Display Popup icon Display Popup — Full-screen popup display for ARC: show custom text with configurable timeout, font, text/background color, size and position via controlCommand(). Try it →
Goto() performs the function of what the basic command Gosub is... We already have it.
# Some code
Goto(checksensors)
# Some more code
# In case of an error stop the script before any sub routines
Halt()
# Sub routines
:checksensors
$sensor1 = GetADC(ADC0)
$sensor2 = GetPing(D0, D1)
$sensor3 = Httpget("https://192.168.1.150/currentroomtemp.php";)
Return()
Will it return to exactly from where it was called and go to the next line of code?
Yep
Example with line numbers so I can explain the order of lines executed
1 Print("Hello World")
2 Goto(part1)
3 Print("Goodbye Worlds")
4 Halt()
5 :part1
6 Print("Hello Another World")
7 return()
This will run the code in the following order; 1, 2, 5, 6, 7, 3, 4 and the output would be; Hello World Hello Another World Goodbye Worlds
Try it, open a script control and paste the following code in (not the one above with line numbers, it wont like it), then test the script and look in the right of the dialogue.
Goto(part1)
Halt()
:part1
Return()
As always, Thank You So much!
