Stream All The Video Sources icon Stream All The Video Sources — Stream video from any URI/protocol (RTMP, RTSP, HTTP, UDP, etc.) to a selected ARC camera device for real-time network feed playback. Try it →
Resolved Resolved by Athena!
UART_v6 subject line options:- UART_v6 Waypoint Be…
UART_V6 Subject Line Options:- UART_V6 Waypoint Be…
Hi @Athena,
I'm trying to make an ARC UART script that works seamlessly with an Arduino Mega. Both scripts are reproduced below. A few important constraints and clarifications:
  • For WAYPOINT DATA only: in ARC the variables $actualBearing100 and $desiredBearing100 must be the same value and equal to Servo.getPosition(d17, 0) * 100.
  • After WAYPOINT DATA is sent by the ARC UART script (UART_v6), ARC (my IR_TRACKER robot skill / script) computes $actualBearing100. The Arduino computes $desiredBearing100. These values are not read as servo positions on the Arduino - they are assigned and exchanged via ARC global variables (setVar / getVar).
  • The ARC UART_v6 robot skill picks up and sets ARC globals (getVar / setVar). The Arduino communicates over Serial3 in the sketch. The connection model appears to be a hardware UART between ARC (JavaScript running as a Robot Skill) and the Arduino Mega (Serial3).
Request:
  1. Can you rewrite a clean, full UART_v6 script (comments removed) that incorporates the difference in how $actualBearing and $desiredBearing are produced, and that matches exactly the accompanying ARDUINO_v6 sketch?
Thank you, Jack
ARDUINO_v6
#include <AccelStepper.h>
#include <MultiStepper.h>
// Protocol
static const uint8_t UART_HEADER = 0xA5; // ARC -> Arduino
static const uint8_t CMD_STOP_MOTORS    = 0x01;
static const uint8_t CMD_ACTUAL_BEARING = 0x03;
static const uint8_t CMD_RIGHT_PIVOT    = 0x04;
static const uint8_t CMD_LEFT_PIVOT     = 0x05;
static const uint8_t CMD_WAYPOINT_DATA  = 0x06;
// Arduino -> ARC
static const uint8_t RSP_NAV_ACK           = 0x10;
static const uint8_t RSP_TOTAL_STEPS       = 0x11;
static const uint8_t RSP_DESIRED_BEARING   = 0x12;
static const uint8_t RSP_OBS_SCAN_REQUEST  = 0x13;
static const uint8_t MAX_PAYLOAD = 32;
// Motors
AccelStepper LeftFrontWheel(AccelStepper::DRIVER, 3, 6);
AccelStepper LeftBackWheel(AccelStepper::DRIVER, 2, 5);
AccelStepper RightFrontWheel(AccelStepper::DRIVER, 12, 13);
AccelStepper RightBackWheel(AccelStepper::DRIVER, 4, 7);
MultiStepper multiStepper;
// Parser state
enum ParserState { WAIT_HEADER, WAIT_CMD, WAIT_LEN, WAIT_PAYLOAD, WAIT_CHECKSUM };
ParserState parserState = WAIT_HEADER;
uint8_t currentCmd = 0;
uint8_t expectedLen = 0;
uint8_t payloadIndex = 0;
uint8_t payload[MAX_PAYLOAD];
uint8_t runningChecksum = 0;
// Navigation state
bool navRunning = false;
bool scanNeutralMode = false;
uint32_t totalStepsTaken = 0;
uint32_t combinedStepsDesired = 0;
uint32_t pathTotalDistance = 0;
uint32_t oppositeDistance = 0;
uint32_t nextScanStep = 10500;
const uint32_t scanIntervalSteps = 10500;
uint8_t bearingAlignment = 0;
uint8_t trackDir = 0;
uint16_t actualBearing100 = 9000;
uint16_t desiredBearing100 = 9000;
uint16_t lastSentDesiredBearing100 = 0xFFFF;
int16_t bearingDiffTarget = 0;
int16_t bearingDiffRamped = 0;
uint16_t currentSpeed = 0;
uint16_t normalSpeed = 800;
// Byte helpers
uint16_t readUInt16LE(const uint8_t* data) {
  return (uint16_t)data[0] | ((uint16_t)data[1] << 8);
