Yo DJ
I believe that the new ARC can be programed in Python? In doing some research, to try and learn a little, I found out that it comes now in two versions (2 & 3) which are not fully compatible? Is that right? If so, which should one use?
Thanks
HTTP Server
— Remote web control of ARC desktop: live screen interaction, movement control, camera list, EZ-Script/ControlCommand console with remote execution.
Yo DJ
Thanks
ARC uses Python 2: https://stackoverflow.com/questions/1093322/how-do-i-check-what-version-of-python-is-running-my-script
Also note, JavaScript is much faster than Python if you're looking at performance.
Hey Ted, how are you? Nice to see you are still around. We need more smart people on the forum. Anyway, Java is pretty straight forward. I find the best way to learn is to write scripts in Blockly, convert them to Javascript and then tweak from there...
Cheers man Richard
JavaScript != Java
:P
Me lurn berry badlee.... Thanks for pointing out my typing oversight and lack of proof reading...
.... Now I am only as smart as the Skipper and Gilligan here. ....
Now if you will excuse me, I am about to make myself a cup of java and feed my pet python.....
0==="0" false
amin++
JavaScript comparison difference between value and value/type: https://www.w3schools.com/js/js_comparisons.asp
