Sabertooth Movement Panel icon Sabertooth Movement Panel — Sabertooth movement panel: control two motors via Simplified Serial with variable speed sliders, movement buttons, and serial port options. Try it →
Hi Patrick,
I know it isn't a EZ Robot product but, I would look around to see if you can find something that will fit in it's place. I can't believe there isn't something else to use. Post a picture of the battery if you can, with voltage, milliamp hours and approximate mm or inch measurements. Once you post the information maybe we can help.
We can see about chargers later.
Hey, I like your Cop. He needs a hat and sun glasses next..LOL... :D:D
Ron R
hi andy
jd has a had.
i will find same and lot cheaper.
its a spacial batt,like design and so.25.2 volt charger
Handsome fellow..... Hat looks good....
Let me know if I need to look also.
Be Well,
Ron R
andy
ok thanks