uint32_t readUInt32LE(const uint8_t* data) {
  return (uint32_t)data[0] |
         ((uint32_t)data[1] << 8) |
         ((uint32_t)data[2] << 16) |
         ((uint32_t)data[3] << 24);
void writeUInt16LE(uint16_t value) {
  Serial3.write((uint8_t)(value & 0xFF));
  Serial3.write((uint8_t)((value >> 8) & 0xFF));
void writeUInt32LE(uint32_t value) {
  Serial3.write((uint8_t)((value >> 16) & 0xFF));
  Serial3.write((uint8_t)((value >> 24) & 0xFF));
// Protocol helpers
uint8_t checksumXor(uint8_t cmd, uint8_t len, const uint8_t* data) {
  uint8_t c = cmd ^ len;
  for (uint8_t i = 0; i < len; i++) {
    c ^= data[i];
  return c;
void sendPacket(uint8_t cmd, const uint8_t* data, uint8_t len) {
  Serial3.write(UART_HEADER);
  Serial3.write(cmd);
  Serial3.write(len);
    Serial3.write(data[i]);
  Serial3.write(checksumXor(cmd, len, data));
void sendCmdOnly(uint8_t cmd) {
  sendPacket(cmd, nullptr, 0);
void sendNavAck() {
  sendCmdOnly(RSP_NAV_ACK);
  Serial.println("TX: NAV ACK");
void sendTotalSteps(uint32_t steps) {
  uint8_t tmp[4];
  tmp[0] = (uint8_t)(steps & 0xFF);
  tmp[1] = (uint8_t)((steps >> 8) & 0xFF);
  tmp[2] = (uint8_t)((steps >> 16) & 0xFF);
  tmp[3] = (uint8_t)((steps >> 24) & 0xFF);
  sendPacket(RSP_TOTAL_STEPS, tmp, 4);
  Serial.print("TX: TOTAL STEPS = ");
  Serial.println(steps);
void sendDesiredBearing(uint16_t bearing100) {
  uint8_t tmp[2];
  tmp[0] = (uint8_t)(bearing100 & 0xFF);
  tmp[1] = (uint8_t)((bearing100 >> 8) & 0xFF);
  sendPacket(RSP_DESIRED_BEARING, tmp, 2);
  lastSentDesiredBearing100 = bearing100;
  Serial.print("TX: DESIRED BEARING x100 = ");
  Serial.println(bearing100);
void sendObstacleScanRequest() {
  sendCmdOnly(RSP_OBS_SCAN_REQUEST);
  Serial.println("TX: OBSTACLE SCAN REQUEST");
// Motor helpers
void resetStepperPositions() {
  LeftFrontWheel.setCurrentPosition(0);
  LeftBackWheel.setCurrentPosition(0);
  RightFrontWheel.setCurrentPosition(0);
  RightBackWheel.setCurrentPosition(0);
void setAllMotorSpeeds(int leftSpeed, int rightSpeed) {
  leftSpeed = constrain(leftSpeed, 0, 2000);
  rightSpeed = constrain(rightSpeed, 0, 2000);
  LeftFrontWheel.setSpeed(leftSpeed);
  LeftBackWheel.setSpeed(leftSpeed);
  RightFrontWheel.setSpeed(rightSpeed);
  RightBackWheel.setSpeed(rightSpeed);
void stopMotors() {
  LeftFrontWheel.stop();
  LeftBackWheel.stop();
  RightFrontWheel.stop();
  RightBackWheel.stop();
  LeftFrontWheel.setSpeed(0);
  LeftBackWheel.setSpeed(0);
  RightFrontWheel.setSpeed(0);
  RightBackWheel.setSpeed(0);
  Serial.println("Action: stopMotors()");
void resetNavigationState() {
  resetStepperPositions();
  nextScanStep = scanIntervalSteps;
  currentSpeed = 0;
  navRunning = false;
  Serial.println("Navigation state reset");
void beginForwardNavigation() {
  navRunning = true;
  currentSpeed = 0;
// Navigation math
void computeDesiredBearing() {
  if (bearingAlignment == 0) {
    return;
  uint32_t pathDistanceRemaining = 1;
  if (trackDir == 0) {
    if (pathTotalDistance > totalStepsTaken) {
      pathDistanceRemaining = pathTotalDistance - totalStepsTaken;
  } else {
    uint32_t remainingSteps = (combinedStepsDesired > totalStepsTaken)
      ? (combinedStepsDesired - totalStepsTaken)
      : 0;
    if (pathTotalDistance > remainingSteps) {
      pathDistanceRemaining = pathTotalDistance - remainingSteps;
  float tangent = (float)oppositeDistance / (float)pathDistanceRemaining;
