Camera Variable Overlay icon Camera Variable Overlay — Overlay image packs onto camera feed and map images to control-variable ranges with auto/manual assignment, position and sizing options. Try it →
Roomba 655 Pointers?
Hey Community!
My parents just got a Roomba, which, being a robotics person, interested me. Since I know DJ and other members have hacked roombas, I was curious if there were any pointers people may have, such as the hack itself, or code, or other innovative ideas they've had with there Roomba. But firstly, does the 655 work with the hack?
Thanks, Tech
LOL... I used to work part time for the depot... I know very well that they sell Lexan sheets... Problem is, they don't sell round Lexan or poly carbonate....
Build a robot that can hold a laser cutter or dremel, get the robot to cut it to a perfect circle, that wouldn't be too difficult to do with a little EZ-Script:)
@Rich... What's the formula....? Pi r2 something, something?..... Sounds like some serious math.... :P I think I might be able to do it free hand...:D
I think there is an example in the examples for a circle.
Easy way though... secure a modified servo to the centre of the sheet. Build an arm the correct radius with the cutting device on the end of it, let the modified servo spin around. No maths needed:D (I'm currently designing something similar using EZ-Bits)
Now, If I happened to wire the connector wrong, is the Roomba safe? or would the Roomba go "caput"?
#16
Yes, you must be careful when wiring the 7 pin min din leads. The full battery potential is present on several pins. Look at this picture for guidance.
