Myo Gesture Armband icon Myo Gesture Armband — Map Myo armband gestures and accelerometer to servos and ARC scripts for arm-mimic control; supports multiple armbands. Try it →
Ping Roam V1.1.0
Ping Roam V1.1.0
V1.1.2 available on page 3
Taking on board some of the comments made recently regarding autonomous roaming, plus a few improvements I wanted to make I have updated the Ping Roam script (which if I knew it would be so popular I would have made more of an effort the first time around).
I've done some quick testing with it however my testbot runs on 4 modified servos with wheels on which isn't the best method of driving it so it may still have some bugs in... that's where you come in:) Let me know if there are any bugs, anything that doesn't work quite like it should, any further improvements you want...
I did have a bug in the escape routine, which I think I have now solved. Where it has a loop in the routine to continue turning until the sensor reading is above the setpoint I think that was throwing off the return at the end of the routine, not returning to where it came from but returning to when it was told to loop. Solved with additional labels and it seems to be working now...
Changes
Boxed In check added
Escape from Boxed In added
Avoidance of left/right/left/right loops
Automatic calculation of sweep servo center position
Tidied up code
More comments added
Almost completely made with labels and gotos
And, here is the code
# Ping Object Avoidance
# Using Ultra Sonic Ping Sensor on servo for avoidance
# Version 1.1.0
# Configuration Settings
# Adjust values below for port configuration
$pingport = D0 # Change for Ping Port
$echoport = D1 # Change for Echo Port
$sweepservo = D2 # Change for sweep servo port
# Adjust values below for movement control
$reverseturn = 1 # Reverse before turn? 0 = no, 1 = yes
$maxdistance = 30 # Change for maximum distance from object before avoiding in units
$boxedindistance = 20 # Change for maximum distance for boxed in detection
$turnamount = 500 # Change for how long to turn for in ms
$reverseamount = 500 # Change for how long to reverse for in ms (if applicable)
$movementspeed = 255 # Change for movement speed
$slowturn = 127 # Change for slow turn speed
# Adjust values below for sweep configuration
$sweepmin = 10 # Change for min limit
$sweepmax = 90 # Change for max limit
$sweepservodelay = 500 # Change for delay between sweep servo movements and readings
# Testing Options
$testmode = 0 # Change to 1 if testing without PING sensor
# Do not adjust these values
$sweepcenter = $sweepmin+$sweepmax
$sweepcenter = $sweepcenter/2
$sweepcenter = Round($sweepcenter,0)
$sweepprevious = $sweepmax # Do not change
$sweepcurrent = $sweepcenter # Do not change
$SweepErrorFlag = 0 # Do not change
$BoxedInErrorFlag = 0 # Do not change
$BoxedInRun = 0 # Do not change
$SweepCenterRun = 0 # Do not change
$EscapeRun = 0 # Do not change
$ScriptErrorFlag = 0 # Do not change
$isboxedin = 0 # Do not change
$penultimatemove = "none"
$lastmove = "none"
# ------- The Script --------
# Set the start point for any loops
:begin
# Center the sweep servo
Servo($sweepservo, $sweepcenter)
# Start moving forwards
FORWARD()
# Start the detection
Goto(detect) # This line is redundant
# Detection code
# Set a label for loops and gotos
:detect
# Use random numbers if in test mode
IF ($testmode=0)
  $currentdistance = GetPing($pingport, $echoport)
ELSE
  $currentdistance = GetRandom(0,255)
ENDIF
  # Check the current distance against the max allowed distance
IF ($currentdistance <= $maxdistance)
  # If the current distance is below the max distance start avoiding
  GOTO(avoid)
  # Set label for avoid return to avoid return errors
  :avoidreturn
ENDIF
  # Run the sweeping servo code
GOTO(sweep)
