Prevent PC Sleep icon Prevent PC Sleep — Prevents a PC from entering sleep mode via a tiny, resizable control-keeps the system awake while minimizing UI real estate Try it →
Resolved Resolved by Jeremie!
Camera Disabled Message
This may be a duplicate post lost my Wi-Fi during first attempt.
I just received my Developers Kit Yesterday. Working thru the tutorials and came to a stop on the camera. I received the following message;
Camera Initialized: EZB://192.168.1.1 @ 320x240 EZ-B v4 Camera Error: System.IO.IOException: Unable to read data from the transport connection: A blocking operation was interrupted by a call to WSACancelBlockingCall. ---> System.Net.Sockets.SocketException: A blocking operation was interrupted by a call to WSACancelBlockingCall at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZBv4Video.U1r1qoZAAL() Camera Disabled
I have tried reseating as suggested in MechWarrior's post but did not change. Any ideas, thanks.
Hi @ransan, can you see the LED on the camera, what color of light is it emitting?
It flashes blue when first connected and then nothing after that.
Besides re-seating the black and blue circuit boards, please try re-seating the 6-pin cable on both ends (ez-b side and camera side)
I have reseated every connection restarted computer and EZ-B and ARC. No change still receiving same message "Camera Disables"
It seems you have a defective camera, please use Contact us warranty claim section.
