Firmware does not update via Bootloader, get the following error log
Warning: Line 2: Fixing Diff: 4 Warning: Line 710: Skipping Type: 4 Warning: Line 711: Impossible Diff: -11328 Address: 0x0, SB Size: 0x5880 Image OK
Train Vision Object By Script
— Train camera vision objects via controlcommand(), attach camera, start learning, monitor progress, and return object name for scripts.
Apparently the Toshiba bluetooth stack is not compatible with the file transfer process. Changed to another laptop (Lenovo) using Win 7 bluetooth stack and the upgrade to V16 was successful.
I had a similar problem. I got it solved by uninstalling all the EZ-B software and then do a completely, fresh new install. Everything worked right away.
