England
Question With Wifi
Hi,
I just received my JD but can not connect it to the WIFI with my HP computer. To see if it was an issue with the EZ-B I tried to connect it to my Mac Air and it connected. Does anyone know what the issue could be?
It may be some security software on the HP computer causing the connection issue however that is just a guess.
Do you intend on using it in AP mode (direct connection) or can you use it in client mode (it connects to your home wifi)?
Personally I would do the following;
  1. Connect with the Mac Air (as we know this works)
  2. Open your web browser and go to 192.168.1.1
  3. It should present you with the configuration pages
  4. Click on WiFi Client Mode on the left
  5. You should get the configuration page for Client mode
  6. Fill in the SSID (Your home wifi name) and security key (password) - Note, these are case sensitive.
  7. Click connect
  8. The EZ-B should reset and then announce that it is connected to the network
  9. On the HP computer load up ARC
  10. In the connection box in the top left of the screen click on the scan button
  11. On the dialogue which pops up click start scan
  12. It should now scan your network for EZ-B V4s. They will be listed when found.
  13. Once it finds it, click on the IP under Found IPs then select, this will change the connection box for you
  14. Back up in the connection box in the top left click on connect
  15. The EZ-B should chime to indicate connection is established and ARC should report that it is connected.
@Rich... This is a really good tutorial.... It would be great if you could somehow host it or make it a permanent link... You might have to slightly modify it for the average user (because of the Mac reference)... Nevertheless it's a very easy to follow and understand how to....
Like this?
Haven't read that one for a while and my memory is fuzzy but it should go over how to change to client mode.
@Rich Thanks! one other quick question (sorry I'm kind of new to this) how long does it take to charge the battery as i have left it plugged in for three hours with the robot off and it still says it has low battery
If using the EZ-Robot balance charger and power supply it should take around an hour an 15 minutes to charge. There was a report of another battery saying it's still charging.
I had a similar issue however turning the robot on while it was charging made the green light go out (I haven't needed to charge it again yet).
If you disconnect the charger and turn on the robot it should warn when the battery is low.
If you have a multimeter you can test the voltage between the outside 2 pins of the balance plug (the part that connects to the charger), it should be a little above 8v if fully charged.
Thanks. if the battery doesn't work would you say that it is the battery balancer that doesn't work and i will need to get a new one. also just to check that the robot is plugged into the 2 cell plug. i just can't see why it wont work. ill leave it for an hour and 15 and see what happens.
My Six had some charge in it when it turned up. Have you built the JD yet? Does the EZ-B V4 make any noise if you turn it on?
My JD arrived 2 days ago and it had charge. I have assembled it and the EZ-B made the right noises when switched on. I have now unfortunately used up its power
What happens to the green light if you turn it on while it's on charge?
If you can connect the EZ-B to ARC you can also get a voltage reading from that (if you have done the above configuration change).
Provided you don't pull more than an amp while it's on you can turn it on while charging, it will just slow down the charging time. Personally, however do this at your own risk, I would turn it on, make the changes to the EZ-B configuration as above, connect ARC to the EZ-B, add the EZ-B V4 Info control which gives battery voltage, disconnect the charger and see what it reads. If it's above 8V while not doing anything it is charging OK.
Just a tip... Be careful about under-volting (not really a word but you get my meaning) a lipo battery... If you discharge them too much they die and can't come back to life... You probably have not done that yet, but just be aware of it for future reference... If the ezb4 complains it's battery is low, charge it asap.... I will leave it to Rich to help you further...
I am to the point of connecting to Wifi but I am having trouble! My computer has showed the ezb4 a few times & showed connected twice but showing limited. I cannot go to the screen showing client because it does not pick up that page! Do I need Microsoft Native Bluetooth Stack because I am not sure I have it? Also, the number is showing 192.168.1.1:23 but when I go to scan it shows 192.168.0.1. I am not educated in this type of stuff so I am pretty much lost! The tutorials don't explain what to do if something doesn't work right! Any help on this matter would be greatly appreciated.
@michaelc ...The EZB4 uses wifi, so forget anything about Bluetooth for connecting to the ezb4... Once you get the EZB4 connected to your pc (even a Limited connection as you stated), open ARC and click on the silver flying saucer looking thingy in you first control (the connection control next to the scan tool). This should bring up the ezb4 webserver.... from here you can flip your ezb into client mode... Have you viewed the video in the Learn section here on how to connect the ezb4 to your PC?
You may want to try having any software firewall configured (ie an exception rule for ARC) or turned off. This is what was causing the problem for me. I still can't figure out why the IP scanning won't work (no EZ B is found), but I figured out what IP address the EZ B was on and added it manually.
#15
Thanks Richard R & ftlum. Here is my thinking. My router is 192.168.0.1. The five connections show 192.168.1.1. I change these connections to my router but every time I go to another page & back to the connection page, the five connections are showing 192.168.1.1 again. My question is, can I take my cable directly to my computer & get JD to work? Bypass the router? I want to see JD work! I have waited a year to receive JD & I can't get him to work!
HAHA, Michael I love your energy and eagerness! HP seems to be doing something strange with their network driver which prevents connecting to EZ-B's. We are trying to nail down how to bypass the issue.
The issue appears to be that HP driver wants all network attempts to be connected to the internet. And the EZ-B is not an internet connection, so it doesn't complete the connection. We are working on trying to contact HP to find out how to bypass their strange setting.
In the meantime, I ask that you purchase a WiFi USB dongle from your local computer store. If you are in the USA, you can get one from Best Buy. All of our HP customers have been using USB WiFi modules with success.
Also, please get the latest version of ARC. Once you have installed it, use the Diagnostic Report Control and paste it in this forum thread.
Access the Diagnostic Report by...
  1. Load ARC
  2. Press Projects from the top menu
  3. Press Add Control
  4. From the General Tab, press the Diagnostic Report
  5. Once the report loads, press the COPY TO CLIPBOARD button
  6. Return to this forum and PASTE the contents of your clipboard into a message
Do not worry, there is nothing in the report that exposes your computer. It will display all installed software and driver versions. We are using these reports to compile a case against HP to have them return our calls.
Thanks!
#17
@DJ Sures I just woke up, I may have another solution! I will go try it. J:)
#18
@DJ Sures I am trying to over ride Searching DNS to force to 192.168.1.1 for EZ-B. I did this in the past, just trying to remember how I did it. C:\windows\system32\drivers\etc has the files that need to be changed.
J
#19
@DJ Sures
I was unsuccessful in getting it change searching. USB dongle is best solution for now.
J
#20
@DJ Sures, and everyone else
I now can't charge my JD. The battery in the body is now releasing quite a bad smell. Does anyone know what is happening to it?
josh, did you Contact Us about the battery issue when you created this thread?
#22
@Dj Sures No I didn't. I probably should have. Do you think it could just be a faulty battery or a problem with me charging it?
The EZ-B v4 has a built in battery protection which prevents it from being drained completely. When the battery saver kicks in, the EZ-B v4 will complain with a verbal message and shut down all I/O. This is because the LiPo batteries will be damaged if drained completely. Even though the battery saver feature can be disabled, it is not recommended. If you disabled the battery saver, the battery will be damaged and no longer hold it's charge.
If you did not disable the battery saver and it's always been acting this way, the battery might be damaged from factory. We are able to detect a battery that has been completed drained.
We are unsure if the battery is damaged or the charger is not working.
Do you know if the charger is working? We can start with a replacement battery.
#24
@Dj Sures, I don't think the charger is working. When the power cord is plugged into the mains power and the balancer charger there are no lights on. When plugged into the robot there is a very faint green light on which seems to be dimming slowly.
