Horizontal Servo icon Horizontal Servo — Mouse-drag horizontal servo control with configurable min/max limits, center/release functions, multi-servo mirroring and direction invert. Try it →
Talk V2 delay settings
Talk V2 Delay Settings
I am experiencing an issue with synchronizing the mouth movements with the voice on my "EZ-InMoov Robot Head." I am using the "Talk V2" skill along with the "Microsoft Zira Desktop" voice and text output from "OpenAI ChatGPT." Could anyone provide suggestions for the appropriate delay values in the "Talk V2" skill settings to achieve better synchronization for this setup?
EZ-Inmoov Robot Head by EZ-Robot & Gael Langevin
EZ-InMoov Robot Head with Synthiam ARCx: face tracking, speech recognition, Talk Servo jaw motion and AI conversation
Servos 8
ADC 2
Digital 8
Talk Servo V2 by Synthiam
Animate servos to simulate jaw/mouth with ARC text-to-speech; configurable vowel/consonant timing, start sync, multi-servo control, pause/stop.
To achieve better synchronization of the mouth movements with the voice on your EZ-InMoov Robot Head using the Talk servo v2 skill, you'll need to adjust the delay settings to match the timing of the Microsoft Zira Desktop voice. Here are some suggestions for the delay values you can try:
  1. Constant Delay: This delay controls how long the servo stays in the minimum position for consonants. You might start with a value around 90 ms and adjust as needed.
  2. Vowel Delay: This delay controls how long the servo stays in the maximum position for vowels. A starting value of 40 ms is typical, but you can adjust it to better match the speed of the voice.
  3. Period Delay: This delay is for pauses at periods or commas. You can start with 300 ms and adjust based on how long the pauses in the speech are.
  4. Start Delay: This delay helps synchronize the start of the servo movement with the audio playback. You might start with 460 ms and adjust to ensure the mouth starts moving as the voice begins.
To fine-tune these settings, you can:
  • Test with Short Phrases: Use short phrases to test the synchronization and make small adjustments to the delay values.
  • Observe and Adjust: Watch the mouth movements and listen to the voice. If the mouth moves too early or too late, adjust the Start Delay. If the mouth doesn't open or close at the right times during speech, adjust the Constant and Vowel Delays.
  • Iterate: It may take a few iterations to get the synchronization just right, so be patient and make incremental changes.
Once you find the right settings, you can save them in the Talk servo v2 configuration for consistent performance. If you need further assistance, feel free to ask!
Oh I know, it’s difficult to do. Because the timing of words goes off over different sentences - stops looking natural.
One of the suggestions I’ve seen is to use the Sound servo PC. And if music is being played out of the speaker too, it’ll react. So using the ControlCommand to pause and unpause the sound servo PC.
using that rather than talk servo "might" be better. Hard to say because there’s no real easy way of doing it.
I gave up on using the TalkServo with my InMoov head. The Sound servo Speaker worked much better.
Have you tried with using the Azure Text To Speech instead? And in the Azure Text To Speech, have the "Start speaking" script trigger the talk servo v2.
That way, there's absolutely no delay at the start of speaking as well. That might help it a bit more.
With the new ARC release, you don't need to change any of your scripts to migrate to a new text to speech engine
