Indoor Positioning System icon Indoor Positioning System — Infrared indoor positioning for ARC robots: dual-camera tracks IR beacon, shows real-time heading, path and EZ-Script navigation variables Try it →
A USB UART/TTL device can be used if wireless is not going to be used. If seeking a wireless solution the hardware being considered must be capable of supporting 9600 kbps No parity, 8 bits and 1 stop bit. Connection to the EZ-B consists of power (+5 vdc and Gnd) and a ttl comm (Tx and Rx). Wireless solutions could be any device that will work with the EZ-B comm requirements. Bluetooth (Class 1 330 ft) XBee, Zigbee,, WiFi, and TCP/IP.
Brazil
You have one tutorial to plug shield WiFi in Ez-Robots?
I have no tutorials but you can search the forum for info. There is no "Shield" just the WiFi with built in TTL interface that can connect to the EZ-B.
First step will be to determine what equipment you want to use to connect the EZ-B board to your Robot. After that then you can seek information about how to use the internet to access the EZ-B.