#25
DesktopWeatherAlerts Battle.net EPSON Connect version 1.0 EPSON Scan BodyMedia SYNC LEGO Digital Designer Call of Duty: Ghosts WildTangent Games Windows Live Essentials Tales of Lagoona Royal Envoy 2 Collector's Edition Jewel Match 3 Luxor Evolved Zuma's Revenge Plants vs. Zombies - Game of the Year Vacation Quest - Australia Delicious: Emily's Childhood Memories Premium Edition Build-a-lot Mystery P.I. - Curious Case of Counterfeit Cove House of 1000 Doors: Family Secrets Roads of Rome 3 Cradle Of Egypt Collector's Edition 4 Elements II Youda Jewel Shop Airport Mania Mah Jong Medley Bounce Symphony Mahjongg Dimensions Deluxe: Tiles in Time Governor of Poker 2 Premium Edition Cradle of Rome 2 Bejeweled 3 Azteca Peggle Nights Farm Frenzy Curse at Twilight Polar Bowler Windows Live Communications Platform Steam HP Customer Experience Enhancements Epson Event Manager Windows Live UX Platform Language Pack Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 Java 7 Update 67 Update Installer for WildTangent Games App Photo Gallery Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.60610 EpsonNet Print Recovery Manager OpenOffice 4.0.1 Java Auto Updater Windows Live UX Platform HP Quick Start Movie Maker Intel(R) Management Engine Components Windows Live PIMT Platform Hewlett-Packard ACLM.NET v1.2.2.3 WildTangent Games App (HP Games) Microsoft Visual C++ 2005 Redistributable Apple Application Support Apple Software Update Microsoft Visual C++ 2005 Redistributable Windows Live SOXE Definitions MSVCRT MSVCRT110 Microsoft Office Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.60610 BodyMedia SYNC Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17 Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161 HP MyRoom Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.60610 HP Support Information Software Updater EZ-Builder Windows Live Essentials Qualcomm Atheros Driver Installation Program Windows Live Installer Windows Live Photo Common Adobe Photoshop Lightroom Photo Common D3DX10 HP Support Assistant Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.60610 Movie Maker Microsoft SQL Server 2005 Compact Edition [ENU] Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 Intel(R) Processor Graphics Photo Gallery Intel(R) SDK for OpenCL - CPU Only Runtime Package Windows Live SOXE Battle.net EPSON Connect version 1.0 EPSON Scan BodyMedia SYNC LEGO Digital Designer Call of Duty: Ghosts WildTangent Games Windows Live Essentials Tales of Lagoona Royal Envoy 2 Collector's Edition Jewel Match 3 Luxor Evolved Zuma's Revenge Plants vs. Zombies - Game of the Year Vacation Quest - Australia Delicious: Emily's Childhood Memories Premium Edition Build-a-lot Mystery P.I. - Curious Case of Counterfeit Cove House of 1000 Doors: Family Secrets Roads of Rome 3 Cradle Of Egypt Collector's Edition 4 Elements II Youda Jewel Shop Airport Mania Mah Jong Medley Bounce Symphony Mahjongg Dimensions Deluxe: Tiles in Time Governor of Poker 2 Premium Edition Cradle of Rome 2 Bejeweled 3 Azteca Peggle Nights Farm Frenzy Curse at Twilight Polar Bowler Windows Live Communications Platform Steam HP Customer Experience Enhancements Epson Event Manager Windows Live UX Platform Language Pack Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 Java 7 Update 67 Update Installer for WildTangent Games App Photo Gallery Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.60610 EpsonNet Print Recovery Manager OpenOffice 4.0.1 Java Auto Updater Windows Live UX Platform HP Quick Start Movie Maker Intel(R) Management Engine Components Windows Live PIMT Platform Hewlett-Packard ACLM.NET v1.2.2.3 WildTangent Games App (HP Games) Microsoft Visual C++ 2005 Redistributable Apple Application Support Apple Software Update Microsoft Visual C++ 2005 Redistributable Windows Live SOXE Definitions MSVCRT MSVCRT110 Microsoft Office Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.60610 BodyMedia SYNC Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17 Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161 HP MyRoom Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.60610 HP Support Information Software Updater EZ-Builder Windows Live Essentials Qualcomm Atheros Driver Installation Program Windows Live Installer Windows Live Photo Common Adobe Photoshop Lightroom Photo Common D3DX10 HP Support Assistant Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.60610 Movie Maker Microsoft SQL Server 2005 Compact Edition [ENU] Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 Intel(R) Processor Graphics Photo Gallery Intel(R) SDK for OpenCL - CPU Only Runtime Package Windows Live SOXE
Win32_NetworkAdapter
Realtek PCIe GBE Family Controller AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000000] Realtek PCIe GBE Family Controller ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Realtek PCIe GBE Family Controller DeviceID = 0 GUID = {67FF5371-A68B-42C9-9366-02BB82BCB9C9} Index = 0 Installed = True InterfaceIndex = 3 MACAddress = 88:51:FB:60:28:A4 Manufacturer = Realtek MaxNumberControlled = 0 Name = Realtek PCIe GBE Family Controller NetConnectionID = Ethernet NetConnectionStatus = 2 NetEnabled = True PhysicalAdapter = True PNPDeviceID = PCI\VEN_10EC&DEV_8168&SUBSYS_2ADA103C&REV_07\4&5EBC025&0&00E5 PowerManagementSupported = False ProductName = Realtek PCIe GBE Family Controller ServiceName = RTL8168 Speed = 100000000 SystemCreationClassName = Win32_ComputerSystem SystemName = SKOAL TimeOfLastReset = 20140930092436.829396-300
Microsoft Kernel Debug Network Adapter Availability = 3 Caption = [00000001] Microsoft Kernel Debug Network Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft Kernel Debug Network Adapter DeviceID = 1 Index = 1 Installed = True InterfaceIndex = 2 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Microsoft Kernel Debug Network Adapter PhysicalAdapter = False PNPDeviceID = ROOT\KDNIC\0000 PowerManagementSupported = False ProductName = Microsoft Kernel Debug Network Adapter ServiceName = kdnic SystemCreationClassName = Win32_ComputerSystem SystemName = SKOAL TimeOfLastReset = 20140930092436.829396-300
Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000002] Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter DeviceID = 2 GUID = {BF8A479F-65EF-4FF7-B25B-03B827BD3250} Index = 2 Installed = True InterfaceIndex = 4 MACAddress = 24:FD:52:14:3A:E6 Manufacturer = Qualcomm Atheros Communications Inc. MaxNumberControlled = 0 Name = Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter NetConnectionID = Wi-Fi NetConnectionStatus = 2 NetEnabled = True PhysicalAdapter = True PNPDeviceID = PCI\VEN_168C&DEV_0032&SUBSYS_1838103C&REV_01\4&AB30070&0&00E1 PowerManagementSupported = False ProductName = Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter ServiceName = athr Speed = 97500000 SystemCreationClassName = Win32_ComputerSystem SystemName = SKOAL TimeOfLastReset = 20140930092436.829396-300
Microsoft Wi-Fi Direct Virtual Adapter AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000007] Microsoft Wi-Fi Direct Virtual Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft Wi-Fi Direct Virtual Adapter DeviceID = 7 Index = 7 Installed = True InterfaceIndex = 5 MACAddress = 16:FD:52:14:3A:E6 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Microsoft Wi-Fi Direct Virtual Adapter PhysicalAdapter = False PNPDeviceID = {5D624F94-8850-40C3-A3FA-A4FD2080BAF3}\VWIFIMP_WFD\5&54028C6&0&03 PowerManagementSupported = False ProductName = Microsoft Wi-Fi Direct Virtual Adapter ServiceName = vwifimp Speed = 9223372036854775807 SystemCreationClassName = Win32_ComputerSystem SystemName = SKOAL TimeOfLastReset = 20140930092436.829396-300
