Does the auto position control only work with the board index connection 0? with auto position
or is there a way to use it with board indexes connections 1,2,3 etc... with the auto position?
Thanks
EzAng
Lewansoul Servo
— Control LewanSoul LX-16A servos via ARC (EZ-B v4/IoTiny): assign virtual ports, read positions, set speeds, and enable continuous rotation.
Thanks
EzAng
I agree auto-position is easy
Step 1 - go to "projects" on the top of the ARC program, then go to add
Step 2 - add - movement panels
Step 3 - then click auto-position movement panel
Step 4 - add a servo (whatever D0 to D23)
Step 5 - click to open the servo
Step 6 - select
Step 7 - there you have it, pick board number 0 to 4
Good Luck EzAng
Thanks, just having the knowledge of doing it different ways is very helpful. Will be trying it both ways and see which one works the easiest.
Have another question I want to have the Adc get a value from Board 0, from that value want it to make a decision-say turn on a digital switch D0 and have the Adc get a value from Board 1, from that value want it to make a decision-say turn off a digital switch D1 and have the Adc get a value from Board 2, from that value want it to make a decision-say turn on a digital switch D2
From the auto positioner I cannot do a few things Set a Digital Sw on/off and on which board this is one of the reasons why I say there are pros and cons of using autopositioner -just a matter of time before it's figured out by DJ though If you try to do this in blocky you cannot differentiate which board for the digital switch, seems like it have to be done with code- but I'd prefer to do it with Blockly though.
The Auto Position is one of nearly 600 robot skills to use for ARC. The Auto Position is for creating gait and animations using servos.
to do what you ask, using a script robot skill is the correct tool. With that, you would have a loop that monitors an adc value by having an IF condition that sets the digital port.
It is important to recognize the correct tool for a job. For instance, you wouldn’t use a hammer on a screw. You would use a screw driver. There’s a correct tool for each job.
or, you wouldn’t sleep in your refrigerator. Etc...
the Auto Position is not a tool for anything other than it is intended. The same as your refrigerator, which is not for use other than intended.
Ok understand, thanks for the input and sending me in the right direction. You've done a wonderful job with the robot system. I appreciate how you use whole lot of knowledge behind the scenes to make very complex item look easy. By the way both my parents came from Canada. Ok now I'm off to dig into script robot skill and figure it out.
Awesome - the script robot skill uses Blockly as well, so it’ll be pretty easy for ya. And thanks for the kind words!
