France
Easydriver And NEMA17 Stepper Motor
Hi,
I am trying to use a NEMA17 stepper motor (from an old 3D printer) with the EZB v4, through the EasyDriver - Stepper Motor Driver from Sparkfun. I have connected everything this way:
and use the following code (from this thread: Link):
$x = 0
:loop
  $x = $x + 1
  SET(D1,ON) # dir pin (maintain current direction)
  SET(D0,ON) # step pin
  Sleep(1)
  SET(D0,OFF) # step pin
  Sleep(1)
  print($x) # let me know the loop progress
  if($x = 6400)
  $x = 0 # don't go crazy
  endif
goto (loop)
But the motor barely moves and I cannot change the speed by playing with Sleep().
I use a 24v 15A alim (the same I used before with this stepper motor in my 3D printer) so I should have enough power
Any idea what I do wrong ?
Related Hardware EZ-B v4
Related Control Set Digital
you can't run the stepper from the PC i.e. ARC you need an arduino to run the code.
#3   — Edited
@Fredebec, Soon or later you will find out that is not efficient to run the stepper through the PC (ARC) versus running on the micro-controller. If you look to your code you are sending ON,OFFs to the controller in a short period, when you do that you are "flooding" the controller. The timing is another issue sleep(1) is not 1 ms, sleep(5) is not 5 ms and so on, sleep only works when you are in the context of Javascript, Python, when you get out that context e.g. sending a command through network, and then to EZB queue there is no guarantee of speed.
nevertheless that does not mean you can't run a slow stepper using all the Elephant power (ARC).
Looking to the documentation: https://learn.sparkfun.com/tutorials/easy-driver-hook-up-guide
Did you match the motor coils wiring, and the motor amps (Potentiometer) ?
Please post a PIC of your setup and motor specs.
you missed a few things: Enable (Low = Activates) / (High= Deactivates). Don't forget to switch off otherwise the coils are active. Don't change the wiring while the coils are active.
Resolution:
I would start with both Low, Low, to see some results (movement)
#5   — Edited
@Fredbec: Sparkfun's documentation is pretty good, did you missed that ?
ARC simplifies a lot of things, but wiring less signals (2 of 5)  is not an ARC's feature:)
@ptp,
Thanks for the help. I used this (arduino) link : Easy Driver Example that showed the simple setup i used. It seems that I have been misled...:D
I am going to make the complete circuit and see how it goes. But first, I have some soldering ahead...
#7   — Edited
Please follow the wiring directions and don't forget the common ground.
Javascript code:
//Sparkfun's EasyDriver
//Wiring:
//D2 = Step
//D3 = Dir
//D4 = MS1
//D5 = MS2
//D6 = Enable
//typical motor with 1.8 degrees per step = 200 full steps per revolution
var motor_steps_per_revolution = 200
var driver_resolution = 0;
function forward()
  print("set direction to forward");
  Digital.set(D3, 0);
function backward()
  print("set direction to backward");
  Digital.set(D3, 1);
function enable()
  print("enable motor");
  Digital.set(D2, 0);
  Digital.set(D6, 0);
function disable()
  print("disable motor");
  Digital.set(D6, 1);
function setResolution(value)
  switch(value)
  default:
  case 1:
    Digital.set(D4, 0);
    Digital.set(D5, 0);
    driver_resolution=1;
    break;
  case 2:
    Digital.set(D4, 1);
    Digital.set(D5, 0);
    driver_resolution=2;
  case 4:
    Digital.set(D4, 0);
    Digital.set(D5, 1);
    driver_resolution=4;
  case 8:
    Digital.set(D4, 1);
    Digital.set(D5, 1);
    driver_resolution=8;
    break;
  print("set resolution to 1/" + driver_resolution + " steps.");
function steps(steps, delayMs = 1)
  print("execute " + steps + " steps with delay:" + delayMs + " ms");
  for ( ; steps>0 ; steps--)
     Digital.set(D2, 1);
     sleep(delayMs);
     Digital.set(D2, 0);
     sleep(delayMs);
disable();
setResolution(1);
forward();
enable();
//run two turns (revolutions)
steps(2 * motor_steps_per_revolution * driver_resolution, 1);
backward();
//run three turns (revolutions)
steps(3 * motor_steps_per_revolution * driver_resolution);
//important
disable();
Let me know if it works for you.
So, I have made some testing, and some progresses.
First, I don't use the EasyDriver module anymore, because it stopped working at some stage, without any obvious reason. So, I changed for a DRV8825 (I have a lot of them). I use this kind of setup:
  • the "Enable" pinout connected.
With @ptp's script (and my EZ-script) I am able to rotate the motor, with two main limitations:
  • I am unable to obtain a continuous rotation. It rotates, but randomly...
  • I am unable to change the direction. Putting DIR on or off don't change anything, it always moves in the same direction
