SSC-32 Servo Controller icon SSC-32 Servo Controller — ARC integration for SSC-32 servo controllers via PC COM or EZ-B/Arduino UART; maps V0-V31, configurable baud, enables servos in ARC skills. Try it →
Robot Arm Designs
Robot Arm Designs
Anyone interested in creating a team to brain storm ideas and designs for robot arms for large or small robots. Perhaps collectively we could come up with a universal design that many of us could use. We each could provide input, drawings and/or services.
Rex
#81
Loki looks pre-scripted. The video skips a lot per take to get it right I think:)
#82
all software and hardware on main website
#83
I also got that impression...but was hoping....anyway...
DJ any updates on Synthia?
There I go again... getting off topic of my own thread :P
#84
Back to topic, I am working on my arms for B9 and the design may be good for small bots. I'll post images/videos after I get the kinks worked out.
#85
Thanks for sewing the thread back into the topic :D If I don't get to many more"honey do" lists when I get home, I'll do my best to take pictures of my shoulder setup for Magnus. The claws I think I can create OK. The elbow is the problem.
#86
Here are some pictures of the shoulder drive mechanism and arm socket for Magnus. Please pardon the dust. Paint job is still far in the future ;)
Arm Socket that I installed into the clothes dryer drum.
Shoulder Drive Mechanism: Support structure is two 1/8" thick steel plates and a 2" x 2" steel tube pedestal. Chain drive with two pillow block bearings. 1" hollow steel tube passes through the bearings. #25 chain and associated sprockets. 12V 400 in.lb. torque motor.
Picture of the two interior decks for all my electronics and both shoulder drives.
The actual arm is a separate entity. It will mount to this disk and tube. This tube was turned down on a lathe so that it slides smoothly into the 1" tube and serves as a wire-way to the arm as well. It will have a pin (not shown in picture) that will lock it into the shoulder disc so that the arm will rotate with the shoulder. That way when I need to remove the torso all I have to do is unplug the cable harness, pull a lock pin and off pops his arm.
Holy crap that is beefy - you want Magnus to be able to lift an engine block? lol
#88
Bret... I was thinking the same thing. Oh my. He's going to be huge....
