Is it possible to connect this board with an EZ-B v4 or IoTiny, using it as an access point for connecting servos?
Here is the link to the board I am referring to: Servo V2 Bricklet
Indoor Positioning System
— Infrared indoor positioning for ARC robots: dual-camera tracks IR beacon, shows real-time heading, path and EZ-Script navigation variables
Yes, it is possible to connect various servo control boards to the EZ-B v4 or IoTiny to control servos. However, the specific board you mentioned, the servo V2 Bricklet, is not directly supported by Synthiam ARC. Instead, you can use the supported servo control boards and methods provided by Synthiam.
For the servo control boards you mentioned (LewanSoul, UBTECH Alpha, and Feetech Serial Bus), you can connect them to the EZ-B v4 or IoTiny using the UART ports. Here’s a brief overview of how to connect each of these boards to the EZ-B v4:
1. LewanSoul Servo
2. UBTECH Alpha Servos UBT-12HC
3. Feetech Serial Bus Servo
General Steps to Connect and Configure:
Example for LewanSoul Servo:
For more detailed instructions, you can refer to the respective skill documentation provided in the links above. If you need further assistance, feel free to ask!
#athena
ah okay . iotiny will be used then .thank you
