Omron HVC-P2 icon Omron HVC-P2 — Omron HVC-P/HVC-P2 ARC plugin: Python-based camera integration for body, hand and face detection, gaze, age/gender, expressions and face recognition. Try it →
Ping Roam V1.1.0
Ping Roam V1.1.0
V1.1.2 available on page 3
Taking on board some of the comments made recently regarding autonomous roaming, plus a few improvements I wanted to make I have updated the Ping Roam script (which if I knew it would be so popular I would have made more of an effort the first time around).
I've done some quick testing with it however my testbot runs on 4 modified servos with wheels on which isn't the best method of driving it so it may still have some bugs in... that's where you come in:) Let me know if there are any bugs, anything that doesn't work quite like it should, any further improvements you want...
I did have a bug in the escape routine, which I think I have now solved. Where it has a loop in the routine to continue turning until the sensor reading is above the setpoint I think that was throwing off the return at the end of the routine, not returning to where it came from but returning to when it was told to loop. Solved with additional labels and it seems to be working now...
Changes
Boxed In check added
Escape from Boxed In added
Avoidance of left/right/left/right loops
Automatic calculation of sweep servo center position
Tidied up code
More comments added
Almost completely made with labels and gotos
And, here is the code
# Ping Object Avoidance
# Using Ultra Sonic Ping Sensor on servo for avoidance
# Version 1.1.0
# Configuration Settings
# Adjust values below for port configuration
$pingport = D0 # Change for Ping Port
$echoport = D1 # Change for Echo Port
$sweepservo = D2 # Change for sweep servo port
# Adjust values below for movement control
$reverseturn = 1 # Reverse before turn? 0 = no, 1 = yes
$maxdistance = 30 # Change for maximum distance from object before avoiding in units
$boxedindistance = 20 # Change for maximum distance for boxed in detection
$turnamount = 500 # Change for how long to turn for in ms
$reverseamount = 500 # Change for how long to reverse for in ms (if applicable)
$movementspeed = 255 # Change for movement speed
$slowturn = 127 # Change for slow turn speed
# Adjust values below for sweep configuration
$sweepmin = 10 # Change for min limit
$sweepmax = 90 # Change for max limit
$sweepservodelay = 500 # Change for delay between sweep servo movements and readings
# Testing Options
$testmode = 0 # Change to 1 if testing without PING sensor
# Do not adjust these values
$sweepcenter = $sweepmin+$sweepmax
$sweepcenter = $sweepcenter/2
$sweepcenter = Round($sweepcenter,0)
$sweepprevious = $sweepmax # Do not change
$sweepcurrent = $sweepcenter # Do not change
$SweepErrorFlag = 0 # Do not change
$BoxedInErrorFlag = 0 # Do not change
$BoxedInRun = 0 # Do not change
$SweepCenterRun = 0 # Do not change
$EscapeRun = 0 # Do not change
$ScriptErrorFlag = 0 # Do not change
$isboxedin = 0 # Do not change
$penultimatemove = "none"
$lastmove = "none"
# ------- The Script --------
# Set the start point for any loops
:begin
# Center the sweep servo
Servo($sweepservo, $sweepcenter)
# Start moving forwards
FORWARD()
# Start the detection
Goto(detect) # This line is redundant
# Detection code
# Set a label for loops and gotos
:detect
# Use random numbers if in test mode
IF ($testmode=0)
  $currentdistance = GetPing($pingport, $echoport)
ELSE
  $currentdistance = GetRandom(0,255)
ENDIF
  # Check the current distance against the max allowed distance
IF ($currentdistance <= $maxdistance)
  # If the current distance is below the max distance start avoiding
  GOTO(avoid)
  # Set label for avoid return to avoid return errors
  :avoidreturn
ENDIF
  # Run the sweeping servo code
GOTO(sweep)
# Wait
SLEEP ($sweepservodelay)
# Loop back to the start of detection
GOTO(detect)
# Avoidance code
:avoid
# First check if boxed in
Goto(boxedin)
