Read Digital icon Read Digital — Read TTL digital input from an ARC I/O port; real-time red/green status for low (0V) or high (+3.3/5V), selectable board/port and read interval. Try it →
What's the range you are after ?
Wifi Or Xbee could both be options.
whole house but like i said (robot in 1 house and computer in my other house)
I believe they are asking how far are your houses apart. Is the house right next door almost touching the first house, or is it down the block? The other side of town? In another city? etc.
Usually, wireless works for a matter of feet, not miles.
From how it was explained to me you would at least have to have some sort of computer set up at the house to establish a wifi network. Unless they are just about touching.
houses are 5 miles apart,i was hoping i could leave robot in house 1 (have robot linked to router)and computer in house 2 (linked to router) and use ip adress to link them togeather
You'll have no camera then, unless your using a Wifi camera too. The EZ-Robot camera may use the same radio band as Wifi, but it only communicates to its USB receiver.
You don't have to put the computer on the robot, but one nearby/in the remote house running ARC is pretty much required. If the computer at your house is the one with the EZ-B smarts on it & the internet between the houses fails, your bot would lose its brain, possibly be left driving & crash & damage something.
i have ip foscam camera on it now working with the ez-b program. maby i will look into a mini pc to put on it and use my android phone with phonemypc(phonemypc works great) to control manual when i want to
