Sabertooth Kangaroo icon Sabertooth Kangaroo — Movement panel enabling Kangaroo & Sabertooth encoder-based speed/velocity control, UART/PC serial options, tuning and encoder setup. Try it →
Resolved Resolved by EzAng!
I/O ports not responding to the ARC UI servo control
I/O Ports Not Responding To The ARC UI Servo Control
I have an ezb v4 that has been on the shelf for several years. (worked when last used). I was on the shelf too so we are both a little dusty so bare with me. When I set up an I/O port in ARC for a servo there is no signal present on the signal pins. I have a scope on them. If i go to the diagnostics page of the ezb's web server and hit the "center all servos" button the pins come to life. I think its something simple but ...?
Horizontal Servo by Synthiam
Mouse-drag horizontal servo control with configurable min/max limits, center/release functions, multi-servo mirroring and direction invert.
from on of DJ posts
  1. Did you disable the low voltage monitor? I'm guessing you must have because the "My battery is low" on 6v would have been annoying And the servos won't move at all with power below the threshold
  2. What servos are you using at 6v? Depending on the servo, it might not be able to accept 6v and it's behaving strangely
  3. Do you have a volt meter to ensure the voltage coming from the power supply is indeed 6v? If not, you can add the EZ-B Info control to see. Check here: https://synthiam.com/Software/Manual/EZ-B-v4-Info-16059
#10   — Edited
What servos are you using?
You can connect to the WIFI right?
if not re set the network on the ezb4 unit
connect to the ezb network on your WIFI settings
make sure your battery is charged
I am trying all things, lol
I'm using a bench supply running 7.4 volts . The servos are tower hobby... i think mg 995? generic at any rate.
#12   — Edited
Hey Steve - we can get you up and running ...
  1. do you hear a startup chime when power is applied to the ezb?
  2. do you hear a welcome message when the ezb is reset with the reset button?
  3. do you hear the connection chime when ARC connects to the ezb?
  4. did you select the port using the configuration button on the servo control that matches where the servo is connected?
  5. did you set min and max values of the servo control in the configuration screen?
Yes to questions 1, 3, 4 and 5. I didn't pay attention when I reset it. I can try that tomorrow. If i access the web server diagnostics page I can play all of the chimes and messages there.
#14   — Edited
Okay - next questions
  1. Are you connecting to the ezb on the index #0?
  2. does the ezb repeat "my battery is low"
#15   — Edited
Yes, I just have the one ezb. No its not giving me a low battery message.
