Lidar-Lite Laser Module icon Lidar-Lite Laser Module — Laser Lidar-Lite ARC control reads distance, velocity and signal strength (0-40m+) via EZ-B v4 i2c, setting EZ-Script vars for robotics Try it →
Twitter
Resolved Resolved by fxrtst!
Servos for robot dog
Servos For Robot Dog
Anyone building a robot dog? I am looking for Servo's to build one that will work with ARC...
Servo Speed by Synthiam
Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved.
#177
Awwww I love that! The biggest motor I remember, I was about 10 years old we had a stator that was big enough for me stand up in arms out stretched...but this one is waaaaayyyyy bigger. I've never seen a wind turbine apart like that before..so neat! Thanks for sharing!
#178
OMG that is some huge a** generator!!! You always forget industry builds when working on the small scale hobby projects...amazing!!!:D
Twitter
#179
anyone working with PolyCarbonate. I am printing the MJBot components and the lower legs are PC Blend. Reading the docs on PC Blend looks like you need a hood (I guess I can make a makeshift one using clear plastic and dowel) but wondering what peoples experiences are.  Also looks like the PC Blend is quite strong (although prone to warp on large prints) wondering if suitable for gears.
#180   — Edited
@nink Just be sure your hot end can get up to 250-300 degrees. It warps and splits like crazy..more so than ABS. Need to put the printer into an enclosure to keep it heated to reduce warping. Also PC likes a bed at 145-150. Print slow for first layer like 20mm/sec. No fans on.
Edit: I missed you were using a blend.....these suggestions are for PC by itself. Not used a blend..what is the other component?
Twitter
#181
Thanks for the info @Will. It is Prusa own PC Blend filament.  I haven't ordered it yet but wanted to understand how complicated this really was.  Sounds like the Prusa printer supports it so I am game, I just didn't want to waste a bunch of money for a failed print and to make sure I had everything I need to do it.
https://shop.prusa3d.com/en/prusament/1258-prusament-pc-blend-natural-1kg.html
#182
Here are some good ideas for enclosures...they will help to prevent the crazy warping of your prints!:)
Twitter
#183
Thanks I just got rid of a couple of old tables just like these.  I don't think I will do the tent idea because you can't see the print.
#184
The tent is a bit weird...the table idea is cool though!!:)