WAN Miniport (SSTP) Availability = 3 Caption = [00000008] WAN Miniport (SSTP) CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (SSTP) DeviceID = 8 Index = 8 Installed = True InterfaceIndex = 6 MaxNumberControlled = 0 Name = WAN Miniport (SSTP) PhysicalAdapter = False PowerManagementSupported = False ProductName = WAN Miniport (SSTP) SystemCreationClassName = Win32_ComputerSystem SystemName = SKOAL TimeOfLastReset = 20140930092436.829396-300
WAN Miniport (PPTP) Availability = 3 Caption = [00000009] WAN Miniport (PPTP) CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (PPTP) DeviceID = 9 Index = 9 Installed = True InterfaceIndex = 7 MaxNumberControlled = 0 Name = WAN Miniport (PPTP) PhysicalAdapter = False PowerManagementSupported = False ProductName = WAN Miniport (PPTP) SystemCreationClassName = Win32_ComputerSystem SystemName = SKOAL TimeOfLastReset = 20140930092436.829396-300
WAN Miniport (PPPOE) Availability = 3 Caption = [00000010] WAN Miniport (PPPOE) CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (PPPOE) DeviceID = 10 Index = 10 Installed = True InterfaceIndex = 8 MaxNumberControlled = 0 Name = WAN Miniport (PPPOE) PhysicalAdapter = False PowerManagementSupported = False ProductName = WAN Miniport (PPPOE) SystemCreationClassName = Win32_ComputerSystem SystemName = SKOAL TimeOfLastReset = 20140930092436.829396-300
WAN Miniport (IKEv2) Availability = 3 Caption = [00000011] WAN Miniport (IKEv2) CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (IKEv2) DeviceID = 11 Index = 11 Installed = True InterfaceIndex = 9 MaxNumberControlled = 0 Name = WAN Miniport (IKEv2) PhysicalAdapter = False PowerManagementSupported = False ProductName = WAN Miniport (IKEv2) SystemCreationClassName = Win32_ComputerSystem SystemName = SKOAL TimeOfLastReset = 20140930092436.829396-300
WAN Miniport (L2TP) Availability = 3 Caption = [00000012] WAN Miniport (L2TP) CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (L2TP) DeviceID = 12 Index = 12 Installed = True InterfaceIndex = 10 MaxNumberControlled = 0 Name = WAN Miniport (L2TP) PhysicalAdapter = False PowerManagementSupported = False ProductName = WAN Miniport (L2TP) SystemCreationClassName = Win32_ComputerSystem SystemName = SKOAL TimeOfLastReset = 20140930092436.829396-300
WAN Miniport (IP) Availability = 3 Caption = [00000013] WAN Miniport (IP) CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (IP) DeviceID = 13 Index = 13 Installed = True InterfaceIndex = 11 MaxNumberControlled = 0 Name = WAN Miniport (IP) PhysicalAdapter = False PowerManagementSupported = False ProductName = WAN Miniport (IP) SystemCreationClassName = Win32_ComputerSystem SystemName = SKOAL TimeOfLastReset = 20140930092436.829396-300
WAN Miniport (IPv6) Availability = 3 Caption = [00000014] WAN Miniport (IPv6) CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (IPv6) DeviceID = 14 Index = 14 Installed = True InterfaceIndex = 12 MaxNumberControlled = 0 Name = WAN Miniport (IPv6) PhysicalAdapter = False PowerManagementSupported = False ProductName = WAN Miniport (IPv6) SystemCreationClassName = Win32_ComputerSystem SystemName = SKOAL TimeOfLastReset = 20140930092436.829396-300
WAN Miniport (Network Monitor) Availability = 3 Caption = [00000015] WAN Miniport (Network Monitor) CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (Network Monitor) DeviceID = 15 Index = 15 Installed = True InterfaceIndex = 13 MaxNumberControlled = 0 Name = WAN Miniport (Network Monitor) PhysicalAdapter = False PowerManagementSupported = False ProductName = WAN Miniport (Network Monitor) SystemCreationClassName = Win32_ComputerSystem SystemName = SKOAL TimeOfLastReset = 20140930092436.829396-300
Win32_NetworkAdapterConfiguration
\SKOAL\root\cimv2:Win32_NetworkAdapterConfiguration.Index=0 Caption = [00000000] Realtek PCIe GBE Family Controller DatabasePath = %SystemRoot%\System32\drivers\etc DefaultIPGateway = 192.168.0.1 fe80::226:5aff:fec6:870b Description = Realtek PCIe GBE Family Controller DHCPEnabled = True DHCPLeaseExpires = 20141012193728.000000-300 DHCPLeaseObtained = 20141005193728.000000-300 DHCPServer = 192.168.0.1 DNSDomain = murray-ky.net DNSDomainSuffixSearchOrder = murray-ky.net DNSEnabledForWINSResolution = False DNSHostName = Skoal DNSServerSearchOrder = 192.168.0.1 DomainDNSRegistrationEnabled = False FullDNSRegistrationEnabled = True GatewayCostMetric = 0 256 Index = 0 InterfaceIndex = 3 IPAddress = 192.168.0.100 fe80::bc84:6ce8:c299:f0e IPConnectionMetric = 20 IPEnabled = True IPFilterSecurityEnabled = False IPSecPermitIPProtocols = IPSecPermitTCPPorts = IPSecPermitUDPPorts = IPSubnet = 255.255.255.0 64 MACAddress = 88:51:FB:60:28:A4 ServiceName = RTL8168 SettingID = {67FF5371-A68B-42C9-9366-02BB82BCB9C9} TcpipNetbiosOptions = 0 WINSEnableLMHostsLookup = True
\SKOAL\root\cimv2:Win32_NetworkAdapterConfiguration.Index=1 Caption = [00000001] Microsoft Kernel Debug Network Adapter Description = Microsoft Kernel Debug Network Adapter DHCPEnabled = True Index = 1 InterfaceIndex = 2 IPEnabled = False ServiceName = kdnic SettingID = {8718928D-CBEB-45EA-A621-800A9249001D}
\SKOAL\root\cimv2:Win32_NetworkAdapterConfiguration.Index=2 Caption = [00000002] Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter DatabasePath = %SystemRoot%\System32\drivers\etc DefaultIPGateway = 192.168.0.1 fe80::226:5aff:fec6:870b Description = Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter DHCPEnabled = True DHCPLeaseExpires = 20141012193727.000000-300 DHCPLeaseObtained = 20141005193727.000000-300 DHCPServer = 192.168.0.1 DNSDomain = murray-ky.net DNSDomainSuffixSearchOrder = murray-ky.net DNSEnabledForWINSResolution = False DNSHostName = Skoal DNSServerSearchOrder = 192.168.0.1 DomainDNSRegistrationEnabled = False FullDNSRegistrationEnabled = True GatewayCostMetric = 0 256 Index = 2 InterfaceIndex = 4 IPAddress = 192.168.0.101 fe80::2c4f:7d6c:6c86:c835 IPConnectionMetric = 25 IPEnabled = True IPFilterSecurityEnabled = False IPSecPermitIPProtocols = IPSecPermitTCPPorts = IPSecPermitUDPPorts = IPSubnet = 255.255.255.0 64 MACAddress = 24:FD:52:14:3A:E6 ServiceName = athr SettingID = {BF8A479F-65EF-4FF7-B25B-03B827BD3250} TcpipNetbiosOptions = 0 WINSEnableLMHostsLookup = True
\SKOAL\root\cimv2:Win32_NetworkAdapterConfiguration.Index=7 Caption = [00000007] Microsoft Wi-Fi Direct Virtual Adapter Description = Microsoft Wi-Fi Direct Virtual Adapter DHCPEnabled = True Index = 7 InterfaceIndex = 5 IPEnabled = False MACAddress = 16:FD:52:14:3A:E6 ServiceName = vwifimp SettingID = {11E3F9B0-84A5-4272-AD09-F338F5F181D1}
\SKOAL\root\cimv2:Win32_NetworkAdapterConfiguration.Index=8 Caption = [00000008] WAN Miniport (SSTP) Description = WAN Miniport (SSTP) DHCPEnabled = False Index = 8 InterfaceIndex = 6 IPEnabled = False ServiceName = RasSstp SettingID = {66FAA1C2-543E-4882-ADB9-7315064AFFFA}
\SKOAL\root\cimv2:Win32_NetworkAdapterConfiguration.Index=9 Caption = [00000009] WAN Miniport (PPTP) Description = WAN Miniport (PPTP) DHCPEnabled = False Index = 9 InterfaceIndex = 7 IPEnabled = False ServiceName = PptpMiniport SettingID = {2D2B4E40-0F7B-430D-8908-21B4111B7D84}
\SKOAL\root\cimv2:Win32_NetworkAdapterConfiguration.Index=10 Caption = [00000010] WAN Miniport (PPPOE) Description = WAN Miniport (PPPOE) DHCPEnabled = False Index = 10 InterfaceIndex = 8 IPEnabled = False ServiceName = RasPppoe SettingID = {12FDE4E9-08AB-40D9-B7B8-D2AA6BC1CE97}
\SKOAL\root\cimv2:Win32_NetworkAdapterConfiguration.Index=11 Caption = [00000011] WAN Miniport (IKEv2) Description = WAN Miniport (IKEv2) DHCPEnabled = False Index = 11 InterfaceIndex = 9 IPEnabled = False ServiceName = RasAgileVpn SettingID = {C953C2CD-855E-45C4-A971-D1A66868C0BF}