  float deg = atan(tangent) * 180.0 / PI;
  desiredBearing100 = (uint16_t)((deg + 90.0) * 100.0);
  if (abs((int)desiredBearing100 - (int)lastSentDesiredBearing100) >= 100) {
    sendDesiredBearing(desiredBearing100);
void updateBearingDiff() {
  bearingDiffTarget = (int16_t)actualBearing100 - (int16_t)desiredBearing100;
  if (bearingDiffRamped < bearingDiffTarget) {
    bearingDiffRamped += 10;
    if (bearingDiffRamped > bearingDiffTarget) bearingDiffRamped = bearingDiffTarget;
  } else if (bearingDiffRamped > bearingDiffTarget) {
    bearingDiffRamped -= 10;
    if (bearingDiffRamped < bearingDiffTarget) bearingDiffRamped = bearingDiffTarget;
void runForwardLoop() {
  if (!navRunning) {
    return;
  if (currentSpeed < normalSpeed) {
    currentSpeed = normalSpeed;
  computeDesiredBearing();
  updateBearingDiff();
  int leftSpeed = currentSpeed;
  int rightSpeed = currentSpeed;
  if (!scanNeutralMode) {
    int correction = bearingDiffRamped / 10;
    leftSpeed -= correction;
    rightSpeed += correction;
  Serial.print("RUN=");
  Serial.print(navRunning);
  Serial.print(" currentSpeed=");
  Serial.print(currentSpeed);
  Serial.print(" bearingDiffRamped=");
  Serial.print(bearingDiffRamped);
  Serial.print(" leftSpeed=");
  Serial.print(leftSpeed);
  Serial.print(" rightSpeed=");
  Serial.print(rightSpeed);
  Serial.print(" scanNeutralMode=");
  Serial.println(scanNeutralMode);
  setAllMotorSpeeds(leftSpeed, rightSpeed);
  LeftFrontWheel.runSpeed();
  LeftBackWheel.runSpeed();
  RightFrontWheel.runSpeed();
  RightBackWheel.runSpeed();
  totalStepsTaken =
    (abs(LeftFrontWheel.currentPosition()) +
     abs(LeftBackWheel.currentPosition()) +
     abs(RightFrontWheel.currentPosition()) +
     abs(RightBackWheel.currentPosition())) / 4;
  if (totalStepsTaken >= nextScanStep) {
    sendObstacleScanRequest();
    scanNeutralMode = true;
    nextScanStep += scanIntervalSteps;
  if (combinedStepsDesired > 0 && totalStepsTaken >= combinedStepsDesired) {
    stopMotors();
    sendTotalSteps(totalStepsTaken);
    resetNavigationState();
// Packet handling
uint8_t getExpectedLength(uint8_t cmd) {
  switch (cmd) {
    case CMD_STOP_MOTORS:    return 0;
    case CMD_ACTUAL_BEARING: return 2;
    case CMD_RIGHT_PIVOT:    return 2;
    case CMD_LEFT_PIVOT:     return 2;
    case CMD_WAYPOINT_DATA:  return 18;
    default:                 return 0xFF;
void pivotRight(uint16_t steps) {
  long positions[4];
  positions[0] = LeftFrontWheel.currentPosition() + steps;
  positions[1] = LeftBackWheel.currentPosition() + steps;
  positions[2] = RightFrontWheel.currentPosition() - steps;
  positions[3] = RightBackWheel.currentPosition() - steps;
  multiStepper.moveTo(positions);
  while (multiStepper.run()) { }
  totalStepsTaken += steps;
  stopMotors();
void pivotLeft(uint16_t steps) {
  long positions[4];
  positions[0] = LeftFrontWheel.currentPosition() - steps;
  positions[1] = LeftBackWheel.currentPosition() - steps;
  positions[2] = RightFrontWheel.currentPosition() + steps;
  positions[3] = RightBackWheel.currentPosition() + steps;
  stopMotors();
void handleWaypointPacket(const uint8_t* data, uint8_t len) {
  if (len != 18) {
    Serial.println("Waypoint length error");
    return;
  pathTotalDistance      = readUInt32LE(&data[0]);
  combinedStepsDesired   = readUInt32LE(&data[4]);
