How do I build a large hexapod leg / servo without breaking the bank? I want each leg to be about 2 feet long.
antguru
— Edited
Sound Script (Ezb)
— Trigger a script when EZB audio plays, exposing live Min, Max and Avg audio-level variables for looped monitoring; stops when audio ends.
Somewhat of a contradiction in terms my friend... Something that large = powerful servos = \(\)
You will need to cut the parts from syrofoam to manage that size and still use standard servos.
josh's idea is good...also consider door skin cheap and light , only a couple of 32's thick
what is door skin? I never heard of it.
I think he means buying a cheap household door. They have foam sandwiched between two pieces of very thin wood laminate. You could use a jigsaw to cut parts from it. Buuuut if you are patient we could 3d print a big one with interconnected parts and the 3d printed parts can be very light. Because of the size you are talking about it would take a few days worth of prints. The end product or would probably make a mold of for replacement parts in the future. It just depends on what you want in the end. Some people want to build something just for the experience and never even use it after its built and in that case that is cool too. So just ask yourself if you want it useful and durable later.
cant you use more exstentions? exstentions
Not exactly Josh! I ment the actual sheet of plywood about 16$ 3/32 thick
.......but with Josh's suggestion, one can get a really cool custom leg ....or whatever
I like the idea of 3d printed parts. Time is not a issue as we are waiting for our hexapod to arrive. How do I contact you? My email is [email protected]