\SKOAL\root\cimv2:Win32_NetworkAdapterConfiguration.Index=12 Caption = [00000012] WAN Miniport (L2TP) Description = WAN Miniport (L2TP) DHCPEnabled = False Index = 12 InterfaceIndex = 10 IPEnabled = False ServiceName = Rasl2tp SettingID = {F71DB464-5F0C-4CC1-81BF-A9044890F151}
\SKOAL\root\cimv2:Win32_NetworkAdapterConfiguration.Index=13 Caption = [00000013] WAN Miniport (IP) Description = WAN Miniport (IP) DHCPEnabled = False Index = 13 InterfaceIndex = 11 IPEnabled = False ServiceName = NdisWan SettingID = {06216914-9272-4171-8C54-60D74BE8AB7E}
\SKOAL\root\cimv2:Win32_NetworkAdapterConfiguration.Index=14 Caption = [00000014] WAN Miniport (IPv6) Description = WAN Miniport (IPv6) DHCPEnabled = False Index = 14 InterfaceIndex = 12 IPEnabled = False ServiceName = NdisWan SettingID = {BEB93BE4-1E42-4B4D-95BF-59134ACE52E4}
\SKOAL\root\cimv2:Win32_NetworkAdapterConfiguration.Index=15 Caption = [00000015] WAN Miniport (Network Monitor) Description = WAN Miniport (Network Monitor) DHCPEnabled = False Index = 15 InterfaceIndex = 13 IPEnabled = False ServiceName = NdisWan SettingID = {36379D5B-D822-4658-9F1C-37A866689819}
SKOAL AdminPasswordStatus = 3 AutomaticManagedPagefile = True AutomaticResetBootOption = True AutomaticResetCapability = True BootROMSupported = True BootupState = Normal boot Caption = SKOAL ChassisBootupState = 3 CreationClassName = Win32_ComputerSystem CurrentTimeZone = -300 DaylightInEffect = True Description = AT/AT COMPATIBLE DNSHostName = Skoal Domain = WORKGROUP DomainRole = 0 EnableDaylightSavingsTime = True FrontPanelResetStatus = 3 HypervisorPresent = False InfraredSupported = False KeyboardPasswordStatus = 3 Manufacturer = Hewlett-Packard Model = 500-023w Name = SKOAL NetworkServerModeEnabled = True NumberOfLogicalProcessors = 4 NumberOfProcessors = 1 OEMStringArray = FBYTE#2U333E3K3N3Q3a4k5c6J6S6Z6b7B7K7M7Q7T7W9Sa3aJapaqasauazb3bc bhbp.ND;BUILDID#13AM2RR8604#SABA#DABA;
PartOfDomain = False PauseAfterReset = -1 PCSystemType = 1 PCSystemTypeEx = 1 PowerOnPasswordStatus = 3 PowerState = 0 PowerSupplyState = 3 PrimaryOwnerName = [email protected] ResetCapability = 1 ResetCount = -1 ResetLimit = -1 Roles = LM_Workstation LM_Server NT Potential_Browser Master_Browser Status = OK SystemType = x64-based PC ThermalState = 3 TotalPhysicalMemory = 8469192704 UserName = Skoal\SKOAL\micha_000 WakeUpType = 6 Workgroup = WORKGROUP
Thanks @Michaelc would you be able to quickly grab a couple screenshots?
Under device manager -> networks adapters -> right click on the Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter and select properties. Once you are in the properties menu could you take a screenshot of the "Advanced" and "Driver" tabs and post them here?
Thanks!
#27
his primary nic is looking at this network not the ez-b v4 network that is 192.168.1.1.
@dj sures knows how I fix this with a work around.
If dj is not there...
send me e-mail jdebay @ yahoo.com...
then I will call Ez-robot with an explainatin what to do.
j
jdebay, are you saying that you have figured out the HP WiFi connection issue? Is the DHCP the issue?! That's great if it is! Tell me more
#29
Sorry to change the subject, but @DJ Sures should I just contact you and then should I talk about replacing the JD body and/or the battery?
Hi @joshcd2000 please use the Contact Us page and reference the thread that DJ helped you with. We'll get that battery looked after as soon as we can.
#31
@dj sures
yes i have a work around, but I need to tell you how and I left a message on the ez-robot answering machine.
j
#32
@jdebay.... Why don't you lay out your fix here? I am sure us HP users and EZ Robot would greatly appreciate it....
#33
Richard it is a long answer.
I would tell them and they can write up an how to do it. I am not the best at writing... lol
This is only a work around solution for hp/compaq owners who have two nic's, one a wired connection and second one is a wifi nic, connection. DNS is getting confused when trying to find the EZ-B. And it times out. Says unable to connect.
It requires that they disable the wired connection and the wifi connection. Maybe you could write it up?
Also requires that they have or purchase a usb wifi for their hp/compaq personal computer OR use another pc or laptop to set the EZ-B in client mode.
I have test this on my HP system and it worked. But I need another person who has an HP/Compaq to try the work around.
J
#34
Sorry, I don't know how to take a screenshot. About my Qualcomm Atheros AR9485 802.11b/g/n Wifi Adapter
Advanced
Property: 802.11b Preamble AdHoc Mode Network Address Receive Buffers Scan Valid Interval Transmit Buffers
Value: Long & Short Long Only
Driver
Driver Provider: Qualcomm Atheros Communication Inc.
Driver Date: 5/16/2013
Driver Version: 10.0.0.251
Digital Signer: Microsoft Windows Hardware Compatibility Publisher
Thanks again Michael,
What are the values for 802.11b Preamble (long and short?) and AdHoc Mode (disabled?)
Have you tried to Update your Driver for your WiFi Adapter? (right click on Qualcomm Atheros AR9485 802.11b/g/n Wifi Adapter in the device manager and select update driver)
What version of windows do you have? Is it 32 or 64 bit?
In the Device manager are there any yellow exclamation marks on your WAN Mini-port network adapters?
For the last check you may have to select the View tab in the Device Manager and click on "Show Hidden Devices"
Michael, for screenshots in Windows 8, follow these directions
  1. Press the Windows Key + PRNTSCREEN buttons together. On a laptop, PRINTSCREEN can be labelled PRTSC and is normally located on the top right near the delete key
  2. The screen will flash when you press that key combination
  3. In this forum, press the ATTACH FILE -> BROWSE button. Navigate to your My Pictures folder and look in the SCREENSHOTS folder
  4. Select the screenshot that was saved
  5. Press the UPLOAD FILE button on this forum
  6. Type your message
  7. Press the REPLY button to submit your post
#38
I just updated my driver. 802.11b Preamble - Long & short AdHoc Mode - 11b Operating system - Windows 8.1, 64-bit No exclamation marks Cannot find any hidden devices router is not taking my password in ARC.
Can you explain what you mean by "router is not taking my password in ARC"?
#40
I put in 192.168.0.1 on the first connection. I then hit the round button to go to client mode & my d-link comes up wanting to know my password. When I type in the password, it will not take it. I'm going to try resetting the password tomorrow. Maybe I'm using the wrong password.
#41
@Jeremie i will thanks thanks everyone for your help!
#42
@michaelc,
You are entering the IP address of your router, not your EZ-B, which is why you are being prompted for a router password. I suggest you watch the tutorial videos in lessons 3 and 4 under "EZ-B v4 Robot Brain" in the Learn page to understand how to connect ARC to your EZ-B.
Hey @michaelc thanks for the info:
I was wondering a couple things, could you try and temporarily change Adhoc mode to 11g if possible and try testing your connection to the EZ-B with that setting?
Otherwise, what do your network adapter power settings look like?
Are they set to maximum like this?
11g & 11n did not work. Everything is showing balanced. My Power Saving Mode only shows Setting & it is at Maximum Performance
Thanks for checking that @Michaelc I am running out of ideas, these HP computers are giving me a run for my money, anyone else got any other thoughts?