  oppositeDistance       = readUInt32LE(&data[8]);
  bearingAlignment       = data[12];
  desiredBearing100      = readUInt16LE(&data[13]);
  actualBearing100       = readUInt16LE(&data[15]);
  trackDir               = data[17] & 0x01;
  Serial.println("RX: WAYPOINT DATA");
  Serial.print(" pathTotalDistance=");
  Serial.println(pathTotalDistance);
  Serial.print(" combinedStepsDesired=");
  Serial.println(combinedStepsDesired);
  Serial.print(" oppositeDistance=");
  Serial.println(oppositeDistance);
  Serial.print(" bearingAlignment=");
  Serial.println(bearingAlignment);
  Serial.print(" desiredBearing100=");
  Serial.println(desiredBearing100);
  Serial.print(" actualBearing100=");
  Serial.println(actualBearing100);
  Serial.print(" trackDir=");
  Serial.println(trackDir);
  sendNavAck();
  beginForwardNavigation();
void handlePacket(uint8_t cmd, const uint8_t* data, uint8_t len) {
  switch (cmd) {
      stopMotors();
      break;
      if (len == 2) {
        actualBearing100 = readUInt16LE(data);
        Serial.print("actualBearing100: ");
      break;
      if (len == 2 && !navRunning) {
        pivotRight(readUInt16LE(data));
      break;
        pivotLeft(readUInt16LE(data));
      break;
      if (!navRunning) {
        handleWaypointPacket(data, len);
      break;
// UART parser
void processIncomingByte(uint8_t b) {
  switch (parserState) {
    case WAIT_HEADER:
      if (b == UART_HEADER) {
        parserState = WAIT_CMD;
      break;
    case WAIT_CMD:
      currentCmd = b;
      runningChecksum = b;
      parserState = WAIT_LEN;
      break;
    case WAIT_LEN:
      expectedLen = b;
      runningChecksum ^= b;
      if (expectedLen > MAX_PAYLOAD) {
      } else if (expectedLen == 0) {
        parserState = WAIT_CHECKSUM;
      } else {
        payloadIndex = 0;
        parserState = WAIT_PAYLOAD;
      break;
    case WAIT_PAYLOAD:
      payload[payloadIndex++] = b;
      if (payloadIndex >= expectedLen) {
      break;
    case WAIT_CHECKSUM:
      if (b == runningChecksum) {
        handlePacket(currentCmd, payload, expectedLen);
      } else {
        Serial.println("Checksum error");
      currentCmd = 0;
      expectedLen = 0;
      payloadIndex = 0;
      break;
void readIncomingUart() {
  while (Serial3.available() > 0) {
    processIncomingByte((uint8_t)Serial3.read());
// Arduino setup/loop
void setup() {
  Serial.begin(115200);
  Serial3.begin(115200);
  LeftFrontWheel.setMaxSpeed(2000);
  LeftBackWheel.setMaxSpeed(2000);
  RightFrontWheel.setMaxSpeed(2000);
  RightBackWheel.setMaxSpeed(2000);
  LeftFrontWheel.setAcceleration(800);
  LeftBackWheel.setAcceleration(800);
  RightFrontWheel.setAcceleration(800);
  RightBackWheel.setAcceleration(800);
  multiStepper.addStepper(LeftFrontWheel);
  multiStepper.addStepper(LeftBackWheel);
  multiStepper.addStepper(RightFrontWheel);
  multiStepper.addStepper(RightBackWheel);
  Serial.println("ARDUINO_v5 ready");
void loop() {
  readIncomingUart();
  runForwardLoop();
UART_v6 (ARC JavaScript Robot Skill)
var UART_INDEX = 0;
var UART_HEADER = 0xA5;
// ARC -> Arduino
var CMD_STOP_MOTORS = 0x01;
var CMD_ACTUAL_BEARING = 0x03;
var CMD_RIGHT_PIVOT = 0x04;
var CMD_LEFT_PIVOT = 0x05;
var CMD_WAYPOINT_DATA = 0x06;
// Arduino -> ARC
var RSP_NAV_ACK = 0x10;
var RSP_TOTAL_STEPS = 0x11;
var RSP_DESIRED_BEARING = 0x12;
var RSP_OBS_SCAN_REQUEST = 0x13;
// RX parser state
