Get Line Containing From Array icon Get Line Containing From Array — Adds GetLineContainingFromArray() ez-script function to return the first array item that contains specified text, simplifying substring searches. Try it →
Hi All.
I know we can use 2 H bridges together-- one with the regular Movement Panel and the other via scripting. For some reason, though, I could not get a 4 wire H bridge to work (I wasn't tyring using 2 together-- just the one by itself). It might be a hardware problem-- the one I got looks very slightly different than the example in the video tutorial. My sabertooth works fine.
The question I have is: can I use 2 SABERTOOTH H bridges together? (One to operate wheels, the other to run a car antenna.) Would the scripting be any different than the example DJ posted in another thread?
thanks in advance,
Frank
