Sherpa-ONNX Speech To Text icon Sherpa-ONNX Speech To Text — Offline continuous speech recognition with wake word support, custom phrases, and real-time transcription using sherpa-onnx models on ARC Windows. Try it →
Sabertooth/kangaroo With Different Motor/encoder Combination
Sabertooth/Kangaroo With Different Motor/Encoder Combination
Since I know some of you have used the Sabertooth and Kangaroo I figured I would ask opinions.
I have decided on the Parralax Arlo base for my next robot chassis. I will use the caster's from parralax.
I will most likely be using the Sabertooth and kangaroo combination for motor controller/PID but I am not decided on this and open to suggestions.
I also find myself in a heated mental debate between the wheel/motor combination from parralax or the Zagros Rex motors and wheels combined with the Sabertooth/Kangaroo.
Item 1:
One of the key items for me is how well the encoders between the two different motor/wheel sets works with the Sabertooth and kangaroo.
Item 2:
The other item floating in my mind is the ground clearance between the two motor/wheel sets. It seems at least to me that the Zagros wheels would provide more ground clearing but since the base plate of the chassis provides stability to the base platform I am not really sure if using the Zagros motors are feasible.
Item 3:
Since I am going to build a body, arms and head on top of the base the torque and weight carrying ability is important.
Item 4:
I need to be able to control both the position and speed of the motors at the same time. For example example I should be able to have to robot move lets say 1 feet at a certain speed.
I know this is kind of an open ended questions but if anyone have used any of these wheel/motor combinations please provide your 2 cents as it relates to the items listed above.
I appreciate any comments or insights you guys can provide.
#129
No headder sounds like a good option. That’s how I'd like to buy something like this. I seem to always be unsoldering things and redoing them to make my own connection points anyway.
#130
That is what I am thinking. Also, it would allow someone to direct solder wire to the board if they wanted too.
For those in Europe, I chose all RoHS components.
#131
I will have to sell these for about $5.00 each to make it worth my time to put them together to sell to others. The original order will be for 160 board. I will put them up for sale to see what happens.
#132
Given the total cost of a Sabertooth/Roo/Encoder combo, another $5+shipping to make it effective is certainly money well spent. I think you could easily charge double that and sell as many as you are going to sell. I think the challenge may be finding 160 people with this need. It seems to be a fairly small part of our community that needs them, although maybe the Astromech and BB8 builders clubs have a need that we aren't seeing here as well. I am not even sure I am buying a roo to go with my sabertooth, but I will order one when they are available just to be sure I have it if I need it.
Where I see the potential is more in the Arduino world. There are people building these for themselves, but there isn't anything that is available to purchase built and ready to use. Digital (logic) /2 circuits (especially with the 74HC chip) seem to be in demand a bit. I need to sell about 50 of these at this price to break even. I think that is doable and still leaves me with a good stock to start on Rafiki's.
The encoder/sabertooth/roo issue is really just one of the issues that can be resolved with this. I think it could be used for clocks or many other projects that I have seen while researching flip flop circuits.
#134
The other benefit I do see is with this motor specifically. I can find the motors without the encoders for $200 each. I then can find encoders for about $40 each that will work on these motors. The motor+encoder+flip flop runs about $144 if the motors+encoders are bought from Zagros.
This all excludes shipping of course. So, you end up saving about $96.00 with this option if you wanted this motor with a smaller count encoder. 65K per rev is crazy ridiculous.
If you are looking at producing quite a few robots using these motors, a cost savings of $192.00 per robot is huge. This along with the time to put these encoders on the motors as opposed to putting these on the encoders really helps.
Also, the pull up resistors for the encoder are in the circuit so, this is an added benefit for manufacturing.
#135
DIP Socket or solder the chip to the board? It doubles the price to have the DIP socket. Thoughts?
#136
it is safer to do the socket so I think I will go that route. Alan, we are now at that $10.00 mark you mentioned... Ugh
Trying to keep it to where if I sell 50 of these, I break even.
[edit] I will use sockets on the first 10 that I make. From there I will go to soldering the chips on the board.
The first 160 of these I am going to assemble myself. If they sell good, I will start having the board manufacturer handle the build and test process.
I will get a sheet that will need to be cut (40 or so per sheet). I plan on trying a scroll saw to cut these apart. If that doesn't work well or if I am breathing too much fiberglass, I will go to a wet saw.
Doing it this way should allow the cost to be more at the $6.00 range for the first run.
When it goes beyond this 160, I will receive completed boards ready to be sold.
