Is there an updated version of using this H-Bridge with the EZB v4? I'm assuming (again) that it is the same... But Power? Not using the Battery pack
Thanx:)
Servo Speed
— Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved.
Thanx:)
Finally got around to it, I believe it's wired up right; Put PTP's code in, hope all goes well! lol
Seems to be working! Although the old RAD motor gear boxes seem worn:( not engaging well) Took apart gearboxes and reseated them, works now! But NO REVERSE?
I have both treads going FWD, Left Turn,Right Turn....No Reverse:( PTP, I double checked the code you have here, in my Script...
If you have turn left and turn right set up so that motor 1 rotates one direction and motor 2 rotates the other then reverse should work. Check both motors are rotating when you turn.
Yes, they both turn opposite to each other, in reference to left or right. and FWD. I hit reverse arrow in EZB and nothing.
