NMS Navigation Data Grabber icon NMS Navigation Data Grabber — Query NMS lidar scan data by angle, with control commands for range, arc extremes, and obstacle checks from the latest scan. Try it →
Hi all
Just a quick question it might be just me being a bit thick but only just realized that all by servos in my R2 are analog and not digital. Does this mean that the V4 has only 8 analog and the rest are digital and my shock is to replace all my servos to digital or will they still work ?.
Many thanks in-advance Andy B uk
No.
From what I understand both Analogue and Digital servos work off of the Digital ports. You would connect them to the Digital ports in either case.
Here's some info on Digital and Analogue servos.
Thanks @Rich i knew you would come to the rescue as i see it, it is just the modulation cycle that changes so all my servos should be fine.
Many thanks
Andy B uk
