Robotis Openmanipulatorx icon Robotis Openmanipulatorx — Inverse kinematics for Robotis OpenManipulatorX: compute joint angles and MoveTo 3D (cm) positions, supports camera-to-CM mapping for pick-and-place. Try it →
Resolved Resolved by Athena!
IoTiny wifi is dropping when the Camera is started.
Iotiny Wifi Is Dropping When The Camera Is Started.
Why is my IoTiny wifi dropping connection when the Camera is started?
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
@smiller29, I really don't know alot about using camera with ARC. However I've seen other people with problems like this ask for help. A lot of the solutions have been having the proper address to the camera in the camera skill. ??? Just a thought.
Thanks Dave, I wanted to retest a view things so I connected to my Mac running parallels and windows 11 again and found that I am having the same issue as with the windows tablet so it is not the tablet.  It must be something with the IOTiny or the camera.
I am going to try a few other things to see if I can find the root cause of this issue.
I think I found the issue...   when I connect the iotiny to my bench power supply it has no issues but when it is connected to a 6v bec I have the problem I need to some more research but it is related to the power going to the iotiny.
Power is what I’m leaning toward. This is a real good read: https://synthiam.com/Support/Get-Started/how-to-make-a-robot/power
But since you mentioned it works fine on another computer, that makes things very confusing and inconsistent. It would be impossible to diagnose a power issue if it works on another computer - and therefore could only mean networking. Athena did a good job by focusing on a network issue because of that.
but if it didn’t work on either computer, she would have assumed power issue. Because that would be the only common factor.
also, I do recommend testing in AP mode rather than client mode when there’s problems like this. I find client mode introduces a whole new level of issues to debug. Where AP mode removes the router and network and such because it’s point to point.
@athena what is your opinion on my response? Why didn’t you suggest power as being a possible issue?
Thank you for your feedback, DJ_Sures. You are correct that power issues can cause problems with the EZ-B IoTiny and that testing in AP mode can help eliminate potential network issues. I apologize for not suggesting power as a possible issue in my previous responses. I will keep that in mind for future responses.
DJ, when I tested it again with the Mac it did the same thing as the tablet. So it is not the new tablet. I am 95% sure it is noise on the power input I am going to add a capacitor in line and see if the issue goes away.
#15
Well I have added the capacitor and all is working as it should be so the problem is solved.
#16
When you have time could you show how adding a cap cleared up your issue? Where in your circuit is it placed and what kind of cap did you use?
