Some info for anyone that would like to setup web access haven't actually tested the response of the EZB this simply outlines how I set it up and tested connection.
- setup EZB as Wi-Fi Client and leave powered up
2.Identify your EZB ip address and port ( this can be found from your dhcp client list on your router)
- Open port forwarding on router and add port of EZB ( in my case that was "23" )
4.To test you can access the EZB from web go to https://www.mynetworktest.com/ports.php
take note of your public ip address top right of mynetworktest page
scroll down page to " Test Custom Port"
enter you public IP address and EZB port & click Submit
It will tell you if port is open & Your EZB will give its welcoming jingle also
:P
Pat