var rxState = 0; // 0=wait header, 1=cmd, 2=len, 3=payload, 4=checksum
var rxCmd = 0;
var rxLen = 0;
var rxIndex = 0;
var rxPayload = [];
var rxChecksum = 0;
function safeInt(v, def) {
  var n = parseInt(v);
  if (isNaN(n)) return def;
  return n;
function clamp(v, min, max) {
  if (v < min) return min;
  if (v > max) return max;
  return v;
function u16ToBytes(value) {
  value = value & 0xFFFF;
  return [
    value & 0xFF,
    (value >> 8) & 0xFF
function u32ToBytes(value) {
  value = value >>> 0;
  return [
    value & 0xFF,
    (value >> 8) & 0xFF,
    (value >> 16) & 0xFF,
function bytesToU16LE(b0, b1) {
  return (b0 & 0xFF) | ((b1 & 0xFF) << 8);
function bytesToU32LE(b0, b1, b2, b3) {
  return (
    (b0 & 0xFF) |
    ((b1 & 0xFF) << 8) |
    ((b2 & 0xFF) << 16) |
    ((b3 & 0xFF) << 24)
  ) >>> 0;
function checksumXor(cmd, len, payload) {
  var c = (cmd ^ len) & 0xFF;
  for (var i = 0; i < payload.length; i++) {
    c ^= (payload[i] & 0xFF);
  return c & 0xFF;
function sendPacket(cmd, payload) {
  var len = payload.length & 0xFF;
  var cs = checksumXor(cmd, len, payload);
  var out = [];
  out.push(UART_HEADER);
  out.push(cmd & 0xFF);
  out.push(len);
    out.push(payload[i] & 0xFF);
  out.push(cs);
  UART.hardwareUartWrite(UART_INDEX, out);
function sendCmdOnly(cmd) {
  sendPacket(cmd, []);
function sendStopMotors() {
  sendCmdOnly(CMD_STOP_MOTORS);
  print("TX: STOP MOTORS");
function sendActualBearing() {
  // You asked for bearing to reflect Servo.getPosition(d17,0) * 100
  // var bearing100 = safeInt(Servo.getPosition(d17, 0), 90) * 100;
  var bearing100 = getVar("$actualBearing100");
  bearing100 = clamp(bearing100, 0, 18000);
  var payload = u16ToBytes(bearing100);
  sendPacket(CMD_ACTUAL_BEARING, payload);
  print("TX: ACTUAL BEARING x100 = " + bearing100);
function sendWaypointData() {
  // Bearing source per your request
  // Build packet values from ARC globals
  var pathTotalDistance = safeInt(getVar("$pathTotalDistance", 0), 0) >>> 0;
  var combinedStepsDesired = safeInt(getVar("$combinedStepsDesired", 0), 0) >>> 0;
  var oppositeDistance = safeInt(getVar("$oppositeDistance", 0), 0) >>> 0;
  var bearingAlignment = safeInt(getVar("$bearingAlignment", 0), 0) & 0xFF;
  // trackDir must be 0 or 1
  var trackDir = safeInt(getVar("$trackDir", 0), 0);
  trackDir = (trackDir === 0) ? 0 : 1;
  // Per your request: both values reflect Servo.getPosition(d17,0) * 100
  var desiredBearing100 = bearing100;
  var actualBearing100 = bearing100;
  var payload = [];
  payload = payload.concat(u32ToBytes(pathTotalDistance));
  payload = payload.concat(u32ToBytes(combinedStepsDesired));
  payload = payload.concat(u32ToBytes(oppositeDistance));
  payload.push(bearingAlignment);
  payload = payload.concat(u16ToBytes(desiredBearing100));
  payload = payload.concat(u16ToBytes(actualBearing100));
  payload.push(trackDir);
  if (payload.length != 18) {
    print("Waypoint payload length error: " + payload.length);
    return;
  sendPacket(CMD_WAYPOINT_DATA, payload);
  print("TX: WAYPOINT DATA");
  print("  pathTotalDistance=" + pathTotalDistance);
  print("  combinedStepsDesired=" + combinedStepsDesired);
  print("  oppositeDistance=" + oppositeDistance);
  print("  bearingAlignment=" + bearingAlignment);
  print("  desiredBearing100=" + desiredBearing100);
  print("  actualBearing100=" + actualBearing100);
