XV11 LIDAR icon XV11 LIDAR — Real-time 2D mapping from Neato XV-11 360° LIDAR via GetSurreal controller; exports $LIDARDistance/$LIDARIntensity, configurable angles, color, zoom. Try it →
Insert Blank Problem
Hi DJ,
Since I installed the latest version of ARC, it is no longer possible to properly use the insert blank option in voice recognition configuration. That creates some problems since this option is essential in editing commands. Would you please help?
I tested it. Works fine. What isn't working for you?
Thanks for your reply. It is only possible to insert blank at the bottom of all the commands, not between commands. I can't get this symbol * to be between commands but only at the bottom of the window.
Hi DJ, Thank you for fixing the insert blank problem in the latest version of ARC. I deeply appreciate your hard work. I am also very impressed with your efforts to put different voices in the speech synthesis settings, I just can't wait for it to be completed!
