Benchmark icon Benchmark — Diagnose EZ-B connection speed and reliability; benchmark ADC read rates (4-70/sec), reveal flood-control effects and optimize data throttle. Try it →
White Pin
you will need to customize (Scripts) the Custom Movement Panel, I'll post the scripts.
Step 1:
you will need a script to create the speed variables.
Script Name: Init
#set initial speed, speed 0..255
SetSpeed(125)
#Note:
#if left  motor is slower => decrease current_speed_right_factor e.g. 0.9
#if right motor is slower => decrease current_speed_left_factor e.g. 0.9
#Note:
# pwm = 0..100
$current_pwm_left_factor=1.0
$current_pwm_left=CInt(GetSpeed() * $current_pwm_left_factor * 100 / 255)
$current_pwm_right_factor=1.0
$current_pwm_right=CInt(GetSpeed() * $current_pwm_right_factor * 100 / 255)
Then assign the Init script to the connection event:
Step 2:
Add the Custom Movement Panel (Add Control > Scripting > Custom Movement Panel)
you will need 7 scripts for each event: Stop, Forward, Right, Reverse, Left, Speed.
Stop Script:
PWM(D1, 0)
PWM(D3, 0)
Forward Script:
PWM(D1, $current_pwm_left)
Set(D2, OFF)
PWM(D3, $current_pwm_right)
Set(D4, OFF)
Right Script:
Set(D2, OFF)
Set(D4, ON)
Reverse Script:
Set(D2, ON)
Set(D4, ON)
Left Script:
Set(D2, ON)
Set(D4, OFF)
Speed Script:
if ($direction!="Stop")
endif
Check the Digital Ports wires: D0 - Left Motor - E1 D1 - Left Motor - M1 D2 - Right Motor - E2 D3 - Right Motor - M2
Disconnect/Connect the EZB Button, to run the Init script, and it's ready to use.
Note: speed and pwm have different ranges.
Thanx so much. But That seems a lot. I'm only using the h bridge to control 2 motors on my bots drive train. Fwd.backward. left.right:)
Other thing I'm not seeing: how to I provide power to the h bridge from the ezb? From the red/black from one of the servo ports.correct? Just making sure. I don't want to accidently fry something. And Btw, my base is from a RAD robot, that appears to be popular here:)
Yes pickup red = vcc black = gnd from the digital ports and connect to vdd (vcc) and gnd (gnd)
#16
thanx again PTP:)
