Sphero Movement Panel icon Sphero Movement Panel — Control Sphero via Bluetooth in ARC. Detects two COM ports (one connects); requires deleting and re-pairing after disconnects or reboots. Try it →
Ultrasonic Radar Panel Bot keeps doing circles
Ultrasonic Radar Panel Bot Keeps Doing Circles
Hello everyone,
Im using the HC-SR04 , works well but when using the Radar it detects then bot move back and just keeps doing circles. I tried all different settings. The sensor is fixed not on a servo. What do you recommend?
Thank you all
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
Ultrasonic Radar by Synthiam
Ultrasonic on a servo sweeps 180°; radar shows distances and obstacles, integrates with movement panels for automatic avoidance, scriptable GetPing
Stops robot movement (no steering) when an EZB-connected ultrasonic sensor detects an object within a set range; integrates with scripting and paused polling.
Dual Hbridge by Synthiam
Two-channel Dual H-Bridge movement panel to control two DC motors (on/off) for forward, reverse, left, right via EZ-B digital ports; no PWM speed.
#1   — Edited
hi sproket
are you using a script  or just the radar panel ?
hi
what happens when you check the box "only scan forwart " ?
#6   — Edited
It jerks left and right moving closer to the target with only scan fwd. But doesnt do circles.
Thats with No reverse before turn
With reverse before turn enabled it detects and jerks left to right backing up some then spins.
there's another checkbox on the right for distants . you can try lower the number by half and see what happens.
#8   — Edited
Same thing is going on.
I can try another sensor.
If I scrip it pings are solid-
while(true){
var x = Ping.get(D6, D7); print(x); sleep(500);
Tested regulator 5v true with meter.
