USB connection to EZB V4
USB Connection To EZB V4
OK guys I have another question for everyone can you use the UART on the EZB V4 to connect to a USB rather than the camera port?
I want to hardwire my EZB's to my onboard PC but I also want to use my ez-robot camera with one of my EZB V4.
#41
Yep, remember when we built the neopixel blaster @DJ? There was nothing we could do with the EZ-B to get the timing that fast. An Arduino (or equivalent) controller was needed to produce the signals for the WS2812B LEDs. I believe Dave Cochrane built a skill that incorporates an Arduino and Neopixels.
#42
Well it looks like I will have to purchase an Arduino uno to deal with this.  And yes I found the skill for it thank you guys.  This project just keeps getting more and more complex and costly.  I guess that is expected.
#43   — Edited
Hello @smiller29, well I ran into a speed bump. The PL2303 uart-ttl adapter I ordered was the HX 'A' version (PL2303HXA) which as it turns out didn't get driver support in Windows 10. I had no idea that some chip versions didn't get driver support for Windows 8 and 10 (I guess some of the chip versions are legacy products) It seems like they come out with a new chip version almost every year!xD Here's the chip version Windows 10 support list:
Now I have to order another one. Learn from my mistakes I guessxD
#44   — Edited
I ordered two PL-2303HX that is said to work with Windows 10 32/64 bit so I hope it works.  I hope your test works.  I ordered a USB Camera but I am not sure it will fit in the chest where I want it like the EZ-Camera will.
#45
I hope they are the D’ version, cross your fingers
#46
Well Jeremie,  the ones I got also did not work the part description was not correct. So I am sending those back tomorrow.
#47
Hey @smiller29 I received my PL2303TA USB-TTL adapter today and I've done a bit of testing with it. It connected to my laptop as soon as it was plugged in and appeared as a COM port. Using the serial terminal (PC) in ARC I was able to verify that it was communicating with local echo and that it could communicate at 3.3Mbaud. It is rated to go up to 6Mbaud max. Unfortunately, I can't seem to get images to come through with the camera yet but I'll press on tomorrow.
#48
Local echo doesn’t use the adapter. Local echo means just display the characters you typed
to test a true echo, you’d need to connect rx and tx together in the uart
