EZ Chart icon EZ Chart — 4-series bar chart for real-time sensor comparison in ARC; set titles, values, RGB bar colors and conditional coloring via EZ-Script. Try it →
Russia
Question With Video On Bookstone Rover
hi.
I have problem with video from rover camera in ARC. Sorry for bad English, it is not my native language.
First, all was ok. I've connected to robot from EZB, picture was ok, and I ran the robot by office about 10-20 minutes.
Then, after reconnect i saw black screen instead of picture. Motion controls still work fine. I tried to reinstall EZB, reset the robot, tried on another pc - nothing helps. On iphone everything is ok. Even the python script, that grabs jpeg from camera works fine.
I watched traffic between EZB and robot - it seems, that robot sends its video stream, but EZB shows only black screen.
Help me! thanks:)
please help me stress
Hi
Thanks I read all the tuto, yes it's true eek but I didn't find the answer
How to connect my rover to my WIFI network ( not to my computer through wifi )
Thanks per advance for your HELP :D
Please watch the video on the tutorial page.
I saw also de video stress but i didn't find HELP me blush
I'm now solving the same problem. It is not possible with standart instruments. The solution is to download firmware through com port on bottom of rover (under cover, near to the reset button). Unpack it, change config files and upload it back.
some info here https://www.openipcam.com/forum/index.php/topic,261.0.html
@groniki Hello and welcome. I have been watching your posts and think I understand better what you wish to do. The link between the Rover and the ARC is an ad-hoc network... I believe... (as is its normal routine, only with iPhones/iPads/etc). It looks like what you are trying to do is tie your rover into an infrastructure network, then from there to the ARC. Unfortunately, I think the solution is outside the scope of this forum as you may be the first (here) to try this. If anyone out there knows better, then please correct me, lest I lead someone astray:P
It looks like @robot468 has the idea of looking into other sites that deal with the hacking of the Rover itself... which seems to be the root of the issue, not with DJ's ad-hoc tie-in with ARC.
Of course once you figure it out, please do share the solution with this forum so that it might help the next person who asks:) That way these off-the-scope hacks start to mesh with the whole EZ-Robot concept.
#16
Hi Gunner You are understand 100% It's simple, I just want to remote through internet my Rover sick I think the first step is to connect my rover to my infrastructure wifi network. I understand that the rover firmware can only connect with ad-hoc network. Is there a firmware for infrastructure wifi connection ? stress stress