  print("  trackDir=" + trackDir);
function sendRightPivot() {
  var steps = safeInt(getVar("$pivotSteps", 0), 0) >>> 0;
  sendPacket(CMD_RIGHT_PIVOT, u16ToBytes(steps));
  print("TX: RIGHT PIVOT steps=" + steps);
function sendLeftPivot() {
  sendPacket(CMD_LEFT_PIVOT, u16ToBytes(steps));
  print("TX: LEFT PIVOT steps=" + steps);
function expectedLengthForCmd(cmd) {
  switch (cmd) {
    case RSP_NAV_ACK:
      return 0;
    case RSP_TOTAL_STEPS:
      return 4;
    case RSP_DESIRED_BEARING:
      return 2;
    case RSP_OBS_SCAN_REQUEST:
      return 0;
    default:
      return -1;
function handleRxPacket(cmd, payload) {
  if (cmd == RSP_NAV_ACK) {
    print("RX: NAV ACK");
    setVar("$navAckReceived", 1);
    return;
  if (cmd == RSP_TOTAL_STEPS) {
    if (payload.length == 4) {
      var steps = bytesToU32LE(payload[0], payload[1], payload[2], payload[3]);
      print("RX: TOTAL STEPS = " + steps);
      setVar("$totalStepsTaken", steps);
    return;
  if (cmd == RSP_DESIRED_BEARING) {
    if (payload.length == 2) {
      var bearing100 = bytesToU16LE(payload[0], payload[1]);
      print("RX: DESIRED BEARING x100 = " + bearing100);
      setVar("$desiredBearing100", bearing100);
    return;
  if (cmd == RSP_OBS_SCAN_REQUEST) {
    print("RX: OBSTACLE SCAN REQUEST");
    setVar("$obstacleScanRequested", 1);
    return;
  print("RX: Unknown cmd=" + cmd + " len=" + payload.length);
function processIncomingBytes() {
  var available = UART.hardwareUartAvailable(UART_INDEX);
  while (available > 0) {
    var b = UART.hardwareUartRead(UART_INDEX, 1)[0];
    available--;
    if (rxState == 0) {
        rxState = 1;
      continue;
    if (rxState == 1) {
      rxCmd = b & 0xFF;
      rxChecksum = rxCmd;
      rxState = 2;
      continue;
    if (rxState == 2) {
      rxLen = b & 0xFF;
      rxChecksum ^= rxLen;
      rxPayload = [];
      rxIndex = 0;
      if (rxLen == 0) {
        rxState = 4;
      } else {
        rxState = 3;
      continue;
    if (rxState == 3) {
      rxPayload.push(b & 0xFF);
      rxChecksum ^= (b & 0xFF);
      rxIndex++;
      if (rxIndex >= rxLen) {
        rxState = 4;
      continue;
    if (rxState == 4) {
      var cs = b & 0xFF;
      if (cs == (rxChecksum & 0xFF)) {
        handleRxPacket(rxCmd, rxPayload);
      } else {
        print("RX checksum error. cmd=" + rxCmd + " expected=" + (rxChecksum & 0xFF) + " got=" + cs);
      rxState = 0;
      rxCmd = 0;
      rxLen = 0;
      rxIndex = 0;
      rxPayload = [];
      rxChecksum = 0;
      continue;
print("UART_v5 started");
while (true) {
  if (getVar("$sendWaypointNow", 0) == 1 && getVar("$waypointSent", 0) == 0) {
    sendWaypointData();
    setVar("$sendWaypointNow", 0);
    setVar("$waypointSent", 1);
  if (getVar("$sendStopNow", 0) == 1) {
    sendStopMotors();
    setVar("$sendStopNow", 0);
  if (getVar("$sendActualBearingNow", 0) == 1) {
    sendActualBearing();
    setVar("$sendActualBearingNow", 0);
  if (getVar("$sendRightPivotNow", 0) == 1) {
    sendRightPivot();
    setVar("$sendRightPivotNow", 0);
  if (getVar("$sendLeftPivotNow", 0) == 1) {
    sendLeftPivot();
    setVar("$sendLeftPivotNow", 0);
  processIncomingBytes();
  sleep(20);
Slide Script by Synthiam
Adjust a numeric variable via slider (0-1000) with customizable min/max, center button and scripts triggered on value change or bonus button press.