If you need to get up and running quickly I would suggest either using Client mode or purchasing a USB WiFi dongle.
There's an excellent step by step text based tutorial on the forums for connecting your EZ-B in client mode. It's written by @Rich: here
Otherwise we have a video in the Learn section and I believe that @TechnoPro has a video as well.
If you'd like to keep on troubleshooting AP (Adhoc) mode with your HP laptop I'll do my best to keep researching but I'm not sure if I can come up with things to try everyday, it may continue to be a work in progress.
Edit: I forgot to suggest that you can use another WiFi device to setup the client mode connection if you'd like, just like @Rich suggested at the start of this thread. Then you can go back to using ARC with your HP laptop.
#46
@Jeremie
When my Roli and dev kit arrive, I expect to have this issue with my work laptop (an HP, and as a networking expert, I should be able to help determine if it is fixable without an update from HP.
I gave you EZ-Robot a work around.
HP is get confused on DNS search for the EZB.
I have been networking PC's since the beginning of PC's.
The Nic controller of HP and their software will not search a second nic wifi, if it is using hp drivers. Only HP can fix that. PERIOD. I tired everything that I know to make it work.
I left you a message on your answering machine (EZ-Robot) to contact me.
BUT you EZ-Robot INC would not call me.
I use my HP each day to access the internet and use an USB wifi (2) to connect to my EZB's in AP mode. I have tested this every day since some time last week. But know one is will to listen to me. I keep here the same thing in this thread too.
USE A USB BY OTHER COMPANY BESIDES HP. AND IT WORKS...
I use an Netgear USB... It works.
But before I can connect in AP mode. I have to disable the HP nic's both of them.
Then connect to EZB via Netgear USB. It works. Then start ARC and do what every. Do you need me to make a video?
I love my EZ-Robots.
I have three work this way and I am working on a fourth one which I already tested and accessed this EZB in the AP mode. Also tested the other EZB V4 07F3 JD robot too and works fine. So that is five robots working this way.
J stress stress stress stress
Hi @jdebay sorry we didn't call, we just haven't had much of a chance to converse with our customer support team who took the message.
I wasn't aware that you would have to disable the on-board NIC and Wireless Cards on the HP computer when adding a USB WiFi dongle, thanks for that!
#49
Thanks everyone for your help on the HP issue. I have tried two different Wifi USB's with no luck. Jeremie, if you could make that video or explain to me about turning off my Wifi on my computer, maybe I can get my Netgear Wifi USB working. Next, I am going to a different computer that will not be an HP! I see with all of the questions on calibrating servos that I have a lot to learn once I get JD working! One day I will succeed! My computer has Windows 8.1 & 64 bit which I wished I hadn't bought. One USB says it's compatiable with Windows 8.1 Pro but not Windows 8.1. I want to thank all of the ez- robot employees because I know they are working around the clock to get everyones purchase working.
#50
@michaeic I will make a video in the am. how disable the hp nic's. and use the usb wifi with ARC.
i have an hp envy 23 touchsmart pc, running windows 8.1 64bits os.
j
#51
@jdebay.... I have the exact same 23" touchsmart HP as you without any connection issues whatsoever...
Edit Mine is actually a Pavilion 23
hmmm Maybe both you guys, @jdebay and @Richard R, can use the ARC diagnostic tool (under controls -> General) and share your WiFi Adapter diagnostics and we can compare!
#53
Here you go Jeremie... (Actually my PC is a HP Pavilion 23) I have 5 ezb4 boards all connect flawlessly in wp or client mode... I have not experienced any disconnects that I didn't cause myself....
Start Menu Arduino CyberLink YouCam CyberLink Media Suite 10 CyberLink Power2Go 8 HP SimplePass Cyberlink PhotoDirector CyberLink PowerDirector 10 CyberLink PowerDVD 12 Pinger CyberLink YouCam HP Customer Experience Enhancements CereVoice SAPI CereVoice William 3.1.0 Evernote v. 5.1.1 Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 CyberLink Media Suite 10 CyberLink Power2Go 8 Cyberlink PhotoDirector Recovery Manager Realtek Card Reader Intel(R) Management Engine Components Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.51106 Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.51106 Hewlett-Packard ACLM.NET v1.2.2.3 Microsoft Visual C++ 2005 Redistributable HP Documentation Microsoft Visual C++ 2005 Redistributable Realtek Ethernet Controller Driver HP Support Assistant Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.51106 Microsoft Office Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17 Pinger CyberLink PowerDirector 10 HP Support Information CyberLink PowerDVD 12 EZ-Builder Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.51106 Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 Intel(R) Processor Graphics Realtek High Definition Audio Driver Energy Star Arduino CyberLink YouCam CyberLink Media Suite 10 CyberLink Power2Go 8 HP SimplePass Cyberlink PhotoDirector CyberLink PowerDirector 10 CyberLink PowerDVD 12 Pinger CyberLink YouCam HP Customer Experience Enhancements CereVoice SAPI CereVoice William 3.1.0 Evernote v. 5.1.1 Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 CyberLink Media Suite 10 CyberLink Power2Go 8 Cyberlink PhotoDirector Recovery Manager Realtek Card Reader Intel(R) Management Engine Components Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.51106 Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.51106 Hewlett-Packard ACLM.NET v1.2.2.3 Microsoft Visual C++ 2005 Redistributable HP Documentation Microsoft Visual C++ 2005 Redistributable Realtek Ethernet Controller Driver HP Support Assistant Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.51106 Microsoft Office Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17 Pinger CyberLink PowerDirector 10 HP Support Information CyberLink PowerDVD 12 EZ-Builder Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.51106 Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 Intel(R) Processor Graphics Realtek High Definition Audio Driver Energy Star
Broadcom BCM943228HMB 802.11abgn 2x2 Wi-Fi Adapter AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000000] Broadcom BCM943228HMB 802.11abgn 2x2 Wi-Fi Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Broadcom BCM943228HMB 802.11abgn 2x2 Wi-Fi Adapter DeviceID = 0 GUID = {292B1C34-3949-4D42-8DED-1C369E14C38C} Index = 0 Installed = True InterfaceIndex = 3 MACAddress = B8:EE:65:77:22:04 Manufacturer = Broadcom MaxNumberControlled = 0 Name = Broadcom BCM943228HMB 802.11abgn 2x2 Wi-Fi Adapter NetConnectionID = Wi-Fi NetConnectionStatus = 2 NetEnabled = True PhysicalAdapter = True PNPDeviceID = PCI\VEN_14E4&DEV_4359&SUBSYS_2135103C&REV_00\000065FFFF77B8EE00 PowerManagementSupported = False ProductName = Broadcom BCM943228HMB 802.11abgn 2x2 Wi-Fi Adapter ServiceName = BCM43XX Speed = 182500000 SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
Microsoft Kernel Debug Network Adapter Availability = 3 Caption = [00000001] Microsoft Kernel Debug Network Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft Kernel Debug Network Adapter DeviceID = 1 Index = 1 Installed = True InterfaceIndex = 2 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Microsoft Kernel Debug Network Adapter PhysicalAdapter = False PNPDeviceID = ROOT\KDNIC\0000 PowerManagementSupported = False ProductName = Microsoft Kernel Debug Network Adapter ServiceName = kdnic SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
Realtek PCIe GBE Family Controller AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000002] Realtek PCIe GBE Family Controller ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Realtek PCIe GBE Family Controller DeviceID = 2 GUID = {8657D8F8-0329-4673-992E-8DD3DC337701} Index = 2 Installed = True InterfaceIndex = 4 MACAddress = 00:25:AB:53:A6:87 Manufacturer = Realtek MaxNumberControlled = 0 Name = Realtek PCIe GBE Family Controller NetConnectionID = Ethernet NetConnectionStatus = 7 NetEnabled = False PhysicalAdapter = True PNPDeviceID = PCI\VEN_10EC&DEV_8168&SUBSYS_2B0D103C&REV_0C\0100000000AB250000 PowerManagementSupported = False ProductName = Realtek PCIe GBE Family Controller ServiceName = RTL8168 Speed = 9223372036854775807 SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