# If the robot is boxed in run the escape code
IF ($isboxedin = 1)
  Goto(escape)
  # Avoid return error after escape loop by setting a label for a goto
  :escapereturn
ENDIF
  # Check to see if to reverse before turning
IF ($reverseturn = 1)
  # If the option of reverse before turning is set reverse
  Reverse($movementspeed,$reverseamount)
ENDIF
  # Check the servo position
  # Check if it's to the left
IF ($sweepcurrent = $sweepmin)
  # If the servo is in the lowst position (left) move right
  Goto(moveright)
  # Continue moving forwards
  FORWARD()
  # Else check if it's to the right
ELSEIF ($sweepcurrent = $sweepmax)
  # If the servo is in the highest position (right) move left
  Goto(moveleft)
  FORWARD()
  # Else assume it's in the middle
ELSE
  # If the servo is in the center position check which side is closest to the object and move the other way
  # Move and check the left side
  Servo($sweepservo,$sweepmin)
  IF ($testmode=0)
    $pingmin = GetPing($pingport, $echoport)
  ELSE
    $pingmin = GetRandom(0,255)
  ENDIF
    # Wait
  Sleep(400)
  # Move and check the right side
  Servo($sweepservo,$sweepmax)
  IF ($testmode=0)
    $pingmax = GetPing($pingport, $echoport)
  ELSE
    $pingmax = GetRandom(0,255)
  ENDIF
    # Wait
  Sleep(400)
  # Move and check the center
  Servo($sweepservo,$sweepcenter)
  IF ($pingmin > $pingmax)
    Goto(moveright)
    FORWARD()
  ELSE
    Goto(moveleft)
    FORWARD()
  ENDIF
ENDIF
  # Return to the main code
Goto(avoidreturn)
# The sweep code
:sweep
# Move in the correct direction and store previous position
# Check what the current position is
# Check if left
  # Save the current position as the previous
  $sweepprevious = $sweepcurrent
  # Move to the next position
  $sweepcurrent = GetServo($sweepservo)
  # Else check if its center and where it was before
  # If it is center and was left before
ELSEIF ($sweepcurrent = $sweepcenter and $sweepprevious = $sweepmin)
  Servo($sweepservo, $sweepmax)
  # If it is center and was right before
ELSEIF ($sweepcurrent = $sweepcenter and $sweepprevious = $sweepmax)
  Servo($sweepservo, $sweepmin)
  # Else check if right
  # Else something has gone wrong
ELSE
  # Set an error flag for debugging purposes
  $SweepErrorFlag = 1
ENDIF
  # Return back to the main script
Return()
# The sweep center code
:sweepcenter
# Set a flag so we know it has run for debugging purposes
$SweepCenterRun = 1
# Move the servo to the left position
IF ($testmode=0)
ELSE
ENDIF
# Wait
Sleep(200)
# Move the servo to the right
IF ($testmode=0)
ELSE
ENDIF
# Wait
Sleep(200)
# Move the servo back to the center
# Check which side has the closest object
# If the object to the left is further away than the object to the right
  # Move to the right
  RIGHT($movementspeed,$turnamount)
  # Move forwards again
  FORWARD()
  # Else if the object to the right is further away than the object to the left
ELSEIF ($pingmin < $pingmax)
  # Move to the left
  LEFT($movementspeed,$turnamount)
  FORWARD()
  # Else they are both the same
ELSE
  # So move left - this can be customised
  # And move forwards again
  FORWARD()
ENDIF
  # Retyrn to the main code
Return()
# The boxed in code
:boxedin
$BoxedInRun = 1
# Get distance to the side
IF ($testmode=0)
  $side1scan = GetPing($pingport,$echoport)
ELSE
  $side1scan = GetRandom(0,255)
ENDIF
  # Get distance to the other side
IF ($testmode=0)
  $side2scan = GetPing($pingport,$echoport)
ELSE
  $side2scan = GetRandom(0,255)
ENDIF
  # Get distance to the front
  # Move the servo to the center
IF ($testmode=0)
  $centerscan = GetPing($pingport,$echoport)
ELSE
  $centerscan = GetRandom(0,255)
ENDIF
  # Check if boxed in by compairing the results against a fixed boxed in distance
IF ($side1scan < $boxedindistance and $side2scan < $boxedindistance and $centerscan < $boxedindistance)
  # If any are true set the boxed in flag
  $isboxedin = 1
ENDIF
  # Return to the main script
Return()
# The escape code
:escape
