Maestro Servo Controller icon Maestro Servo Controller — USB control for Pololu Maestro (6/12/18/24) via ARC Vx ports. Maps Vx to Maestro channels; supports position, speed, acceleration, release. Try it →
ARC only works on windows 7/8. If you want to run it on a chromebook, you could try the http server, which would require a windows pc to run the ARC program and host the server. Then you can connect to that server through your chromebook via the web browser.
Thanks so much