Microsoft Wi-Fi Direct Virtual Adapter AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000003] Microsoft Wi-Fi Direct Virtual Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft Wi-Fi Direct Virtual Adapter DeviceID = 3 Index = 3 Installed = True InterfaceIndex = 5 MACAddress = BA:EE:65:77:22:04 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Microsoft Wi-Fi Direct Virtual Adapter PhysicalAdapter = False PNPDeviceID = {5D624F94-8850-40C3-A3FA-A4FD2080BAF3}\VWIFIMP_WFD\5&2A57E707&0&01 PowerManagementSupported = False ProductName = Microsoft Wi-Fi Direct Virtual Adapter ServiceName = vwifimp Speed = 9223372036854775807 SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
Bluetooth Device (Personal Area Network) #2 AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000005] Bluetooth Device (Personal Area Network) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Bluetooth Device (Personal Area Network) DeviceID = 5 GUID = {96C778A9-808A-4217-BA67-7C82C4E49A62} Index = 5 Installed = True InterfaceIndex = 9 MACAddress = B8:EE:65:56:66:01 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Bluetooth Device (Personal Area Network) #2 NetConnectionID = Bluetooth Network Connection 2 NetConnectionStatus = 7 NetEnabled = False PhysicalAdapter = True PNPDeviceID = BTH\MS_BTHPAN\6&A1F97B8&0&2 PowerManagementSupported = False ProductName = Bluetooth Device (Personal Area Network) ServiceName = BthPan Speed = 3000000 SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
Bluetooth Device (Personal Area Network) Availability = 3 Caption = [00000006] Bluetooth Device (Personal Area Network) CreationClassName = Win32_NetworkAdapter Description = Bluetooth Device (Personal Area Network) DeviceID = 6 Index = 6 Installed = True InterfaceIndex = 6 MaxNumberControlled = 0 Name = Bluetooth Device (Personal Area Network) PhysicalAdapter = False PowerManagementSupported = False ProductName = Bluetooth Device (Personal Area Network) SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
Microsoft ISATAP Adapter AdapterType = Tunnel AdapterTypeId = 15 Availability = 3 Caption = [00000008] Microsoft ISATAP Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft ISATAP Adapter DeviceID = 8 Index = 8 Installed = True InterfaceIndex = 10 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Microsoft ISATAP Adapter PhysicalAdapter = False PNPDeviceID = SWD\IP_TUNNEL_VBUS\ISATAP_0 PowerManagementSupported = False ProductName = Microsoft ISATAP Adapter ServiceName = tunnel Speed = 100000 SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
Teredo Tunneling Pseudo-Interface AdapterType = Tunnel AdapterTypeId = 15 Availability = 3 Caption = [00000009] Microsoft Teredo Tunneling Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft Teredo Tunneling Adapter DeviceID = 9 Index = 9 Installed = True InterfaceIndex = 11 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Teredo Tunneling Pseudo-Interface PhysicalAdapter = False PNPDeviceID = SWD\IP_TUNNEL_VBUS\TEREDO_TUNNEL_DEVICE PowerManagementSupported = False ProductName = Microsoft Teredo Tunneling Adapter ServiceName = tunnel Speed = 100000 SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
WAN Miniport (SSTP) Availability = 3 Caption = [00000012] WAN Miniport (SSTP) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (SSTP) DeviceID = 12 Index = 12 Installed = True InterfaceIndex = 12 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (SSTP) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_SSTPMINIPORT PowerManagementSupported = False ProductName = WAN Miniport (SSTP) ServiceName = RasSstp SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
WAN Miniport (IKEv2) Availability = 3 Caption = [00000013] WAN Miniport (IKEv2) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (IKEv2) DeviceID = 13 Index = 13 Installed = True InterfaceIndex = 13 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (IKEv2) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_AGILEVPNMINIPORT PowerManagementSupported = False ProductName = WAN Miniport (IKEv2) ServiceName = RasAgileVpn SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
WAN Miniport (PPPOE) Availability = 3 Caption = [00000014] WAN Miniport (PPPOE) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (PPPOE) DeviceID = 14 Index = 14 Installed = True InterfaceIndex = 14 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (PPPOE) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_PPPOEMINIPORT PowerManagementSupported = False ProductName = WAN Miniport (PPPOE) ServiceName = RasPppoe SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
WAN Miniport (PPTP) Availability = 3 Caption = [00000015] WAN Miniport (PPTP) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (PPTP) DeviceID = 15 Index = 15 Installed = True InterfaceIndex = 15 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (PPTP) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_PPTPMINIPORT PowerManagementSupported = False ProductName = WAN Miniport (PPTP) ServiceName = PptpMiniport SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
WAN Miniport (L2TP) Availability = 3 Caption = [00000016] WAN Miniport (L2TP) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (L2TP) DeviceID = 16 Index = 16 Installed = True InterfaceIndex = 16 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (L2TP) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_L2TPMINIPORT PowerManagementSupported = False ProductName = WAN Miniport (L2TP) ServiceName = Rasl2tp SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
WAN Miniport (IP) Availability = 3 Caption = [00000017] WAN Miniport (IP) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (IP) DeviceID = 17 Index = 17 Installed = True InterfaceIndex = 17 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (IP) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_NDISWANIP PowerManagementSupported = False ProductName = WAN Miniport (IP) ServiceName = NdisWan SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
WAN Miniport (IPv6) Availability = 3 Caption = [00000018] WAN Miniport (IPv6) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (IPv6) DeviceID = 18 Index = 18 Installed = True InterfaceIndex = 18 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (IPv6) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_NDISWANIPV6 PowerManagementSupported = False ProductName = WAN Miniport (IPv6) ServiceName = NdisWan SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
WAN Miniport (Network Monitor) Availability = 3 Caption = [00000019] WAN Miniport (Network Monitor) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (Network Monitor) DeviceID = 19 Index = 19 Installed = True InterfaceIndex = 19 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (Network Monitor) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_NDISWANBH PowerManagementSupported = False ProductName = WAN Miniport (Network Monitor) ServiceName = NdisWan SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=0 Caption = [00000000] Broadcom BCM943228HMB 802.11abgn 2x2 Wi-Fi Adapter DatabasePath = %SystemRoot%\System32\drivers\etc DefaultIPGateway = 192.168.225.1 Description = Broadcom BCM943228HMB 802.11abgn 2x2 Wi-Fi Adapter DHCPEnabled = True DHCPLeaseExpires = 20141012013130.000000-240 DHCPLeaseObtained = 20141011013130.000000-240 DHCPServer = 192.168.225.1 DNSDomainSuffixSearchOrder = DNSEnabledForWINSResolution = False DNSHostName = Robot_PC DNSServerSearchOrder = 192.168.225.1 DomainDNSRegistrationEnabled = False FullDNSRegistrationEnabled = True GatewayCostMetric = 0 Index = 0 InterfaceIndex = 3 IPAddress = 192.168.225.101 fe80::f054:47b0:8bc7:ee0e IPConnectionMetric = 25 IPEnabled = True IPFilterSecurityEnabled = False IPSecPermitIPProtocols = IPSecPermitTCPPorts = IPSecPermitUDPPorts = IPSubnet = 255.255.255.0 64 MACAddress = B8:EE:65:77:22:04 ServiceName = BCM43XX SettingID = {292B1C34-3949-4D42-8DED-1C369E14C38C} TcpipNetbiosOptions = 0 WINSEnableLMHostsLookup = True
