Synbot Plugin icon Synbot Plugin — Synbot plugin for ARC: local Bot Server chatbot integration with SIML dialogs, ControlCommand API, multi-language, learning and emotion support. Try it →
Twitter
Resolved Resolved by fxrtst!
Servos for robot dog
Servos For Robot Dog
Anyone building a robot dog? I am looking for Servo's to build one that will work with ARC...
Servo Speed by Synthiam
Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved.
Twitter
#105
FYI new extended feature launch tomorrow.  https://www.youtube.com/watch?v=WvTdNwyADZc&feature=youtu.be
I have been looking at the API and the ROS integration with Spot and I think a ARC plugin could be written fairly easily to provide some basic functionality.  Also SPOT has a sensor platform where you can add OEM sensors (Lidar, Robot Arms etc) so ARC would provide a lot of value.
So who has $75,000.
#106
Adding a few more bearings and now also a second encoder per joint... I need to do a testing rig, but it is looking pretty good so far!:)
#108
These guys managed to get very precise with their Cyclodials...
#109
...now all we have to do is line up for a Markforge...heheheh (Onyx 1 is $4500 and the Onyx 2 is $10,000) Wonder how much a roll of carbon fiber filament costs?
#110
Its a bit more expensive than ordinary filament and you need a hardened steel nozzle...there is no magic to it, any ordinary printer can print this! Its just a bit pricey for prototyping that's all!:)
#111   — Edited
How about another controller...this one called the Dizzy..controls BLDC motors like servos with 180 degrees.....
https://www.dizzy.ai/
#112   — Edited
That is a VERY good find!!! The controller is only 35$ and it looks pretty amazing...with the encoder build in an hollow shaft being supported by design!! I am following the guy on YouTube but never realized, he is also selling products!!
Great...this could help to reduce the per joint cost! Quads are getting exponentially expensive...just way to much joints!!:p