Task Script by Synthiam Inc.
Split complex robot tasks into sequential scripts, synchronizing asynchronous skills via NEXT/CANCEL commands for staged automation.
Absolutely - here’s a review of the math in computeDesiredBearing() and updateBearingDiff(), plus the key things I’d change for consistency and safety in ARC/Arduino.
What it’s doing now
You’re computing:
  • pathDistanceRemaining
  • ratio = oppositeDistance / pathDistanceRemaining
  • angle = atan(ratio) in degrees
  • then shifting by + 90 and scaling by * 100
So this line:
means your bearing range becomes roughly:
  • 0 to 18000 for 0.00 to 180.00
That’s consistent with your bearing100 protocol.
Main concern: divide-by-zero / near-zero
This line is vulnerable:
You guard pathDistanceRemaining by setting it to 1 initially, which avoids divide-by-zero, but it can still create a very large angle if the remaining distance is extremely small.
That may be okay if intentional, but if not, I’d clamp it more explicitly.
Main concern: use of atan() instead of atan2()
If oppositeDistance is always positive and you only need a single-sided geometry angle, atan() is fine.
But if you want a more robust bearing calculation, atan2() is usually better because it handles sign and quadrants properly.
For your current design, though, atan() is acceptable if the geometry is always positive and one-directional.
Suggested cleaner version
  if (bearingAlignment == 0) return;
  } else {
    uint32_t remainingSteps = (combinedStepsDesired > totalStepsTaken) ? (combinedStepsDesired - totalStepsTaken) : 0;
  if (pathDistanceRemaining == 0) {
  uint16_t newDesiredBearing100 = (uint16_t)((deg + 90.0) * 100.0);
  desiredBearing100 = constrain(newDesiredBearing100, 0, 18000);
updateBearingDiff()
What it’s doing now
You calculate:
This means:
  • positive value = actual bearing is larger than desired
  • negative value = actual bearing is smaller than desired
That’s good and intuitive.
Then you "ramp" the difference:
if (bearingDiffRamped < bearingDiffTarget) bearingDiffRamped += 10;
else if (bearingDiffRamped > bearingDiffTarget) bearingDiffRamped -= 10;
This is essentially a smoothing filter. That’s a good idea.
Main concern: overshoot
Right now, if bearingDiffRamped is close to bearingDiffTarget, adding or subtracting 10 can overshoot the target.
For example:
  • target = 7
  • ramped = 0
  • ramped += 10 now 10, which overshoots
You partially correct this by forcing:
But only after the increment/decrement logic. That works, though it can be made cleaner.
Cleaner version
This version prevents overshoot directly:
Important logic note
Right now updateBearingDiff() only computes a smoothed difference. It does not actually use that difference to drive any correction behavior in the snippet you shared.
So the math is fine, but the next question is:
  • what action should happen when bearingDiffRamped is positive?
  • what action should happen when it is negative?
  • do you want the magnitude to control motor speed or pivot intensity?
That’s the part that determines whether the math is merely computed or actually used for navigation correction.
My recommendation
Keep:
  • desiredBearing100 = (deg + 90.0) * 100.0
  • bearingDiffTarget = actual - desired
Improve:
  • explicit guard for pathDistanceRemaining <= 0
  • clamp desiredBearing100 to 0..18000
  • avoid overshoot in updateBearingDiff()
One more small ARC/Arduino consistency note
Because ARC is sending actualBearing100 initially and later sending computed actual bearing updates, make sure both sides agree on:
  • degrees * 100
  • integer range 0..18000
  • no decimal payloads
That keeps your UART packets simple and reliable.
If you want, I can now rewrite just these two Arduino functions in final production-ready form and match them to your current full sketch exactly.
#10   — Edited
@Athena. Thank you for your analysis. I have 3 requests.