# Wait
SLEEP ($sweepservodelay)
# Loop back to the start of detection
GOTO(detect)
# Avoidance code
:avoid
# First check if boxed in
Goto(boxedin)
# If the robot is boxed in run the escape code
IF ($isboxedin = 1)
  Goto(escape)
  # Avoid return error after escape loop by setting a label for a goto
  :escapereturn
ENDIF
  # Check to see if to reverse before turning
IF ($reverseturn = 1)
  # If the option of reverse before turning is set reverse
  Reverse($movementspeed,$reverseamount)
ENDIF
  # Check the servo position
  # Check if it's to the left
IF ($sweepcurrent = $sweepmin)
  # If the servo is in the lowst position (left) move right
  Goto(moveright)
  # Continue moving forwards
  FORWARD()
  # Else check if it's to the right
ELSEIF ($sweepcurrent = $sweepmax)
  # If the servo is in the highest position (right) move left
  Goto(moveleft)
  FORWARD()
  # Else assume it's in the middle
ELSE
  # If the servo is in the center position check which side is closest to the object and move the other way
  # Move and check the left side
  Servo($sweepservo,$sweepmin)
  IF ($testmode=0)
    $pingmin = GetPing($pingport, $echoport)
  ELSE
    $pingmin = GetRandom(0,255)
  ENDIF
    # Wait
  Sleep(400)
  # Move and check the right side
  Servo($sweepservo,$sweepmax)
  IF ($testmode=0)
    $pingmax = GetPing($pingport, $echoport)
  ELSE
    $pingmax = GetRandom(0,255)
  ENDIF
    # Wait
  Sleep(400)
  # Move and check the center
  Servo($sweepservo,$sweepcenter)
  IF ($pingmin > $pingmax)
    Goto(moveright)
    FORWARD()
  ELSE
    Goto(moveleft)
    FORWARD()
  ENDIF
ENDIF
  # Return to the main code
Goto(avoidreturn)
# The sweep code
:sweep
# Move in the correct direction and store previous position
# Check what the current position is
# Check if left
  # Save the current position as the previous
  $sweepprevious = $sweepcurrent
  # Move to the next position
  $sweepcurrent = GetServo($sweepservo)
  # Else check if its center and where it was before
  # If it is center and was left before
ELSEIF ($sweepcurrent = $sweepcenter and $sweepprevious = $sweepmin)
  Servo($sweepservo, $sweepmax)
  # If it is center and was right before
ELSEIF ($sweepcurrent = $sweepcenter and $sweepprevious = $sweepmax)
  Servo($sweepservo, $sweepmin)
  # Else check if right
  # Else something has gone wrong
ELSE
  # Set an error flag for debugging purposes
  $SweepErrorFlag = 1
ENDIF
  # Return back to the main script
Return()
# The sweep center code
:sweepcenter
# Set a flag so we know it has run for debugging purposes
$SweepCenterRun = 1
# Move the servo to the left position
IF ($testmode=0)
ELSE
ENDIF
# Wait
Sleep(200)
# Move the servo to the right
IF ($testmode=0)
ELSE
ENDIF
# Wait
Sleep(200)
# Move the servo back to the center
# Check which side has the closest object
# If the object to the left is further away than the object to the right
  # Move to the right
  RIGHT($movementspeed,$turnamount)
  # Move forwards again
  FORWARD()
  # Else if the object to the right is further away than the object to the left
ELSEIF ($pingmin < $pingmax)
  # Move to the left
  LEFT($movementspeed,$turnamount)
  FORWARD()
  # Else they are both the same
ELSE
  # So move left - this can be customised
  # And move forwards again
  FORWARD()
ENDIF
  # Retyrn to the main code
Return()
# The boxed in code
:boxedin
$BoxedInRun = 1
# Get distance to the side
IF ($testmode=0)
  $side1scan = GetPing($pingport,$echoport)
ELSE
  $side1scan = GetRandom(0,255)
ENDIF
  # Get distance to the other side
IF ($testmode=0)
  $side2scan = GetPing($pingport,$echoport)
ELSE
  $side2scan = GetRandom(0,255)
ENDIF
  # Get distance to the front
  # Move the servo to the center
IF ($testmode=0)
  $centerscan = GetPing($pingport,$echoport)
ELSE