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=1 Caption = [00000001] Microsoft Kernel Debug Network Adapter Description = Microsoft Kernel Debug Network Adapter DHCPEnabled = True Index = 1 InterfaceIndex = 2 IPEnabled = False ServiceName = kdnic SettingID = {8718928D-CBEB-45EA-A621-800A9249001D}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=2 Caption = [00000002] Realtek PCIe GBE Family Controller Description = Realtek PCIe GBE Family Controller DHCPEnabled = True Index = 2 InterfaceIndex = 4 IPEnabled = False MACAddress = 00:25:AB:53:A6:87 ServiceName = RTL8168 SettingID = {8657D8F8-0329-4673-992E-8DD3DC337701}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=3 Caption = [00000003] Microsoft Wi-Fi Direct Virtual Adapter Description = Microsoft Wi-Fi Direct Virtual Adapter DHCPEnabled = True Index = 3 InterfaceIndex = 5 IPEnabled = False MACAddress = BA:EE:65:77:22:04 ServiceName = vwifimp SettingID = {185FEE05-0224-476B-B8EE-E745BDEFCCA2}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=5 Caption = [00000005] Bluetooth Device (Personal Area Network) Description = Bluetooth Device (Personal Area Network) DHCPEnabled = True Index = 5 InterfaceIndex = 9 IPEnabled = False MACAddress = B8:EE:65:56:66:01 ServiceName = BthPan SettingID = {96C778A9-808A-4217-BA67-7C82C4E49A62}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=6 Caption = [00000006] Bluetooth Device (Personal Area Network) Description = Bluetooth Device (Personal Area Network) DHCPEnabled = True Index = 6 InterfaceIndex = 6 IPEnabled = False ServiceName = BthPan SettingID = {01DDD903-BCFD-46C7-B5A2-896E34590F89}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=8 Caption = [00000008] Microsoft ISATAP Adapter Description = Microsoft ISATAP Adapter DHCPEnabled = False Index = 8 InterfaceIndex = 10 IPEnabled = False ServiceName = tunnel SettingID = {4CF4DEA2-B12A-4015-B1FC-31547E9D4F5B}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=9 Caption = [00000009] Microsoft Teredo Tunneling Adapter Description = Microsoft Teredo Tunneling Adapter DHCPEnabled = False Index = 9 InterfaceIndex = 11 IPEnabled = False ServiceName = tunnel SettingID = {0C9A0A33-1D70-45CD-80C3-DB79C6C5F28E}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=12 Caption = [00000012] WAN Miniport (SSTP) Description = WAN Miniport (SSTP) DHCPEnabled = False Index = 12 InterfaceIndex = 12 IPEnabled = False ServiceName = RasSstp SettingID = {D6AA1B4A-82A0-42CF-AADD-9044A792922F}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=13 Caption = [00000013] WAN Miniport (IKEv2) Description = WAN Miniport (IKEv2) DHCPEnabled = False Index = 13 InterfaceIndex = 13 IPEnabled = False ServiceName = RasAgileVpn SettingID = {7703E127-FE4D-4103-A6C5-382819A7F53D}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=14 Caption = [00000014] WAN Miniport (PPPOE) Description = WAN Miniport (PPPOE) DHCPEnabled = False Index = 14 InterfaceIndex = 14 IPEnabled = False ServiceName = RasPppoe SettingID = {F5AE3CB1-EDFE-40F1-A875-22CF18DAA2C0}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=15 Caption = [00000015] WAN Miniport (PPTP) Description = WAN Miniport (PPTP) DHCPEnabled = False Index = 15 InterfaceIndex = 15 IPEnabled = False ServiceName = PptpMiniport SettingID = {4A5CB0DD-7D62-4E60-90E5-F8CE4812F1B2}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=16 Caption = [00000016] WAN Miniport (L2TP) Description = WAN Miniport (L2TP) DHCPEnabled = False Index = 16 InterfaceIndex = 16 IPEnabled = False ServiceName = Rasl2tp SettingID = {48C0E5DE-E3B8-43C2-87E4-CC52377B36D4}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=17 Caption = [00000017] WAN Miniport (IP) Description = WAN Miniport (IP) DHCPEnabled = False Index = 17 InterfaceIndex = 17 IPEnabled = False ServiceName = NdisWan SettingID = {83B74FE1-C658-44DA-AEF0-D47A7D34325B}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=18 Caption = [00000018] WAN Miniport (IPv6) Description = WAN Miniport (IPv6) DHCPEnabled = False Index = 18 InterfaceIndex = 18 IPEnabled = False ServiceName = NdisWan SettingID = {9AA117A0-689C-4CCA-9F66-3EAD6F52E0F3}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=19 Caption = [00000019] WAN Miniport (Network Monitor) Description = WAN Miniport (Network Monitor) DHCPEnabled = False Index = 19 InterfaceIndex = 19 IPEnabled = False ServiceName = NdisWan SettingID = {AFCBAC99-B0D5-48B5-9963-20D0E444F459}
ROBOT_PC AdminPasswordStatus = 0 AutomaticManagedPagefile = True AutomaticResetBootOption = True AutomaticResetCapability = True BootROMSupported = True BootupState = Normal boot Caption = ROBOT_PC ChassisBootupState = 3 CreationClassName = Win32_ComputerSystem CurrentTimeZone = -240 DaylightInEffect = True Description = AT/AT COMPATIBLE DNSHostName = Robot_PC Domain = WORKGROUP DomainRole = 0 EnableDaylightSavingsTime = True FrontPanelResetStatus = 0 HypervisorPresent = False InfraredSupported = False KeyboardPasswordStatus = 0 Manufacturer = Hewlett-Packard Model = 23-p039 Name = ROBOT_PC NetworkServerModeEnabled = True NumberOfLogicalProcessors = 4 NumberOfProcessors = 1 OEMStringArray = FBYTE#3E3K3N3Q4C4h5c666J6S6Z6b7B7K7M7R7S7W7s8FaBapaqasauazb3bPbS bhbpcbcect.F3;BUILDID#14AM2ARA602#SABL#DABL;
PartOfDomain = False PauseAfterReset = -1 PCSystemType = 1 PCSystemTypeEx = 1 PowerOnPasswordStatus = 0 PowerState = 0 PowerSupplyState = 3 PrimaryOwnerName = [email protected] ResetCapability = 1 ResetCount = -1 ResetLimit = -1 Roles = LM_Workstation LM_Server NT Status = OK SystemType = x64-based PC ThermalState = 3 TotalPhysicalMemory = 8475103232 UserName = Robot_PC\ROBOT_PC\Richard WakeUpType = 6 Workgroup = WORKGROUP
#54
Mine are in this topic
synthiam.com/Community/Questions/6437 J
@Richard R
We do not have the same hardware!
This is my WiFi
\TOUCHMEPC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=2 Caption = [00000002] Ralink RT3290 802.11bgn Wi-Fi Adapter Description = Ralink RT3290 802.11bgn Wi-Fi Adapter DHCPEnabled = True Index = 2 InterfaceIndex = 4 IPEnabled = False MACAddress = A4:17:31:06:93:B7 ServiceName = netr28x SettingID = {F708FA04-0055-4157-8AE1-D1788386E149} J:D
#55
Maybe this will help? I compared my diagnostics with Richard's. I don't know what I am talking about but here was some differences. These were in the same order with Richard showing WiFi first & Mike showing Ethernet first.
Richard Mike Net Connection ID = WiFi Ethernet Net Connection Status = 2 2
Net Connection ID = Ethernet WiFi Net Connection Status = 7 2 Net Enabled = False True
Microsoft WiFi Direct Virtual Adapter Device ID = 3 7 Index = 3 7
#56
mike Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000002] Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter DeviceID = 2 GUID = {BF8A479F-65EF-4FF7-B25B-03B827BD3250} Index = 2 Installed = True InterfaceIndex = 4 MACAddress = 24:FD:52:14:3A:E6 Manufacturer = Qualcomm Atheros Communications Inc. MaxNumberControlled = 0 Name = Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter NetConnectionID = Wi-Fi NetConnectionStatus = 2 NetEnabled = True PhysicalAdapter = True PNPDeviceID = PCI\VEN_168C&DEV_0032&SUBSYS_1838103C&REV_01\4&AB30070&0&00E1 PowerManagementSupported = False ProductName = Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter ServiceName = athr Speed = 97500000 SystemCreationClassName = Win32_ComputerSystem SystemName = SKOAL TimeOfLastReset = 20140930092436.829396-300
rr Win32_NetworkAdapter
john Ralink RT3290 802.11bgn Wi-Fi Adapter AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000002] Ralink RT3290 802.11bgn Wi-Fi Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Ralink RT3290 802.11bgn Wi-Fi Adapter DeviceID = 2 GUID = {F708FA04-0055-4157-8AE1-D1788386E149} Index = 2 Installed = True InterfaceIndex = 4 MACAddress = A4:17:31:06:93:B7 Manufacturer = Ralink Technology, Corp. MaxNumberControlled = 0 Name = Ralink RT3290 802.11bgn Wi-Fi Adapter NetConnectionID = Wi-Fi NetConnectionStatus = 7 NetEnabled = False PhysicalAdapter = True PNPDeviceID = PCI\VEN_1814&DEV_3290&SUBSYS_18EC103C&REV_00\4&12E9EEF9&0&00E2 PowerManagementSupported = False ProductName = Ralink RT3290 802.11bgn Wi-Fi Adapter ServiceName = netr28x Speed = 9223372036854775807 SystemCreationClassName = Win32_ComputerSystem SystemName = TOUCHMEPC TimeOfLastReset = 20140927105616.498214-240
each of us has a different wifi that came with our hp, see above.
m
i added another usb wifi and got it working with ezb's
Again I am going to ASK do you want me to make an how to disable nic's Or not?
j
#57
Yes J, if you have the time. I am going to keep trying different things to get JD working on my HP before I switch to a different computer! Thanks.