1. I would like to perform Right Triangle equations to the right (as I am currently doing) and perform Right Triangle equations to the left. An equation to the right resulting in the OppositeDistance side proceeding to the right towards the reflector. An equation to the left resulting in the OppositeDistance side proceeding to the left towards the reflector. So, would an equation to the left be negative and an equation to the right be positive? If so, I need you to utilize atan2().
If oppositeDistance is always positive and you only need a single-sided geometry angle, atan() is fine. But if you want a more robust bearing calculation, atan2() is usually better because it handles sign and quadrants properly. For your current design, though, atan() is acceptable if the geometry is always positive and one-directional. 2.
Keep:
Improve:
3. One more small ARC/Arduino consistency note Because ARC is sending actualBearing100 initially and later sending computed actual bearing updates, make sure both sides agree on:
  • degrees * 100
Thank you. Jack
Yes - for a left/right triangle solution, atan2() is the right choice.
Short answer
  • Right side can be treated as positive
  • Left side can be treated as negative
  • That lets atan2(opposite, adjacent) return:
    • a positive angle to the right
    • a negative angle to the left
So yes, if you want the triangle to resolve in both directions, you should move from atan() to atan2().
How that applies to your case
If your geometry is:
  • adjacent = pathDistanceRemaining
  • opposite = lateral offset from centerline to the reflector
then you can define:
  • oppositeDistance > 0 = reflector/right target is to the right
  • oppositeDistance < 0 = reflector/left target is to the left
Then:
float angle = atan2(oppositeDistance, pathDistanceRemaining) * 180.0 / PI;
This produces:
  • positive angle for right
  • negative angle for left
What happens to your bearing math
If you keep your current convention of storing bearings as 0..18000 with a center offset, then you can still do:
desiredBearing100 = (uint16_t)((angle + 90.0) * 100.0);
That means:
  • -45.0 becomes 4500
  • 0.0 becomes 9000
  • +45.0 becomes 13500
So your existing +90 offset model still works.
For your left/right navigation, I’d recommend:
float angleDeg = atan2((float)oppositeDistance, (float)pathDistanceRemaining) * 180.0 / PI;
uint16_t newDesiredBearing100 = (uint16_t)((angleDeg + 90.0) * 100.0);
Important design decision
You need to decide whether left/right offset should be signed at the source or derived later.
Option A - signed oppositeDistance
  • left = negative
  • right = positive
  • best choice for atan2()
Option B - unsigned distance plus a direction flag
  • oppositeDistance stays positive
  • add something like turnDir = -1 or +1
  • then use:
    float angleDeg = atan2(turnDir * oppositeDistance, pathDistanceRemaining) * 180.0 / PI;
If your current data already includes a left/right direction, this may be the cleaner approach.
About bearingDiffTarget = actual - desired
Yes, keep that.
That means:
  • if actual is greater than desired, the robot is effectively rotated one way
  • if actual is less than desired, it is rotated the other way
That sign convention is fine as long as your correction logic uses it consistently.
About the updateBearingDiff() smoothing
Yes, keep the guard and the overshoot protection. That part is good practice.
I’d recommend this version:
About ARC / Arduino consistency
Yes, your summary is exactly right:
  • use degrees × 100
  • keep values in 0..18000
  • don’t send decimals over UART
  • keep both sides using the same unit system
That makes the protocol much cleaner and easier to debug.
My recommendation for your geometry model
Use this logic:
  • right target: positive oppositeDistance
  • left target: negative oppositeDistance
  • compute angle using atan2()
  • convert to your 0..18000 bearing scale by adding 90.0
That gives you a single math model that supports both directions naturally.
If you want, I can now rewrite your full computeDesiredBearing() and updateBearingDiff() functions in final Arduino form using atan2() and your left/right signed-distance approach.
@Athena. Please rewrite your full computeDesiredBearing() and updateBearingDiff() functions in final Arduino form using atan2() and your left/right signed-distance approach. Thank you. Jack
Sorry, I can't continue helping in this thread. It's grown long enough that my context window will require too much extra processing, which makes follow-ups unreliable and I can start making mistakes.
A couple of options:
  • Start a new thread that picks up where we left off - fresh context, faster responses.
  • Or get unlimited interaction with me through ARC's built-in AI Assistant agent: Synthiam AI Assistant
@Athena. Thank you for your help. Very Informative. Jack
