Wheel Encoder Counter icon Wheel Encoder Counter — Arduino UNO wheel encoder: reads left/right ticks, provides counts, configurable ticks, wheel & pivot sizes, optional pose telemetry to ARC NMS. Try it →
Programing  Jd
I know this must be easy but I just can't find the right settings. I want JD to just see something moving and respond with speech. I also want JD to see a color and not get confused with movement and announce it. Can these both be run at the same time? Is there and activity to help with this movement recognition? Thanks All Ron
#97
Thinking about it. 500 BACK OR A BIG HEADACHE! Thanks all Ron
#98
@darticus Maybe it would help if you started with something simpler. The video stuff can be a pain even for those familiar with the Script language. Perhaps something to ease you into the scripting language so you would have more confidence when you tackle the camera stuff again.
How about starting with just having JD raise his hand and put it back down? Or is that too simple?
Let me know and I will post a step by step guide to doing it with details about each line of code.
#99
Thanks WBS00001 I really don't know what to do now. I think my brain is mush. Ron
darticus
take a day off,go outdoors or something els then pc robots. then deside what you gonna do,i would take the session with alan or wbs i have a feeling we bolt have same issue go from overexcitment to frustration. what ever you deside is good,aldo i hope you stay keeping frustrated with me.
#101
Thanks but I think I've had it. Good luck ALL. HELP NOMAD 6R. Ron
#102
@Darticus Below is a very simple script that turns on the camera (if off) then turns on motion tracking and finally takes a picture every time it sees movement.... This is just to show you how easy it is to do stuff like this using just one simple script. You may need to adjust the movement sensitivity slider under the motion tab in the camera control to avoid it taking pictures of nothing... Remember, this is just a generic script I wrote that you can run separately on it's own ( not the tracking script from within the camera control).
if ($IsCameraActive != 1) #turn on the camera on if off
  ControlCommand("Camera", CameraStart)
  sleep(1000)
endif
ControlCommand("Camera", CameraMotionTrackingEnable)
sleep(3000)
:top
waitforchange($CameraIsTracking)
if($CameraIsTracking = 1)
ControlCommand("Camera", CameraSnapshot)
saywait("movement detected")
endif
sleep(3000)
goto(top)
#103
@Richard_R Simple to you. Simple to me. But is it simple to Darticus?
#104
Thanks Richard thanks WBS00001 Thanks to Richard for putting in the time and yes WBS00001 it makes no sense to me. Again I see where he is going with his program but at 67 I don't think its time to study programing that really from what I see must be learned by trial and error with no real instructions or written documentation on using it. Maybe I'm lazy or just don't want to put in the effort. I will always watch the robot development info coming out but even the programing for ER1 was explained and easy to use they just went out of business. Thanks all Ron
