Script Collection icon Script Collection — Manage and execute multiple scripts in a single Script Manager using ControlCommand(), with Control Details showing available commands. Try it →
we posted simultaneously, so you may have missed my reply which pre-answers your question. Look at post #8.
When you measured the pin voltage you probably inadvertently shorted across the pins... If you're lucky you just blew a fuse or tripped the poly fuse... I dropped a screwdriver on one of my ezb4 boards and now port 9 does not work... Be careful
Alan, That sounds great. I have some of the parts printed up already. Show me which parts you need printed.
Email me at... [email protected]
Fuse was blown. Off to autozone to get another.
@mstephens_42 .... That's good news... maybe you should get a couple, though....;)
#15
Please follow the tutorial on the developer kit - the data sheet will explain the ports, voltages and other relevant data to prevent from potentially blowing up your ezb:)
#16
DJ, Can you confirm my schematic....
I've killed two ping sensors due to my mistake trying to do this without the voltage regulator...
