Hi will ARC work under Google Chrome OS? Thanks, Roger
rolew
— Edited
Talk Servo V2
— Animate servos to simulate jaw/mouth with ARC text-to-speech; configurable vowel/consonant timing, start sync, multi-servo control, pause/stop.
ARC only works on windows 7/8. If you want to run it on a chromebook, you could try the http server, which would require a windows pc to run the ARC program and host the server. Then you can connect to that server through your chromebook via the web browser.
Thanks so much
No problem!
