when using the Radar it detects then bot move back and just keeps doing circles. I tried all different settings. The sensor is fixed not on a servo. What do you recommend?
Thank you all
Custom Movement Panel
— Custom Movement Panel maps directional commands to scripts, adjusts per-wheel speed (0-255), and integrates with joysticks for unsupported motors
Hello everyone,
Thank you all
hi sproket
these are my settings for using only forwart detection . maybe this helps .
i use the original sensor from ez robot . one cable wire . i dont use the sero port .hey jedi
i made a simpel script to detect forwart motion .
controlCommand("Ultrasonic Radar Scan", "PauseOff") sleep(300) ping_wait(d22,d22,lower,20) sleep(300) controlCommand("Auto Position", "AutoPositionAction", "Wow") sleep(1000) controlCommand("Auto Position", "AutoPositionAction", "Stand") sleep(300) sayezb(" stop that please ")
I remember when I tried to do a proximity sensor setup with my Six Hexapod, it would always get stuck at a wall.
Nomad 6R I will check it out. Thanks man.
Stop it please, love it
Scripting seems the way to go on this for sure.
hi winterU
did you use the same sensor as in this topic ? if yes were did you placed the sensor ? ontop the six dome ?if yes you have to calculate that in your settings . cause you need to ad the distants from the dome to the front of the legs , before the sensor need to detect something .
hi jedi
if you want it in a loop . see picture .
use your own ports in the script .some more actions to test .
Yes loop
I was diving into that a little this morning
jedi
always make a small sleep(300) between motions to be sure they work . sleep(300) give time for the next motion to come when the previous is done . the longer a motion last the higher the sleep needs to be . sleep(1000) is one second. but you problably know this allreddy .
