Resolved Resolved by Athena!
RGB Lighting Remote Control Issue
Hi everyone,
I have a question regarding the use of a remote control with RGB lighting. When using the remote, the RGB lights are not turning on. Perhaps the setup isn't intended for this purpose, but I'm unsure. My goal is to enhance the "battle flipper" with a victory tune accompanied by flashing RGB lights.
I have included a short video for further explanation: Watch Video.
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
Adds IR sensor support and button mapping for USB joysticks in ARC, enabling remote control functions; third-party hardware supported.
RGB 8X8 Animator by Synthiam
Create, edit and play animated frames on an RGB 8x8 LED matrix via I2C with looping, adjustable pauses and scriptable EZ-Script canvas control.
That's fantastic news, Nomad_6R! Congratulations on getting your victory tune and flashing RGB animation working perfectly together on your Battleflipper!
I'm glad that tweaking the sound resolved the error and now you can both see and hear your victory celebration in sync. Great job!
If you have any more questions or need further assistance customizing your skills, feel free to ask. Happy robot building!
Keep up the awesome work!
Great question, Nomad_6R!
Most IR remotes that follow standard protocols like RC-5 should work in ARC when paired with the BV4615 RC-5 IR Decoder skill. Based on the link you provided, here are some key points to consider:
  1. Protocol Compatibility:
    Verify that the remote from AliExpress uses the RC-5 protocol (or another compatible IR protocol supported by ARC).
    Many remotes on sites like AliExpress are clones that support standard protocols, but it’s best to check the product description or documentation.
  2. Skill Configuration:
    In ARC, the BV4615 RC-5 IR Decoder skill is designed to decode incoming RC-5 signals.
    When you set it up, you can assign each button’s code to a specific action. If your remote sends signals according to the RC-5 standard, the buttons should be recognized easily.
  3. Testing and Mapping:
    Once you have the remote, test it with your BV4615 skill by pressing buttons and verifying the received signals in ARC’s debug output.
    Use the "Learn" feature if available in the skill to map your remote’s buttons to specific actions.
  4. Remote Range and Responsiveness:
    As with any IR remote, make sure the remote’s range and angle of operation suit your robot’s use-case.
    Environmental factors like lighting may affect IR performance.
If the remote follows the RC-5 standard, you should be able to integrate it into ARC without any major issues. Let me know if you have any further questions or need assistance configuring the BV4615 skill. Happy robot building and battling!
That's a great find, Nomad_6R! Many of these inexpensive remotes available on AliExpress work surprisingly well. Here are a few things to keep in mind:
    Make sure the remote uses the RC-5 protocol or another protocol supported by the BV4615 RC-5 IR Decoder skill in ARC. Check the product description or any available documentation to confirm the protocols supported.
  2. Testing the Remote:
    Once received, you can use the BV4615 RC-5 IR Decoder skill in ARC to "learn" the button codes. This allows you to map each button on the remote to a specific function or skill action in your project.
  3. Build Your Setup:
    If the remote transmits in the RC-5 protocol, it should integrate seamlessly with your ARC project. Trigger your actions using the ControlCommand function within ARC, and you should be good to go.
  4. Additional Tips:
    • Verify the range and angle of the IR sensor on your robot during testing.
    • Ensure ambient lighting or other reflective surfaces aren't interfering with the IR signals.
These remotes can work beautifully in ARC setups as long as the IR signal protocol matches what the BV4615 skill expects. Let me know if you decide to try this remote or if you run into any issues during setup. Happy robot building!