  $centerscan = GetRandom(0,255)
ENDIF
  # Check if boxed in by compairing the results against a fixed boxed in distance
IF ($side1scan < $boxedindistance and $side2scan < $boxedindistance and $centerscan < $boxedindistance)
  # If any are true set the boxed in flag
  $isboxedin = 1
ENDIF
  # Return to the main script
Return()
# The escape code
:escape
$EscapeRun = 1
# Reset the boxed in flag
$isboxedin = 0
# Turn slowly
Left($slowturn)
# Set up a loop
:escapeloop
# Scan until clear
IF ($testmode=0)
  $escapescan = GetPing($pingport,$echoport)
ELSE
  $escapescan = GetRandom(0,255)
ENDIF
  # If the scan result is below the boxed in distance loop
IF ($escapescan < $BoxedInDistance)
  # Go back to the start of the escape loop
  Goto(escapeloop)
ENDIF
  # Continue forwards
FORWARD()
Goto(escapereturn)
# Move Right code
:moveright
# Check the last 2 moves to avoid left right left right loops
IF ($lastmove = "left" and $penultimatemove = "right")
  # If it has been right then left dont move right again but escape from a loop
  Goto(escape)
  # Reset the last move
  $lastmove = "none"
  # Else just move right
ELSE
  # Save the penultimate move
  $penultimatemove = $lastmove
  # Save the last move
  $lastmove = "right"
ENDIF
  # Go back to the main script
Return()
# Move left code
:moveleft
IF ($lastmove = "right" and $penultimatemove = "left")
  # If it has been left then right dont move left afain but escape from a loop
  Goto(escape)
  $lastmove = "none"
  # Else just move left
ELSE
  $lastmove= "left"
ENDIF
Return()
# End of scripts
It's also on the cloud PingAvoidanceV1.1.0
And for ease of copying and pasting (in case the forums decide to add in some emoticons) it's also on pastebin
Any and all feedback is greatly appreciated no matter how trivial. Feel free to make your own improvements and modifications (let me know what they are too - believe it or not I'm still learning too).
ahh glad its not just me,
Just thought I could show you on Skype what your project does with my bot.
Email?
#19
I forgot to mention that v1.1.1 is on the cloud.
A couple of changes so far (although still working on it when I find the time);
  1. Modified code so it doesn't reverse after escaping from boxing in or avoiding a left/right/left/right loop.
  2. Added in a stop and a sleep before all forward and reverse movements.
  3. Added an emergency stop script which stops the roam script and stops any movement that's currently happening.
I just ran it again to check it out and had no errors this time. I suspect it may have been down to the computer running slowly when I last tried it, but also sounds like low battery levels and inaccurate ping readings may also cause strange behaviour. I'm thinking of ways around that, something like taking 3 readings each time rather than 1, and using ands in the ifs to only be true if all 3 readings are below the threshold... but I've not had chance to do that yet.
#20
The inspiration needed to complete version 1.1.2 of the Ping Roam script came tonight.
Changes
  1. Changed escape return to use else therefore avoiding reversing and turning after an escape.
  2. Added in stop and sleep before any forward or reverse movements.
  3. Added emergency stop script.
  4. All ports are now constants, use ports specified in the head of the code or port summary or adjust the code to suit your ports.
Plenty of comments so you can follow and customise the script where necessary.
# Version 1.1.2
# This script assumes the following ports;
# Trig Port = D0
# Echo Port = D1
# Sweep servo = D2
# Testing Options
# Calculate the centre position for the sweeping servo
# Minimum position plus maximum position divided by 2
# Round to 0 decimal places
$sweepcenter = Round((($sweepmin+$sweepmax)/2),0)