#58
i will go through the steps then video it. Give me an hour or two to do it.
j
p.s. I will work on jd after, just finished six, that gives me 4 v4 robots and one v3 robot.and another ships next week. jad
:D
#60
I would suggest uninstalling your current drivers and replacing them with a Microsoft one or a different one. Sounds like a driver problem.
#61
@technopro
they are hp and ms latest drivers for me.
only one other thing, i tried before start to connect to ezb.
From an Command Prompt (Admin) type
ipconfig /flushdns
j:D
#62
Mike,
This my work for you!
Change Network Interface Card (NIC) Priority in Windows
Question How do I change a network card's priority in Windows? Answer You need to ensure the network cards are in the correct order of preference in which the connections are accessed by network services. To change the priority (or binding order) of network cards in Windows when multiple NICs are on a machine, follow the below steps:
  1. Select the Start button and click Control Panel.
  2. Click Network and Sharing Center.
  3. Click Change adapter settings to open the Network Connections window.
  4. Press the Alt button on your keyboard; a hidden menu will appear beneath the location bar.
  5. Select Advanced | Advanced Settings. This window displays the order of preference in which network connections are accessed by network services.
  6. Select your Local Area Connection within the Connections section of the Adapters and Bindings tab. You will see current connections listed in the order in which they are accessed by network services in the Bindings for Local Area Connection section.
  7. Use the up and down arrows to the right to change the priority of the network cards. The network card that connects to the trading environment must be listed first.
  8. Click OK.
After the above changes of bindings for local area connection, the trader’s network card remains as first priority in the connection list.
J:D
#63
Thanks J. Still no luck connecting. I have a d-link router with netgear Wifi USB. When I turn on JD, sometimes I get a Linksys network & sometimes I get a default network but never the EZ B4 network. I'll keep trying. Thanks again.
#64
mike,
Just for fun... Turn off your router. And see if you can connect to EZ-B v4 jd.
J p.s. I am in the middle of resetting up my home network, changing security. jad
#65
Three strikes & I am out. My HP will not work with JD. My laptop does not have enough frames to run ARC & my Dell computer has Vista & will also not run ARC. Looks like it's time for a new computer. I am not looking for expensive, but what specs do I need to get on a new computer that will run ARC & no HP. Does anyone have any computer recommendations? Thanks.
#66
From the software download page of ARC
Minimum Operating System Requirements Windows 7 minimum Intel Pentium or AMD 64 or 32 Bit 1 GHz CPU 2 GB RAM 50 MB Drive space
J
p.s. does your Vista system meet these requirements?
if yes then upgrade to win 7. If that is possible, let me know... I can help there. Jad
P.s. my tablet/laptop runs windows 8.1 with 2gb of memory that is what I used to set my ezb to client mode. And use ap mode for my garden-bot, since not all controls work on android yet.
Jad:D
#67
Thanks J for your help so far! I'm sure I'm going to need your help in the near future! I looked at my Vista & there was too many popups happening plus downloading Windows 7 over Vista seemed like a real task so I went out & bought a Dell 3646. I hope this computer does the trick!
#68
Is this it?
Product Features
Intel® Celeron® processor J1800 Entry-level dual-core processor for general e-mail, Internet and productivity tasks. 4GB system memory for basic multitasking Adequate high-bandwidth RAM to smoothly run multiple applications and browser tabs all at once. DVD/CD burner Reads and writes to a variety of media formats, including DVD+R/RW, DVD-R/RW and CD-R/RW. 500GB hard drive for serviceable file storage space Holds your growing collection of digital photos, music and videos. 7200 rpm spindle speed enables rapid read/write times for handling large files and complex applications. Compact design adds less bulk to your desk Tower measures 4" wide, so it fits into smaller workspaces. Built-in media reader for simple photo transfer Supports Secure Digital, Secure Digital High Capacity, SDXC, Memory Stick, Memory Stick XC, Memory Stick PRO, MultiMediaCard and MultiMediaCard Plus memory card formats. 2 USB 3.0 ports maximize the latest high-speed devices Also includes 3 USB 2.0 ports to connect more accessories and peripherals. The USB 3.0 ports are backward-compatible with USB 2.0 devices (at 2.0 speeds). Wireless and wired network connectivity Built-in high-speed wireless LAN connects to your network on the most common Wi-Fi standards. Gigabit Ethernet LAN port plugs into wired networks. Bluetooth 4.0 interface syncs with compatible devices Wirelessly transfer photos, music and other media between the laptop and your Bluetooth-enabled cell phone or MP3 player, or connect Bluetooth wireless accessories. Windows 8.1 operating system Customize your new Start screen with instant access to the things you care about most, or restore the familiar Windows desktop experience with an improved taskbar and streamlined file management. Basic software package included CyberLink Media Suite Essentials and 1-month trial of Microsoft Office. Waves MaxxAudio Tuned to give you great sound across music, movies, voice and games. (Speakers and headphones sold separately.) Additional ports HDMI output for a high-def monitor or HDTV. 1 VGA output. Audio ports for line-in and line-out. 1 headphone port and 1 microphone port. Intel, Pentium, Celeron, Core, Atom, Ultrabook, Intel Inside and the Intel Inside logo are trademarks or registered trademarks of Intel Corporation or its subsidiaries in the United States and other countries.
:D should do the job.:) j
#69
Yes, that is it. For now I am just going to use the new computer for JD. Thanks.
#71
I apologize if you see these questions somewhere else. I have started two new discussions today & I can't find them anywhere! I am going to try here. JD came with two extra long servo wires & two bundle wire wraps. I put the servo wires on the Gripper wires because they were too short. Where are these wires supposed to go & which wires are supposed to be wrapped with these bundle wraps? Last night I tried to get JD to stand for the first time. This was JD's first movement & WOW, he was actually moving. He didn't stand because one of the wires disconnected. Tonight I tried to get JD to stand & his feet ended up in the air. No wires came loose but one wire was keeping an arm from moving. I know DJ has said that he will show us how to keep the servos from disconnecting. I am looking forward to seeing this tutorial & to seeing how the wires go to keep from tangling up. My last thought is how you people post video's on this forum. I do not have a computer camera. I have an iPhone & want to download to my computer so I can put it in this forum. Any help on these matters would be greatly appreciated.
#72
@michaelc.... The tutorials are already here... Tutorials I advise you to complete them before going any further with JD...
The extra servo wires are for JD's gripper servos... The wire wraps are to be used to tidy up Jd's wiring.....
If you have a youtube account you will be able to post videos here...
#73
This is amazing. I have started 3 new discussions & threads & I have not seen them! When I pushed send it said sending. Anyway, here are my problems. Charged JD 5 1/2 hours yesterday & green light did not go out! Also, I have 90 degrees my servos, fine tuned them but JD is not working right! When I push Gorilla, the arms extend straight out but that is it! When I Wave & Think, the arms go back 90 degrees & JD falls backward! What are my problems? Thanks.
#74
michaelc, you need to start a new thread. Your questions about the JD robot are getting lost under the WiFi thread.
#75
@michaelc, when creating a new thread you must select a thread type and category. Make sure there weren't any errors trying to make a new thread. The error message pops up at the top and you might not have seen it.
There aren't currently any problems with creating new threads.
@michaelc I was just wondering if you could tell me the model number of your HP laptop? Thanks!
#77
Desktop - HP Pavilion 500-023w
