Midi Control icon Midi Control — MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes. Try it →
Programing  Jd
I know this must be easy but I just can't find the right settings. I want JD to just see something moving and respond with speech. I also want JD to see a color and not get confused with movement and announce it. Can these both be run at the same time? Is there and activity to help with this movement recognition? Thanks All Ron
#25
I downloaded another JD and the same thing. The Eye led activity #1 doesn't say the speech its programed to do even in the video but it does it here. The #2 activity doesn't work unless you use a different command line and still the pointed hand doesn't go down after lifted. Its either interference here or the activities don't function properly. Because I'm sure all of you did do the activities it must be interference here causing it. Try them! I have tried them 100 times. Will continue but discouraged. Thanks Ron
you can find the batt warning on web page when you connect jd in ARC.
#27
@darticus
I would like to help you through this. I know the frustration level must be very high now and you are sick and tired of people telling you to follow the tutorials or examples when none of that seems to work. At this point you don't know if the problem lies with what you are doing or if it is a malfunction with the robot. It can be difficult for someone who is well versed in all this stuff to truly sympathize with the beginner. Especially those who have been at this for years now and get tired of repeating themselves. I understand that too. It can get to me as well.
Anyway, to help you I need to better understand your problem. There has been so much back and forth, I'm not really sure what it is you are trying to do anymore. Could you please describe, in as much detail as needed, what it is you are trying to do and exactly what you are doing to try to accomplish the task? Step by step.
Take your time and think about what you need to say to get the points across to someone else. It often helps me to pretend I'm talking to someone and explaining what it is I am doing or trying to do. Helps get your thoughts organized. Tell me as much as possible. Doesn't matter if you ramble some. Don't feel you have to be brief.
Thanks.
WBS00001
finaly somebody understand this.best way are pics or video. its a huge diff when explanning to a programmer or a non programmer.
thank you for posting
#29
WBS00001Thanks for your concern. I really don't know again if it a robot problem, me loosing it, or interference to the robot. If you try the Multicolor activity in activities does it work? Do it as it says. Mine will not do the arm point portion. It sometimes does the colors but the arm point it won't do. Try that first. It is very possible I have interference jamming JD. Thanks Ron
does it work with one color?
#31
Can you build something that consistently works and gives you the correct result. This way you can confirm where the problem may be. If you are not able to get a repeatable function, we can look to see if it is a connection problem, hardware issue, or something else. If it does repeat, then we have a better idea of what is needed to help.
Just a suggestion that can maybe help identify your problem.
Ron R
#32
It does one color but it still won't point. Try it! At the start I couldn't connect to JD with WIFI and found that wireless items in the house was causing it. Once they were turned off it connected on the first try. I am wondering if I have interference or the programing is bad or its me doing something wrong. I can't continue until I know what the problem is. I can deal with interference but not with trying to follow poor programing examples. Try the MULTICOLOR ACTIVITY exactly as it says using the command line it uses. If it works it could be interference on my side. There are other things also that are not working right and it could be interference TRY IT PLEASE! Please don't assume it works until you try it. Thanks Ron