# Set the previous position to the max position for initial movement
# Set the current position to the centre position for initial movement
# Set some flags for testing - to be removed in final release
# Set last and penultimate moves.
$lastmove = "none"
:begin
Servo(D2, $sweepcenter)
FORWARD()
Goto(detect) # This line is redundant but left for educational purposes
# Detection code
:detect
# Use random numbers if in test mode - to be removed in final release
IF ($testmode=0)
  $currentdistance = GetPing(D0, D1)
ELSE
ENDIF
  GOTO(avoid)
  :avoidreturn
ENDIF
GOTO(sweep)
# Wait
GOTO(detect)
# Avoidance code
:avoid
Goto(boxedin)
IF ($isboxedin = 1)
  Goto(escape)
  :escapereturn
# Change to else to avoid reversing and turning after an escape - dont forget the endif at the bottom
ELSE
    # If the option of reverse before turning is set stop then reverse
    # Add in a stop and sleep before movement
    Stop()
    Sleep(200)
  ENDIF
    Goto(moveright)
    Stop()
    Sleep(200)
    FORWARD()
    Goto(moveleft)
    Stop()
    Sleep(200)
    FORWARD()
  ELSE
    Servo(D2,$sweepmin)
    IF ($testmode=0)
      $pingmin = GetPing(D0, D1)
    ELSE
    ENDIF
    # Wait
    Sleep(400)
    Servo(D2,$sweepmax)
    IF ($testmode=0)
      $pingmax = GetPing(D0, D1)
    ELSE
    ENDIF
    # Wait
    Sleep(400)
    Servo(D2,$sweepcenter)
      Goto(moveright)
      Stop()
      Sleep(200)
      FORWARD()
    ELSE
      Goto(moveleft)
      Stop()
      Sleep(200)
      FORWARD()
    ENDIF
  ENDIF
ENDIF
Goto(avoidreturn)
# The sweep code
:sweep
# Check if left
  $sweepcurrent = GetServo(D2)
  Servo(D2, $sweepmax)
  Servo(D2, $sweepmin)
ELSE
  # Set an error flag for debugging purposes - to be removed for final release
  $SweepErrorFlag = 1
ENDIF
Return()
:sweepcenter
$SweepCenterRun = 1
Servo(D2,$sweepmin)
IF ($testmode=0)
ELSE
ENDIF
# Wait
Sleep(200)
Servo(D2,$sweepmax)
IF ($testmode=0)
ELSE
ENDIF
# Wait
Sleep(200)
  # Move to the right
  Stop()
  Sleep(200)
  FORWARD()
  # Move to the left
  Stop()
  Sleep(200)
  FORWARD()
ELSE
  Stop()
  Sleep(200)
  FORWARD()
ENDIF
Return()
# The boxed in code
:boxedin
# Set a flag so we know it has run for debugging - to be removed for final release
$BoxedInRun = 1
Servo(D2,$sweepmin)
# Use random numbers if in test mode - to be removed for final release
IF ($testmode=0)
  $side1scan = GetPing(D0, D1)
ELSE
ENDIF
Servo(D2,$sweepmax)
IF ($testmode=0)
  $side2scan = GetPing(D0, D1)
ELSE
ENDIF
IF ($testmode=0)
  $centerscan = GetPing(D0, D1)
ELSE
ENDIF
  $isboxedin = 1
ENDIF
Return()
# The escape code
:escape
$EscapeRun = 1
$isboxedin = 0
# Turn slowly
Left($slowturn)
# Set up a loop
:escapeloop
# Scan until clear
IF ($testmode=0)
  $escapescan = GetPing(D0, D1)
ELSE
ENDIF
  Goto(escapeloop)
ENDIF
# Continue forwards
Stop()
Sleep(200)
FORWARD()
Goto(escapereturn)
# Move Right code
:moveright
  Goto(escape)
  $lastmove = "none"
ELSE
  Sleep(200)
  $lastmove = "right"
ENDIF
Return()
# Move left code
:moveleft
  Goto(escape)
  $lastmove = "none"
ELSE
  Sleep(200)
  $lastmove= "left"
ENDIF
Return()
# End of scripts
This script has not been real world tested - Testbot has been re-purposed to become Jarvis. As a result I am currently unable to run any real world tests on the code. I will be temporarily adding the sweeping servo and ping sensor to Jarvis as soon as I possibly can however in the mean time any comments on it's success or failure would be very much appreciated.
The project is on the EZ-Cloud under Public Library, Examples, Ping Roam V1.1.2 or you can Download here
Also available for copy and paste on pastebin here
#21
Any improvements are welcomed also. For instance, one question I often think about when I am writing this script is Would it be better written to use 3 Ping Sensors rather than a sweeping servo? What is more commonly used, Ping or IR? What do the people want it to do?
So hit it up with suggestions, requests, whatever:) I have no problem writing a bunch of these for the different methods either, I'm not afraid of a little coding!..
#22
Rich,
Can you send us a video? I would love to see how it behaves.
Very elaborate and well commented code!
Bill
#23
I will do when I have a robot that is capable of running the code (Jarvis is being temporarily repurposed but the adaptation is taking a little longer than I planned).
#24
@Rich, I'd like to try this using a modified Roomba with the Ping sensor centrally located at the front of the body. Using the two H-bridges built into the Roomba PCB. Each H-bridge has a forward and reverse PWM lead. What EZ-B control would best suit this trial ?
