Can'T Hook Ezb4 To Network
I have an ezb4 that has worked fine for a while. I had took the robot apart and then put it back together using the V4 instead of V3.
My problem is: I go to find the ezb in the internet access window. I have reset it many times.
I have to give it a code 1234 to hook up to bluetooth. well, I found that I lost ports for Com3, and Com4. So I added them back. My device shows up, but I have a hard time getting to the part that says are you ready to pair?
If I enter in the correct number, it goes out a trys to pair it, it times out and I have to start all over again.
The green light is on and it continuously blinks. There is no red, or whatever. Just a blinking green light.
I have taken everything apart and now my time has run out. I will be back Tues CST to work on it again. I have the unit hooked to a separate 12vdc battery so it will have plenty of juice. There is a constant blinking green light.
Also, there is no sound at all.
thanks in advance.
@Moviemaker I don't understand, are you trying to connect the V4? V4 is wifi not Bluetooth
@moviemaker, Perhaps you should write this down and stick it on a wall. It may aid your condition.
The EZ-B V4 uses WiFi. It connects to your network over wifi. Your initial connection to the ez-b V4 will be direct using your computer. You will then type in your browser 192.168.1.1.
Go to the client mode tab, and enter the information for your Routers wifi address(if you have a wifi network in your house). Then press connect and the ez-b will try to connect to your router and DISCONNECT from your computer.
If it worked, your ez-b should be green or blue, or both. Then connect your COMPUTER to the routers wifi network and open ARC. go to the connection control, and press the scan button to scan for the EZ-B which will now be on your network. Once found, click it, and press connect. Done.
I suspect @Mel is suffering from what my dad is suffering from... Sometimes my dad can't even remember my name... It is sad, but not much you can do about it...
That's why we're patient:D
When I click on the button, there is no webpage that comes up for me to get inside of the ezb settings.
NO IP shows up in the wifi section. and NO sound or bootup. Just a flashing Green light.
No boot sound is a problem, but I believe it sounds like it is already connected to your or a network. Try pressing the scan button in ARC on the connection control and see if it sees it.