$EscapeRun = 1
# Reset the boxed in flag
$isboxedin = 0
# Turn slowly
Left($slowturn)
# Set up a loop
:escapeloop
# Scan until clear
IF ($testmode=0)
  $escapescan = GetPing($pingport,$echoport)
ELSE
  $escapescan = GetRandom(0,255)
ENDIF
  # If the scan result is below the boxed in distance loop
IF ($escapescan < $BoxedInDistance)
  # Go back to the start of the escape loop
  Goto(escapeloop)
ENDIF
  # Continue forwards
FORWARD()
Goto(escapereturn)
# Move Right code
:moveright
# Check the last 2 moves to avoid left right left right loops
IF ($lastmove = "left" and $penultimatemove = "right")
  # If it has been right then left dont move right again but escape from a loop
  Goto(escape)
  # Reset the last move
  $lastmove = "none"
  # Else just move right
ELSE
  # Save the penultimate move
  $penultimatemove = $lastmove
  # Save the last move
  $lastmove = "right"
ENDIF
  # Go back to the main script
Return()
# Move left code
:moveleft
IF ($lastmove = "right" and $penultimatemove = "left")
  # If it has been left then right dont move left afain but escape from a loop
  Goto(escape)
  $lastmove = "none"
  # Else just move left
ELSE
  $lastmove= "left"
ENDIF
Return()
# End of scripts
It's also on the cloud PingAvoidanceV1.1.0
And for ease of copying and pasting (in case the forums decide to add in some emoticons) it's also on pastebin
Any and all feedback is greatly appreciated no matter how trivial. Feel free to make your own improvements and modifications (let me know what they are too - believe it or not I'm still learning too).
#33
Great Script, just gave it a try, ran perfectly. I really like the servo Sweep,
right, center, left, center, right center, and so forth. Would you mind if I trouble you for more scripts?
#34
Give me ideas and I'll give it a go:) I welcome any ideas, or even challenges:D Provided I have a robot that can run it (although not necessarily required, I wrote Ping Roam without a robot).
I just ran it, my sweep servo moved the other way to what I had thought it did so I needed to make code changes (very simple, just change MoveLeft and MoveRight labels around should do it - I did it the long way since I was trying to video it) but once they were made it ran almost perfectly (ping sensor isn't the best, neither is the sweep in my opinion).
Video of it on Jarvis Mk 0.25 coming when I get chance to edit it and stuff. I'll leave the crashes in to demonstrate the drawbacks to this method too though.
#35
I'm too tired, too hungry and too hot to mess around video editing on a PC that's as unstable as Jenga.
It's still uploading and processing as I write this but keep checking back if it says unavailable as it will eventually become available.
I give you Ping Roam V1.1.2
You can see the problems with ultrasonic sensors (I think mine is playing up a little) and the accuracy when using a sweeping servo over multiple sensors. But it works:)
#36
Can you do a simple script that drive around in circle or box, square with an infinity loop? Would like to test my battery longevity.
#37
:start
Forward()
Sleep(3000)
Left()
Sleep(500)
Goto(start)
That should move forwards for 3 seconds, turn left (you may need to adjust the 500 to suit your turn time), forwards, left etc.
Alternately, just hit left or right on the Movement Panel and watch it spin:)
#38
@Rich, how many sensors do you have operating on this robot for navigation? Is it just one with a servo to sweep?
Thanks,
mel
#39
1 sensor, 1 servo to sweep it.
Personally I find it's not the best way to do things as there are blind spots and bumps still happen but if you are short on space or free ports then it does a good enough job.
#40
I think I will have mine stationary. But, this would change the script dramatically. I plan to put two sonars in front and two IR units also. I used to have front,back,left,right, upper,lower,sonar,IR,PIR. It just slows down the operation. I like your idea of having fewer ones.
